Jeffro06's Rubicon - Page 118 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeffro06's Rubicon
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-12-2012, 09:20 PM   #1756
Sgt.Fuzz
Originally Posted by Jeffro06 View Post
So if I order Metal Cloak Overlines the question of the day would be.....4" or 6" flares? I'm thinking the 4" flares would look better with my wheel and tire package.
"Purely hypothetical"...
I dont even know why they make a 6" flare. 4" overline is where its at, but I am a little biased.
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote Quick reply to this message
Unread 04-12-2012, 09:22 PM   #1757
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I'm thinking of copying you on the JK signals too....I mean hypothetically.
Do you have side markers too?
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2012, 09:27 PM   #1758
Sgt.Fuzz
No side markers for me. I never got around to installing any since its not required equipment in Texas.
Unread 04-13-2012, 07:36 AM   #1759
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I spent $1300 today.................
But it was on taxes, not the jeep.
Unread 04-13-2012, 10:17 AM   #1760
bobthetj03
Overlines? Moving right along I see! Does this mean a tire upgrade is in the works? Those 32's are gonna look tiny!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 04-13-2012, 11:04 AM   #1761
JJeeper09
I'm don't think that is what he just spent his money on..
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 04-13-2012, 11:56 AM   #1762
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
The tire upgrade would be down the road, as they'll have to be accompanied by gears....cha-ching.
Not yet anyway.
Unread 04-13-2012, 12:21 PM   #1763
B2CARPEN
B2CARPEN's Avatar
Jeff you could easily get away with running 35s with those D44 axles, 4.10 gearing, and that 42RLE trans. You are at a 4:1 crawl ratio in 4LO as well, so IMO it would be more then manageable..
B2CARPEN is offline   Reply With Quote Quick reply to this message
Unread 04-13-2012, 12:27 PM   #1764
bobthetj03
Good group at MC. Stopped by their facility to check out the Overlines when they first came out and He took time to show me around and got to see several rigs with them installed. Sold me on them from that point. As you probably know, you'll have to trim your sliders to fit. Think Fuzz did on his if I remember correctly. That was a million pages ago on his build.
Bob's boring build:
Unread 04-13-2012, 12:59 PM   #1765
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Hwy gearing is my bigger concern and after driving cross country with the 32's, there is no way in hell I'd ever try that on 35's w/out a re-gear.
Yeppers, I know. I've got Fuzz's page bookmarked.
Unread 04-13-2012, 02:59 PM   #1766
AngryTJ
4.10s with 35s isnt bad at all with my 6speed
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 04-13-2012, 03:35 PM   #1767
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
My auto, on 32's...in the Rocky Mountains...sucked. Any slower and I would have been parked. Heck even trying to maintain 70 mph on a flat hwy in Nebraska was not an easy feat....unless you don't mind turning 4000 rpms for long periods of time.
Unread 04-13-2012, 03:46 PM   #1768
B2CARPEN
B2CARPEN's Avatar
Larger tires will help balance out that power range Jeff
You wont have as much launch speed but you will still be able to use all of your gears for daily driving and run lower rpms at higher speeds.
Unless you meant that you werent able to hit 70 unless you turned your OD off, then were running 4k rpms in 3rd?? There's no way you should be hitting 4k rpms @ 70 mph w/ OD.
4.10s are not ideal for 35s, but they are manageable. But I know you Jeff, you don't want to make that step until you do it in an ideal way.
Unread 04-13-2012, 03:51 PM   #1769
2006_Sport
You guys aren't realizing that the 42rle auto is a turd. It bogs the motor down whenever it gets the chance to and it uses every opportunity to get into OD. Even with OD off, it's still a turd, but I have 3.73s.
2006_Sport is offline   Reply With Quote Quick reply to this message
Unread 04-13-2012, 04:27 PM   #1770
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
QFT
The 42rle sucks. I tried overdrive off, on you name it, as I went cross country, at times it felt like I was going to blow that thing up just trying to do the speed limit...thanks to the high winds trying to blow me backwards. Steep climbs with the OD off were slow going too. Off road however it treated me well.
I'm sure I could get away with 35's off road, around my neck of the woods though. Maybe a second set of wheels and tires will be in my future, someday. Like when my lottery numbers are drawn...
ps...my trail corners arrived!
badlands , indyorv , jeeps gone wild , photography , rokmen
