Jeffro06's Rubicon - Page 39 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeffro06's Rubicon
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 02-08-2011, 08:42 PM   #571
LuckRider
LuckRider's Avatar
Simple answer, it came from a YJ so it needs mounts for a TJ. The axle shafts are smaller or weaker IIRC. Axle disconnect is something that the YJ had. It disconnects the drive shaft so that the shaft isn't spinning unless it is in 4wd. The drive shaft was not balanced and would vibe it it spun at highway speed. TJ shafts are balanced, so they spin with the front axle.
In short, not worth it for you if he dropped it in your garage for free (unless you swapped the carrier with yours to get the gearing).
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 08:49 PM   #572
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Unless you need the axle for a YJ, I wouldn't bother with it either. It's here if anyone needs it, for free, if they can come and get it.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 09:45 PM   #573
kellerumps
Didnt think it would work....but I am on the lookout for HP D30 that will work. If I truss it, then it would be as good as a D44 for ALOT less $$$$.
I have a D30 with 4.88's and Lock-Rites that I would sell or trade. The HP D30 isnt high on my list, but I wont turn down a good deal if I find one.
I don't look for problems....They find me.
Member of: [URL="http://www.indyorv.com"][B]IndyOrv[/B][/URL]
kellerumps is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 09:49 PM   #574
Imped
Imped's Avatar
Come to Indy. There are about 4-5 XJ HP30's (bolt into a TJ) in great shape sitting in the junkyard on any given day. I'll go pull you one for a small fee.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 09:51 PM   #575
tucanbob
not to highjack this futher, but can you help me idenitfy this axle in a JY? we have tons of xjs
99 TJ - SOLD
running jeep-less for now.
tucanbob is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 09:53 PM   #576
2006_Sport
Look at your axle, look where the positioning of the pinion is on the back of the diff. You will see that it's on the low side.
Now go look at an HP30 and see what's different? The pinion is raised up.
2006_Sport is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 09:59 PM   #577
Imped
Imped's Avatar
A pinion and ring gear intersect perpendicularly so that pinion is either rotating the ring gear on the bottom (LP) or top (HP). It's very easy to see the difference. If you don't already know, the drive shaft is connected to the yoke, which is connected to the pinion. Not all XJ's had the HP30 you want so do a little research before you pull one. You don't want the disconnect HP30 or the LP30 from the late XJ's. 95-99 will for sure have a HP30 you want.
SORRY FOR THE HIJACK, JEFF!
OlllllllO
Float Test Build
IndyORV
Unread 02-08-2011, 10:04 PM   #578
kellerumps
Where in Indy and what are they running cost wise....I PULL
Unread 02-08-2011, 10:04 PM   #579
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Unread 02-08-2011, 10:06 PM   #580
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Unread 02-08-2011, 10:07 PM   #581
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Unread 02-08-2011, 10:48 PM   #582
TOLjeep
Looks sweet man. Liking the outcome on the Rubi. Looks stockish but yet so capable. tummy Tuck time?
2003 Jeep Wrangler Sport Dana 30 Front, Dana 35 Rear, 5 Speed
2.5'' Rough Country Suspension
33x12.50 Mud Grapplers on 17" Black Rock Vipers
Mopar Rubicon Rockers,Warn Front Bumper, Bestop Rear Bumper, Banks Exhaust, K&N FIPK
Next: 1.25 Inch Body lift, SAVVY Corner Armor and Steering, PSC Rocker Knockers
Down the Road: Ford 8.8, 3 Inch Springs, 35" Mud Grapplers on Black 20's
TOLjeep is offline   Reply With Quote Quick reply to this message
Unread 02-09-2011, 07:39 AM   #583
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Thanks.....a tummy tuck will be down the road a bit.
Unread 02-09-2011, 10:12 AM   #584
LuckRider
LuckRider's Avatar
What are you planning for a TT? Something like UCF, Savvy, Rockmen?
Support Our Troops!
Unread 02-09-2011, 10:20 AM   #585
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
At this point it's more like wishing.
A TT that's flush with the frame, Rokmen control arms, and new drive shafts would all have to be done at that time as well.....so it's on the back burner for now.
It's time to finish up what I've bought and enjoy it for awhile.
badlands , indyorv , jeeps gone wild , photography , rokmen
