Jeffro06's Rubicon - Page 39 - JeepForum.com
post #571 of 4273 Old 02-08-2011, 07:42 PM
LuckRider
LuckRider's Avatar
Simple answer, it came from a YJ so it needs mounts for a TJ. The axle shafts are smaller or weaker IIRC. Axle disconnect is something that the YJ had. It disconnects the drive shaft so that the shaft isn't spinning unless it is in 4wd. The drive shaft was not balanced and would vibe it it spun at highway speed. TJ shafts are balanced, so they spin with the front axle.
In short, not worth it for you if he dropped it in your garage for free (unless you swapped the carrier with yours to get the gearing).
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #572 of 4273 Old 02-08-2011, 07:49 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Unless you need the axle for a YJ, I wouldn't bother with it either. It's here if anyone needs it, for free, if they can come and get it.
Jeffro06 is offline
post #573 of 4273 Old 02-08-2011, 08:45 PM
kellerumps
kellerumps's Avatar
Didnt think it would work....but I am on the lookout for HP D30 that will work. If I truss it, then it would be as good as a D44 for ALOT less $$$$.
I have a D30 with 4.88's and Lock-Rites that I would sell or trade. The HP D30 isnt high on my list, but I wont turn down a good deal if I find one.
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #574 of 4273 Old 02-08-2011, 08:49 PM
Imped
Imped's Avatar
Come to Indy. There are about 4-5 XJ HP30's (bolt into a TJ) in great shape sitting in the junkyard on any given day. I'll go pull you one for a small fee.
OlllllllO
IndyORV
Imped is offline
post #575 of 4273 Old 02-08-2011, 08:51 PM
tucanbob
not to highjack this futher, but can you help me idenitfy this axle in a JY? we have tons of xjs
99 TJ - SOLD
running jeep-less for now.
tucanbob is offline
post #576 of 4273 Old 02-08-2011, 08:53 PM
2006_Sport
Look at your axle, look where the positioning of the pinion is on the back of the diff. You will see that it's on the low side.
Now go look at an HP30 and see what's different? The pinion is raised up.
2006_Sport is offline
post #577 of 4273 Old 02-08-2011, 08:59 PM
Imped
Imped's Avatar
A pinion and ring gear intersect perpendicularly so that pinion is either rotating the ring gear on the bottom (LP) or top (HP). It's very easy to see the difference. If you don't already know, the drive shaft is connected to the yoke, which is connected to the pinion. Not all XJ's had the HP30 you want so do a little research before you pull one. You don't want the disconnect HP30 or the LP30 from the late XJ's. 95-99 will for sure have a HP30 you want.
SORRY FOR THE HIJACK, JEFF!
OlllllllO
IndyORV
Imped is offline
post #578 of 4273 Old 02-08-2011, 09:04 PM
kellerumps
kellerumps's Avatar
Where in Indy and what are they running cost wise....I PULL
Member of:
post #579 of 4273 Old 02-08-2011, 09:04 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Jeffro06 is offline
post #580 of 4273 Old 02-08-2011, 09:06 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Jeffro06 is offline
post #581 of 4273 Old 02-08-2011, 09:07 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Jeffro06 is offline
post #582 of 4273 Old 02-08-2011, 09:48 PM
TOLjeep
Looks sweet man. Liking the outcome on the Rubi. Looks stockish but yet so capable. tummy Tuck time?
2003 Jeep Wrangler Sport Dana 30 Front, Dana 35 Rear, 5 Speed
2.5'' Rough Country Suspension
33x12.50 Mud Grapplers on 17" Black Rock Vipers
Mopar Rubicon Rockers,Warn Front Bumper, Bestop Rear Bumper, Banks Exhaust, K&N FIPK
Next: 1.25 Inch Body lift, SAVVY Corner Armor and Steering, PSC Rocker Knockers
Down the Road: Ford 8.8, 3 Inch Springs, 35" Mud Grapplers on Black 20's
TOLjeep is offline
post #583 of 4273 Old 02-09-2011, 06:39 AM Thread Starter
Jeffro06
Jeffro06's Avatar
Thanks.....a tummy tuck will be down the road a bit.
Jeffro06 is offline
post #584 of 4273 Old 02-09-2011, 09:12 AM
LuckRider
LuckRider's Avatar
What are you planning for a TT? Something like UCF, Savvy, Rockmen?
Support Our Troops!
JFI Member #7:
post #585 of 4273 Old 02-09-2011, 09:20 AM Thread Starter
Jeffro06
Jeffro06's Avatar
At this point it's more like wishing.
A TT that's flush with the frame, Rokmen control arms, and new drive shafts would all have to be done at that time as well.....so it's on the back burner for now.
It's time to finish up what I've bought and enjoy it for awhile.
Jeffro06 is offline
badlands , indyorv , jeeps gone wild , photography , rokmen
My Rubicon DaveFL Jeep Builds 7 02-02-2015 02:07 PM
Black Rubicon with flat black Rubicon decals MoparToYou Jeep Picture Requests 16 03-12-2012 06:53 AM
TJ (Rocky Mountain Edition) on Rubicon Wheels or Rubicon with Rocky Mtn. Interior MichaelK23 Jeep Picture Requests 19 01-03-2011 09:08 PM
My New Rubicon jeepmojo01 Jeep Builds 9 08-10-2009 07:44 AM
My New Rubicon Zacb262 Jeep Builds 5 06-02-2009 10:11 PM
