Jeffro06's Rubicon - Page 206 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeffro06's Rubicon
Rough Country Lift Kits and Parts!RIGID LED Light Blowout Sale - All Sizes, All Series, all Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerrai
Unread 06-08-2013, 08:10 PM   #3076
LeadDog
Originally Posted by Jeffro06 View Post
But, I'm in no hurry to get back in the mud.
So no Cliffs for you? What a shame.
The scenery never changes unless you're the Lead Dog.
LeadDog is offline   Reply With Quote Quick reply to this message
Unread 06-08-2013, 08:30 PM   #3077
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Not for awhile....in fact I don't know when I'll hit the trails again, after Moab Illinois and Indiana are kind of a let down.
Maybe I'll just head west again.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote Quick reply to this message
Unread 06-08-2013, 09:56 PM   #3078
dandaman99701
Thanks.... I'll have to give your build a looksee (link?). I am running the stock rear tb, with the relocation bracket that came with the OME lift.
Hmmm, I don't remember my lift coming with a rear tb bracket but then again I had someone else install it. No link to my build since I don't have a build thread. My specs should be in my profile. Maybe i will hold off on the rear Currie tb just to save a bit of dough for now. Thanks for the response.
dandaman99701 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2013, 06:20 PM   #3079
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Jeep is acting a bit weird when I start it. It clicks as if the battery is dead, I turn the key again and it starts...a bit sluggish, but starts. But if I turn it off and start it right back up it starts fine. I'm thinking maybe its the battery, but I'm not sure...could be the starter, don't really know.
Unread 06-15-2013, 07:08 PM   #3080
LeadDog
It's because you won't wheel it until your next trip to Moab. It wants some love!
Unread 06-15-2013, 08:03 PM   #3081
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I wish it was that simple.
Unread 06-15-2013, 08:29 PM   #3082
my98tj
Have you turned the key on and let the fuel pump kick on without starting, turn the key off and back on and try to start it on the second time? May be fuel pressure regulator or a leaky injector.
Can anyone tell me how the flux capacitor is used to facilitate time travel???
my98tj is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 08:27 AM   #3083
Holaday
Stop in to Missouri some time. I think you would enjoy some of the parks here
Holaday is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 08:53 AM   #3084
Moabrubi
I feel sorry for you guys who only have off road parks. We have a few parks here but they are pretty boring in comparison.
Moabrubi is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 04:33 PM   #3085
aw12345
So Cali has plenty of stuff to entertain on, just in summer the choices get a bit slim, unless you like night wheelin.
I for one still thoroughly enjoy driving the bunny trails I first cut my teeth on. Moab, AZ, CO and NM trails just add to the variety of wheelin.
Good part of Moab trails fall pretty much in the bunny trail category, but are a blast to put around on anyway
By the way as far as your Jeep starting problem, clean and tighten the battery cables on both ends and have the battery tested, should resolve your problem
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 06-16-2013, 09:18 PM   #3086
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
As far as my starting issue goes, I found a moment to pop the hood to check the battery cables....the positive cable was super loose, so I made quick work of that, started it...without the clicking, and took it for a ride. Hopefully it was just the loose cable, not giving it the juice to start, and possibly not letting it charge correctly too.....I guess we'll see. If nothing else this give me a reason (excuse) to buy a DieHard Platinum.
And as for only having off road parks....it sucks, big time. I'll correct that in 6 years.
Unread 06-16-2013, 09:54 PM   #3087
aw12345
Retirement in 6 years? Gonna move to Florida
Unread 06-17-2013, 06:34 AM   #3088
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I won't be old enough for Florida.
Unread 06-17-2013, 05:01 PM   #3089
dandaman99701
Cocked Joints
[QUOTE=Jeffro06;13174699]I lied, I went back out and found it was off center by about a 1/4 of inch. I centered the axle, centered the steering wheel, and the CA's are no longer cocked.
Hopefully I'll be able to break that rear bolt free, soon, but not today, I'm beat. [/QUOTE
Afternoon Jeffro, So I started my control arm install. Got both front lowers on and had the same situation that you did. Both are cocked. Could you explain a bit more how you went about centering the axle to straighten the arms. I set them at stock length like you did. Just trying to wing this on my own so any advice is appreciated. Also, for the rear lowers, the arms should be the same style as used up front on the lowers correct?
Unread 06-17-2013, 06:28 PM   #3090
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
The "crooked" control arms are nothing to worry about.... they won't center themselves after they move (it was new to me, what did I know). Just make sure the control arms that are supposed to be the same length are.
As for centering the axle I unhooked the track bar and jumped up and down on the bumper... really, which got it close. I measured from a common point on each side of the frame to a common spot on each tire. To fine tune it I turned the wheel, which will move the axle when the track bar is unhooked. Once centered I bolted up the track bar.
badlands , indyorv , jeeps gone wild , photography , rokmen
