Jeffro06's Rubicon - Page 206 - JeepForum.com
post #3076 of 4273 Old 06-08-2013, 07:10 PM
LeadDog
Originally Posted by Jeffro06 View Post
But, I'm in no hurry to get back in the mud.
So no Cliffs for you? What a shame.
The scenery never changes unless you're the Lead Dog.
LeadDog is offline
post #3077 of 4273 Old 06-08-2013, 07:30 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Not for awhile....in fact I don't know when I'll hit the trails again, after Moab Illinois and Indiana are kind of a let down.
Maybe I'll just head west again.
Jeffro06 is offline
post #3078 of 4273 Old 06-08-2013, 08:56 PM
dandaman99701
Thanks.... I'll have to give your build a looksee (link?). I am running the stock rear tb, with the relocation bracket that came with the OME lift.
Hmmm, I don't remember my lift coming with a rear tb bracket but then again I had someone else install it. No link to my build since I don't have a build thread. My specs should be in my profile. Maybe i will hold off on the rear Currie tb just to save a bit of dough for now. Thanks for the response.
dandaman99701 is offline
post #3079 of 4273 Old 06-15-2013, 05:20 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Jeep is acting a bit weird when I start it. It clicks as if the battery is dead, I turn the key again and it starts...a bit sluggish, but starts. But if I turn it off and start it right back up it starts fine. I'm thinking maybe its the battery, but I'm not sure...could be the starter, don't really know.
Jeffro06 is offline
post #3080 of 4273 Old 06-15-2013, 06:08 PM
LeadDog
It's because you won't wheel it until your next trip to Moab. It wants some love!
LeadDog is offline
post #3081 of 4273 Old 06-15-2013, 07:03 PM Thread Starter
Jeffro06
Jeffro06's Avatar
I wish it was that simple.
Jeffro06 is offline
post #3082 of 4273 Old 06-15-2013, 07:29 PM
my98tj
Have you turned the key on and let the fuel pump kick on without starting, turn the key off and back on and try to start it on the second time? May be fuel pressure regulator or a leaky injector.
Can anyone tell me how the flux capacitor is used to facilitate time travel???
my98tj is offline
post #3083 of 4273 Old 06-16-2013, 07:27 AM
Holaday
Stop in to Missouri some time. I think you would enjoy some of the parks here
Holaday is offline
post #3084 of 4273 Old 06-16-2013, 07:53 AM
Moabrubi
I feel sorry for you guys who only have off road parks. We have a few parks here but they are pretty boring in comparison.
Moabrubi is offline
post #3085 of 4273 Old 06-16-2013, 03:33 PM
aw12345
So Cali has plenty of stuff to entertain on, just in summer the choices get a bit slim, unless you like night wheelin.
I for one still thoroughly enjoy driving the bunny trails I first cut my teeth on. Moab, AZ, CO and NM trails just add to the variety of wheelin.
Good part of Moab trails fall pretty much in the bunny trail category, but are a blast to put around on anyway
By the way as far as your Jeep starting problem, clean and tighten the battery cables on both ends and have the battery tested, should resolve your problem
aw12345 is offline
post #3086 of 4273 Old 06-16-2013, 08:18 PM Thread Starter
Jeffro06
Jeffro06's Avatar
As far as my starting issue goes, I found a moment to pop the hood to check the battery cables....the positive cable was super loose, so I made quick work of that, started it...without the clicking, and took it for a ride. Hopefully it was just the loose cable, not giving it the juice to start, and possibly not letting it charge correctly too.....I guess we'll see. If nothing else this give me a reason (excuse) to buy a DieHard Platinum.
And as for only having off road parks....it sucks, big time. I'll correct that in 6 years.
Jeffro06 is offline
post #3087 of 4273 Old 06-16-2013, 08:54 PM
aw12345
Retirement in 6 years? Gonna move to Florida
aw12345 is offline
post #3088 of 4273 Old 06-17-2013, 05:34 AM Thread Starter
Jeffro06
Jeffro06's Avatar
I won't be old enough for Florida.
Jeffro06 is offline
post #3089 of 4273 Old 06-17-2013, 04:01 PM
dandaman99701
Cocked Joints
[QUOTE=Jeffro06;13174699]I lied, I went back out and found it was off center by about a 1/4 of inch. I centered the axle, centered the steering wheel, and the CA's are no longer cocked.
Hopefully I'll be able to break that rear bolt free, soon, but not today, I'm beat. [/QUOTE
Afternoon Jeffro, So I started my control arm install. Got both front lowers on and had the same situation that you did. Both are cocked. Could you explain a bit more how you went about centering the axle to straighten the arms. I set them at stock length like you did. Just trying to wing this on my own so any advice is appreciated. Also, for the rear lowers, the arms should be the same style as used up front on the lowers correct?
post #3090 of 4273 Old 06-17-2013, 05:28 PM Thread Starter
Jeffro06
Jeffro06's Avatar
The "crooked" control arms are nothing to worry about.... they won't center themselves after they move (it was new to me, what did I know). Just make sure the control arms that are supposed to be the same length are.
As for centering the axle I unhooked the track bar and jumped up and down on the bumper... really, which got it close. I measured from a common point on each side of the frame to a common spot on each tire. To fine tune it I turned the wheel, which will move the axle when the track bar is unhooked. Once centered I bolted up the track bar.
Jeffro06 is offline
badlands , indyorv , jeeps gone wild , photography , rokmen
My Rubicon DaveFL Jeep Builds 7 02-02-2015 02:07 PM
Black Rubicon with flat black Rubicon decals MoparToYou Jeep Picture Requests 16 03-12-2012 06:53 AM
TJ (Rocky Mountain Edition) on Rubicon Wheels or Rubicon with Rocky Mtn. Interior MichaelK23 Jeep Picture Requests 19 01-03-2011 09:08 PM
My New Rubicon jeepmojo01 Jeep Builds 9 08-10-2009 07:44 AM
My New Rubicon Zacb262 Jeep Builds 5 06-02-2009 10:11 PM
