#61 | ||
Dreaming of Moab
![]() Now put them in the back seat, side by side, take the seat belts and lace them trough the upper eyelets, squeeze your hand down between the two seats, and secure the buckles. Oh, one more thing....take them out when the twins aren't with you, or you'll look like a dork! ![]()
#62 | |
Dreaming of Moab
Here is what it looks like now... ![]() It didn't go without a hitch though. The new shims came with new centering pins. With those were some little washers...one for each pin. First step of the day was to remove the transfer case drop. Then we, my daughter's boyfriend Josh, jacked up the rear end, supported the springs with jack stands, and started the swap. The fisrt problem of the day came when the pins that RE sent with the shims was too big to fit the predrilled hole.... Thankfully a buddy of mines dad owns a suspension and allignment shop 2-minutes from my house. Even more thankfully....his dad was there at 10am on a Saturday. He drilled out the holes to their proper size!! We returned to my garage and in went the shims. We were trying to figure out the whole pin, washer, thing. It didn't seem the the washers were needed, but we tried one. Guess what.....not needed. As Josh started to remove the pin the threads on it stripped, about half way down! I used a hacksaw to cut the pin, just above the the stripped nut. Josh was able to rethread the bolt onto the pin! We were back on track!From there everything bolted up just fine. We took her out for a test drive and all is well, no more vibes!!! Once that was all done I ordered 5 new 33x12.50 R15 TrXus MT's!! Hopefully they will be here, and mounted in time for the Badlands on the 28th!! |
#63 |
dig the pink
do they make a okoly seat cover for that model?
_______ l l_[____], I—L---{[]ll[]}- (0)_)(0)_)-(o)_) 88 hardtop 258 (Strong motor) 3 in lift, 1 in body , 32X12.50, webber, nutter, HEI upgarde and needs paint. |
#64 | |
Dreaming of Moab
#65 |
Jeffro, be very careful , that driveshaft is too long for your setup , it looks completely stuffed in at ride height, if compressed it will press on your tcase, eventually destroyn'it and- or bending the new ds.
Triple measure everything before driving it really, to me it looks just wrong like that! Maybe it's just the pic, but..!!!!! Greetings from Italy!!!! ![]() |
#66 | |
Dreaming of Moab
#67 |
i have the same lift as you, could i just lengthen my driveshaft and use some 8* shims?
2003 WJ 4.0 - 2" BB - 255/75 on 17" JK Moabs - Projector's with 6000k HID's - 236k and counting 1996 XJ trail rig - sold "Speed has never killed anyone, suddenly becoming stationary... That's what gets you." - Jeremy Clarkson
#68 | |
Dreaming of Moab
#69 |
i agree with chris yj, there doesn't look to be any room for the driveshaft to compress when the axle articulates. even if some of it is the angle, i would think you would be able to see some splines. otherwise nice looking jeep!
http://community.webshots.com/user/richmond1273 1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears 3" Rough Country suspension 33x12.50 Mastercraft MT 2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears |
#70 | |
Dreaming of Moab
#71 |
Dreaming of Moab
New tread!
Well my TrXus 33x12.5 R15's arrived today. I had them mounted today too.
Here's how she looks now..... ![]() I still have to go out and hit some highway speeds to see how well they balanced, as I've read they are a bit hard to tame. It takes a little more time for the rig to come to a stop now. Noticed that when an idiot slammed on his brakes, right in front of me, just two minutes after I left the shop. I like the way she looks, much better now. ![]() |
#72 |
I have the same tires and i think that they are awsome. They are pretty quiet and they have a great bite off road. Good tire in my opinion.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares HOW BOUT THEM REDSOX The build thread http://www.jeepforum.com/forum/f12/my-little-build-503661/ My Rigrator score 535RRv1.0 BOA 25
#73 | |
Dreaming of Moab
They ride well on the road, at 70mph, and made the day of off-roading better than it was with the Mickey Thompson's I had. I've read that the TrXus radials are hard to balance, mine are fine. To sum it up...they look good, ride good, grip well, clean out well, handled in the rain @ highway speeds well, didn't slip in the rain during acceleration....now all I need is some snow! |
#74 |
HAHA
That looks awesome. Really nice jeep
-Andrew Another Chero in progress |
#75 | |
Dreaming of Moab
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
