Quantcast Jeffro's ride ... - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeffro's ride ...
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Closed Thread
Old 11-08-2007, 06:52 PM   #76
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
Nothing new today....but I'm considering MORE boomerang shackles...front and rear.
Member of Jeeps Going Wild and IndyORV
My Jeep Pictures
Jeffro06 is offline
Old 11-20-2007, 11:07 PM   #77
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
Just a little update.
My 5/8" Boomerangs are on the way. I've had no problems with the sye/cv. Love the TrXus tires. They worked good on the trail, road nice on the highway, and are balanced. The only negative so far is they are a bit hard for the first few miles on cold mornings. They soon warm up and the ride smooths out...as much as it can in a Jeep. The MORE boomerangs will probably be the last addition until spring.... I want sooooooo much more.
Better check my lottery ticket.
My Jeep Pictures
Jeffro06 is offline
Old 11-26-2007, 11:42 AM   #78
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
My M.O.R.E. boomerangs arrived today!! They sure are beefy. I'll post some pic's when the change over is complete.
My Jeep Pictures
Jeffro06 is offline
Old 12-18-2007, 08:24 PM   #79
Stout95YJ
2003 WJ
bump, got them shackles on?
2003 WJ 4.0 - 2" BB - 255/75 on 17" JK Moabs - Projector's with 6000k HID's - 236k and counting
1996 XJ trail rig - sold
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you." - Jeremy Clarkson
Stout95YJ is offline
Old 12-18-2007, 09:41 PM   #80
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I just bought some MORE boomerang shackles for the front. I've been going through in my head how I'm going to install them without removing the springs. how did you install them, if you did already?
White '94 YJ 2.5L 5 speed, 33" BFGs MTs, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio
Member #94 White Jeep Club
My Jeep
'89 XJ Laredo Bone Stock
KB6NQT
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
Old 12-18-2007, 11:06 PM   #81
Ryanpowell167
When i did my booms, i just jacked up the front frame so it took all the pressure off the axle. Then i unbolted them and just had the springs stickin out. Then i bolted up the new ones and lowered the springs down into them....
DARK STONE 2005 6.0l v-8 PowerStroke F-350
BLACK 1992 YJ 383Stroker, TH350, looking for a np205, d44 front, 12bolt rear, SOA on 4" springs, 35" Baja Claws, m8000, Electric fan, sliders, bumpers, crossmembers, all made by myself.
Black Jeep Club Member #167
Ryanpowell167 is offline
Old 12-19-2007, 05:30 PM   #82
Mr.B
Mr.B's Avatar
Thanks for the reply. But let me ask. Did you jack up the frame so the tires were off the ground? And then wouldn't you also have to jack up the axle a little to take weight off the springs?
My Jeep
KB6NQT
Everyone is Welcome
Mr.B is offline
Old 12-19-2007, 06:34 PM   #83
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
NOPE! I've been busy with work and all...trying to get caught up before the end of this week, at which time I start a vacation. I'll be off until after the new year, and I hope to get them on then.
I will post some photos afterwards.
It kills me to see them sitting in the box everytime I walk through the dining room....which by the way the wife keeps tellling me to get them out of.
My Jeep Pictures
Jeffro06 is offline
Old 12-19-2007, 09:32 PM   #84
danielp
jeffro love the jeep im hoping to have my jeep setup like you have it now within the next 2-3mos. question. what size tires were you running before you got the 33 trxus? if anything ima be running a 4" lift on 31"s untill i save some more for the 33s
/l, [____],
l---L –[]lllllll[]-
()_) ()_)--o-)_)
95yj 4 happy squirrels going strong
31" BFG AT/KO
stock susp.
danielp is offline
Old 12-19-2007, 09:34 PM   #85
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
Thank you. I had 32x11.5's prior to the 33's.
My Jeep Pictures
Jeffro06 is offline
Old 12-20-2007, 11:51 AM   #86
jsahara24
1995 XJ Cherokee
looks good man, I was wondering where you bought those 8* shims? Thanks, Jason
95' Jeep Cherokee Sport
03' Subaru Forester X
jsahara24 is offline
Old 12-20-2007, 02:29 PM   #87
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
Right here in the vendor section, from Fullsizexj.
My Jeep Pictures
Jeffro06 is offline
Old 01-14-2008, 01:30 PM   #88
93jeepREDSOX
You said that you put in the 8 degree shims for you rear right, how did you go about doing them, I have ordered them and wanted to get some ideas on how to go about doing it.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
Old 01-14-2008, 04:43 PM   #89
Jeffro06
Dreaming of Moab
Jeffro06's Avatar
It's pretty straight forward. You need a floor jack and some jack stands. And of course the right wrenches... Once you loosen up the u-bolts holding the springs on the axle, you slip out the old shims and slip in the new.
Well it wasn't quite that easy...turns out the hole in the new shims wasn't as big as the centering pin. A quick trip to a buddies shop, to use his drill press, solved that problem. I just needed to take the old shim with so we knew what size the hole should be.
After replacing the shims it was as simple as tightening everything back up. I'm not a grease monkey by any means, and this was very easy. Not much to it at all.
Now I have GOT to find time to put on my M.O.R.E. Boomerang shackles!!! I've had them for like forever!!
My Jeep Pictures
Jeffro06 is offline
Old 01-14-2008, 04:55 PM   #90
93jeepREDSOX
Did you take the u-bolts completly off or just losen them up enough to get the shim out.
Closed Thread
Glock Forum
