#91 | ||
Eat, Sleep, Jeep
Aren't the shims supposed to raise the yoke up? (meaning front point up more toward TC)?? The pic looks like you've got them lowering the yoke. Also looks like you have the military wrap on the frame side of the spring, not the shackle side. Do those springs have military wrap on both sides?
#92 |
the shims are on the right way, the thick end is pointing toward the front of the jeep, and i think the leafs are on right also.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares HOW BOUT THEM REDSOX The build thread http://www.jeepforum.com/forum/f12/my-little-build-503661/ My Rigrator score 535RRv1.0 BOA 25
#93 |
Hey Jeffro95
How do you like those tires in the snow? I live in SOCAL right now and will be moving to KY in a couple of months. I got the same ones and am thinking about replacing them with some 35's in a couple of months. But and don't want to get them if they totaly suck in the snow. ![]()
"The Empty Pocket Warriors." Member #2 "92 YJ, 3.5" BDS. Custom 1.5" lift shackles, 2" BL, Ford 8.8 W/Trac-loc & 33" TrXus MT's (for now). "No one ever accused the Wrangler of being comfortable, quiet, or practical. No one ever called it boring, either. The Wrangler is a two-door toy, ... great fun to drive with the top down." -- AUTOMOBILE MAGAZINE, March 1995. |
#94 | |
Eat, Sleep, Jeep
Thanks, was kinda hard to see on my laptop screen. Now that I'm home and can see, I feel like a tard for asking. |
#95 | |
Dreaming of Moab
#96 | |
Dreaming of Moab
#97 | |
Thanks, that confirms it fo me. I'm going to get anouther set. Maybe in the fall I'll see you at Attica.
#98 |
Dreaming of Moab
I've had my M.O.R.E. 5/8" boomerang shackles since 11/26/07...and today I finally put them on. The weather was nice...mid 30's, and sunny, this inspired me to get off my duff and get 'er done!
![]() The back and............................................... front. ![]() Driver side. ![]() Passenger side. ![]() Front. It took me a couple of hours. I need a bigger garage. Doing this in a one car garage, with just enough room to get around the rig was kind of a pain. I even had to unhook the garage door opener to get the door opened high enough to get it and out. ![]() I took it for a spin and could tell the difference, ride wise, instantly. Bumps that have sent spine jarring shock through me, every since I had the lift installed, were now almost non-exisitant. I flexed it a bit, and could tell the difference too...no pictures of that yet. I will need to get the steering wheel re-centered......again. If you have the RE 4" lift, get the M.O.R.E. 5/8" boomerang shackles...you won't regret it. These suckers are way more beefy than the stock shackles too. What to do next? Last edited by Jeffro06; 02-23-2008 at 06:30 PM.. Reason: Forgot something.. |
#99 |
Your Jeep is looking great!
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully. |
#100 |
Dreaming of Moab
Thanks. I've changed quite a bit since I bought it. I'm thinking about beefing up the rear end. Super 35 is the easiest option..for me, but I haven't decided yet. I want a rear locker, so I'll have to do something, strenght wise, to accomplish that. Cost and ease of install, will be the deciding factors here.
#101 |
Lookin good there!
________ l_l_,[____], l---L-- []lllllll[]- (o)_) (o)_)=o)_) ^^^^^^^^^^^ 1995 YJ Sahara, 4.0L 5spd Rubicon Express 4.5 extreme duty lift, SYE, Tom Woods custom drive shaft. Mickey Thompson MTZ 33x12.5R15 on d windows. |
#102 |
Nice jeep Jeffro!
Carry Concealed on Campus |
#103 |
Dreaming of Moab
Thanks guys. I'm trying to convince the wife it would look even better with a nice Warn winch up front.
#104 |
Dreaming of Moab
Well it's been almost a week with the boom's installed. The ride is smoother, the flex is better, but bump steer has appeared. It's not bad, but there wasn't any before. I don't have a dropped pitman arm, so I'm thinking it's time to get one. My steering wheel is taking a hard right, so I figure I may as well get the pitman arm, then adjust that.
My wife even says the Jeep rides better now. |
#105 |
ayyy what kinda flares are u running ......are they stock?
93 wrangler 2.5l, 2in lift shackels, 31's, eagle alloy 186,and a flowmaster 44 98 zj 4.0 straight 6, 4in f<r lift, adj. trak bars, rustys sway bar quik discos, skyjacker shocks, rancho steering stabalizer, 32x11.50 daytons, straight piped, 2 12" pioneers, I DO ALL MY OWN WORK! AND YES IM 17 BUT THIS JEEP AINT DADDYS MONEY! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
