Jeffro06's Rubicon - Page 104 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeffro06's Rubicon
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 03-07-2012, 07:39 AM   #1546
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I sure hope the upper CA's go on easier than the lowers. I'm still recovering from fighting all those bolts. I have two busted knuckles (one on each hand, despite wearing gloved....most of the time), two cuts on the top of my head (those fender flares are sharp), "road rash" on my right tricep (from rubbing on the garage floor while trying to loosen a bolt), a cut but thankfully not broken nose (due to a wrench slipping off a bolt), and two sore hips bones (from laying on the damn concrete for hours on end). I'm getting to old for this stuff.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2012, 08:09 AM   #1547
aw12345
Come on you gots to toughen up some and git er done
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2012, 08:22 AM   #1548
ksilovich
I got an idea for ya..... Sell the jeep and all your problems will go away.
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline   Reply With Quote Quick reply to this message
Unread 03-07-2012, 09:07 AM   #1549
Louie4
Sounds like it's time to pop a few ibprophens. You missing the YJ at all?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2012, 09:13 AM   #1550
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I'm trying.
I've got twin 10 year old girls, so I doubt it.
Did that.
Not really.
Unread 03-07-2012, 10:20 AM   #1551
bobthetj03
We're pulling for ya, my friend! Stay strong, it'll all be worth it!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2012, 10:30 AM   #1552
Imped
Imped's Avatar
Before you start on the uppers, see if the tires will be in the way of the bolt access holes on the outside of the frame rails. If you can get a straight shot at them without the tires being in the way, you're good. If not, then you'll need to pull them off, set the axle on jack stands, and use a jack under the pinion just like I told you.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 03-07-2012, 07:35 PM   #1553
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
When I got home from work I crawled under the jeep and installed the rear upper CA's!!!!
Only problem I had was dropping a socket inside the frame rail on the passenger side. I'll have to fish that out later.
The rear uppers went on pretty easy compared to the lowers. Now to find time to do the front uppers, then the Currectlync.
No cuts, scrapes, bruises or other injuries to speak of tonight.
Took it for a drive, no vibes, drives nice.
Unread 03-08-2012, 01:44 AM   #1554
bojang
Think it took me 15 minutes to do the steering. Give the knuckles and arm a few shots of lube of choice, and a couple wacks with a hammer today, again tomorrow morning, and do it tomorrow afternoon.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline   Reply With Quote Quick reply to this message
Unread 03-08-2012, 07:31 AM   #1555
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
It looks like there's still a chance I'll be snowmobiling up north this weekend, if so the jeep is going to have to sit for a bit.
Unread 03-08-2012, 08:46 AM   #1556
MountainMan864
You gonna buy the JJ housing kit too? Or just replace the bushing on the housing? Im so jealous I hope you get Death Wobble.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2012, 08:48 AM   #1557
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
The what?
Thanks man....appreciate that.
Unread 03-08-2012, 08:50 AM   #1558
MountainMan864
The housing kit that replaces the factory bushings on the front axle housing with a JJ.
Unread 03-08-2012, 08:55 AM   #1559
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Nope, no cutting, no welding for me. I'll be happy with the upgrade these parts give me.
Unread 03-08-2012, 09:59 AM   #1560
Imped
Imped's Avatar
The housing JJ's do make a nice difference, especially considering that when the stock bushings wear down, it's a major DW culprit. Really easy job.....come down to Indy and one of us could do it for you.
OlllllllO
Float Test Build
IndyORV
badlands , indyorv , jeeps gone wild , photography , rokmen
