Jeffro06's Rubicon - Page 103 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeffro06's Rubicon
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 03-04-2012, 01:13 PM   #1531
Imped
Imped's Avatar
You need leverage. Breaker bar is good.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 03-04-2012, 01:15 PM   #1532
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Tried one......not a real long one though.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2012, 04:37 PM   #1533
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Ok, I've got three out of four lowers on. I can't get the DS rear lower off. The front bolt will break free but the rear bolt fought a good fight and won, for now. I need more leverage and just can't get it with the jeep on the ground. I'll talk to a few people tomorrow and see what I can work out.
The front two lowers aren't sitting straight, both are cocked to one side, the same side....normal? Not normal? I set the new CA's to the same length as the old ones, the bolts slid right in, no forcing at all.
It drives fine, better than it did actually, it feels more responsive. I flexed it and nothing broke, so that's a plus.
But for today I'm done.
Unread 03-04-2012, 04:38 PM   #1534
Imped
Imped's Avatar
If they're cocked to one side, the axle isn't centered.
OlllllllO
Float Test Build
IndyORV
Unread 03-04-2012, 04:43 PM   #1535
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Alrighty then, I guess I should wait until all 8 are on then center it.
Unread 03-04-2012, 04:46 PM   #1536
Imped
Imped's Avatar
I'd center it before dropping the uppers in. Regardless of the order of operations, ending up with a centered axle that's square to the frame is the key.
OlllllllO
Float Test Build
IndyORV
Unread 03-04-2012, 05:39 PM   #1537
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I lied, I went back out and found it was off center by about a 1/4 of inch. I centered the axle, centered the steering wheel, and the CA's are no longer cocked.
Hopefully I'll be able to break that rear bolt free, soon, but not today, I'm beat.
Unread 03-05-2012, 07:16 AM   #1538
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
My Currectlync steering will be here today.
I'm going to try and find someone who'll bust that stupid rear CA bolt free. The upper CA's are going to have to wait until at least next weekend.
Unread 03-05-2012, 08:09 AM   #1539
JJeeper09
Lucky. HF has some cheap electric impacts, the are around 35 bucks and mine works great! Check it out it will save some time for future adjustments.
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is online now   Reply With Quote Quick reply to this message
Unread 03-05-2012, 09:55 AM   #1540
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
My local jeep dealer is going to break the bolt free....pro bono. Should be able to get the control arm on tonight.
Unread 03-05-2012, 02:17 PM   #1541
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
My Currie Currectlync was waiting for me, on my porch, when I went home for lunch...that thing is pure beef.
The last bolt on my lower CA's needed to be heated up, but it's loose now. I'll see if I can't get it swapped out tonight.
Looks like I might be going snowmobiling up north this weekend....weather permitting, so the jeep may have to go on hold.
Unread 03-05-2012, 05:59 PM   #1542
ksilovich
You better hope that this 60* warm front doesn't melt it all.
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline   Reply With Quote Quick reply to this message
Unread 03-05-2012, 06:01 PM   #1543
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
It's way up north, almost Michigan. If it melts we might just switch to atv's..
Unread 03-05-2012, 06:05 PM   #1544
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
I got that last lower CA on, thankfully.
Here's a peek:
Flexing it:
The Currie Currectlync:
Unread 03-06-2012, 08:26 AM   #1545
Sobie
Bolt-on Maniac
Sobie's Avatar
Nice. When you install the steering make sure you have a mallet. I didn't need a tie rod puller. I just hit the casting a few times while pulling down and they popped right out. Loosen the nut but leave the nut on with a few threads to "catch" it.
USAF
Sobie is offline   Reply With Quote Quick reply to this message
badlands , indyorv , jeeps gone wild , photography , rokmen
