Jeffro06's Rubicon - Page 195 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeffro06's Rubicon
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 04-29-2013, 06:37 AM   #2911
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Originally Posted by mudn_MI_rubi View Post
Read thru Jerry Bransford's install writeup for the cooler. I think with that help you should be good to instal it yourself.
I read it, twice, it still scares me.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 08:01 AM   #2912
shortstax33
I'm always up for terrifying installs, let me know if you want help, lol.
[URL="http://www.jeepforum.com/forum/f22/staxs-98-tj-build-1245771/"]My build thread[/URL]
"And if anyone's curious, the answer is yes. I drink beer before/during all mechanical surgery on my vehicles. " - yours truly.
shortstax33 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 08:45 AM   #2913
tsstoudt
Web Crawler
tsstoudt's Avatar
I'd gladly help but PA is just too far away. I love working on them when it's not costing me any money...lol good luck with the install.
ΜΟΛΩΝ ΛΑΒΕ
tsstoudt is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 12:27 PM   #2914
bobthetj03
And this is one of the few times I'm glad I have a manual trans! LOL!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 12:44 PM   #2915
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I hear ya.
Unread 04-29-2013, 02:25 PM   #2916
MountainMan864
Any thoughts on a power steering cooler as well before Moab? Gonna change ur diff fluids,xfer case, etc?
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 03:05 PM   #2917
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Not worried about PS. It survived before, hopefully it'll survive again. Everything else on the Jeep is ready to go, the tranny cooler has always been on my list, this trip just pushed it to the top.
Unread 04-29-2013, 08:51 PM   #2918
ksilovich
The cooler is an easy install. I helped ryan with his. The wiring is easy to. If you need help let me know I can swing by after class this week or after my finals next week.
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline   Reply With Quote Quick reply to this message
Unread 04-29-2013, 09:04 PM   #2919
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I may have it by the time you're done with finals.....you know a thing or two about wiring do you?
Unread 04-30-2013, 12:06 AM   #2920
ksilovich
do you even have to ask that question?
Unread 04-30-2013, 06:37 AM   #2921
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
No.....I thought I was being funny.
Unread 04-30-2013, 06:49 PM   #2922
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
My cooler is on the way.
Unread 05-02-2013, 12:15 PM   #2923
BRay
Now that the cat's a$$ of tranny coolers. It has the good AN fittings and good push-lock hose so you are sure to get a good connections to avoid leaks. Is it wired direct to the battery? If they have you going into a circuit then I would make sure you to use a relay along with the fuse they supply. I'll join in on the gathering when your ready to install.
2012 Jeep JK Rubicon
BRay is offline   Reply With Quote Quick reply to this message
Unread 05-02-2013, 12:25 PM   #2924
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
It's here!
It doesn't wire directly to the battery, it has to be wired to a source that is "keyed" so it doesn't run while the jeep isn't.
It appears to have everything it needs with it....except tranny fluid of course.
Making sure I hook up the hoses correctly and getting it wired are the two biggest things that scare me, getting it attached to the jeep is the easy part. I also wonder just how much fluid is going to pour out on me when I unhook the hose at the radiator.
Unread 05-02-2013, 01:31 PM   #2925
BRay
Cool you got it. If you have never changed the trans fluid then now is a good time. If your NOT going to change it then just get 2 quarts. I also suggest wiring in a relay and between us locals we can help you with that.
badlands , indyorv , jeeps gone wild , photography , rokmen
