Jeffro06's Rubicon - Page 105 - JeepForum.com
post #1561 of 4273 Old 03-09-2012, 08:47 PM Thread Starter
Jeffro06
Jeffro06's Avatar
The housing JJ's do make a nice difference, especially considering that when the stock bushings wear down, it's a major DW culprit. Really easy job.....come down to Indy and one of us could do it for you.
I'll keep that in mind. Hopefully I'll find the time to get the front uppers on this weekend.
Jeffro06 is offline
post #1562 of 4273 Old 03-10-2012, 09:14 AM Thread Starter
Jeffro06
Jeffro06's Avatar
Jeeps suck! Or at least the factory bolts they use do. Those stupid front upper control arm bolts with the flange on them suck, suck, suck. They spin and spin. I can't get vise grips on them, nor can I get a c-clamp to hold them.
I'm done screwing with this stupid *** jeep. I hate it, I hate it, I hate it.
(Ok, not really, but I'm not going to kill myself trying to replace the front upper CA's)
Jeffro06 is offline
post #1563 of 4273 Old 03-10-2012, 09:28 AM
Imped
Imped's Avatar
Calm down.....go get a mid-size allen key, like 3/16" or 1/8" (needs to be big enough to not just slip through, you want to have to put a bit of effort into it) and jam it through the flange. You'll see what I'm talking about once you mess with it for a couple minutes--the key will catch and prevent the flange from spinning. I've used that trick on a bunch of them--always works.
OlllllllO
IndyORV
Imped is online now
post #1564 of 4273 Old 03-10-2012, 09:35 AM Thread Starter
Jeffro06
Jeffro06's Avatar
I haven't thrown anything yet... I was trying to think of something to jam in there, didn't think of that, I'll give it a try in a bit.
Jeffro06 is offline
post #1565 of 4273 Old 03-10-2012, 09:51 AM Thread Starter
Jeffro06
Jeffro06's Avatar
So much for that.....the jeep 1, me 0. Game over.
Jeffro06 is offline
post #1566 of 4273 Old 03-10-2012, 10:14 AM
Imped
Imped's Avatar
What's the problem? If you set that allen wrench right, it will jam that flange until the wrench itself breaks.
Otherwise, got a saw zall? Cut the flange off and pull the bolt out. Problem fixed.
OlllllllO
IndyORV
Imped is online now
post #1567 of 4273 Old 03-10-2012, 12:49 PM Thread Starter
Jeffro06
Jeffro06's Avatar
The allen wrench would catch, but then the flange would slip right over it. Maybe I did it wrong, I don't know. I do know the driver side looks even harder to deal with, so.....
I moved on to the Currectlync....it's on, and the jeep drives fine. I'll have the alignment checked, but it's driving straight...as near as I can tell, thanks to the 40 mph winds we're having.
I'll give the front upper CA's a rest, think about it, then decide what I want to do.
Jeffro06 is offline
post #1568 of 4273 Old 03-10-2012, 02:34 PM Thread Starter
Jeffro06
Jeffro06's Avatar
All the lower CA's are on, as are the rear upper CA's. The Currectlyn steering is on. I still have to figure out the front upper CA's, but so far everything seems to be working fine.
Just touching the bump stop, no fender rub or track bar rub.
Jeffro06 is offline
post #1569 of 4273 Old 03-10-2012, 03:38 PM Thread Starter
Jeffro06
Jeffro06's Avatar
One last upper CA update for the day: I managed to free the front passenger side bolts, frame and axle ends. However I can't get any leverage on the front driver side axle bolt. The frame end bolt is free. I may need to get an impact wrench on the axle end bolt, but I've reached my limit for the day. Time to get cleaned up, sit in my chair and enjoy the Daytona Supercross Race.
I did notice one minor "screw up" I did with the tie rod....the ends should be swapped, but the zerks don't hit anything and I can get to them to grease them, so who really cares?
Edit: I cared. I took the time, about 20 minutes, to flip the tie rod ends to where they are supposed to be. It was quick, easy and now the zerks are where they need to be to get to them for greasing, and I don't have to worry about the zerks hitting anything when the wheels are turned.
Jeffro06 is offline
post #1570 of 4273 Old 03-10-2012, 05:33 PM Thread Starter
Jeffro06
Jeffro06's Avatar
I took my dog for a ride, did a little articulating of the jeep while I was out. It sounds as though I have the slightest bit of something hitting something as my rear wheels go up and over a large-ish hump. I wonder if it's the track bar hitting the diff.
Jeffro06 is offline
post #1571 of 4273 Old 03-10-2012, 07:53 PM Thread Starter
Jeffro06
Jeffro06's Avatar
My Mods.
Well since the blogs were taken away () I'll try to list the mods on my Jeep:
Old Man Emu 2" HD lift, with OME steering stabilizer
Currie Anti-Rock front sway bar
LT265/75R16 Good Year MRT/Kevlars on stock Moabs
LoD Extreme Duty rear bumper
Rokmen Mercenary front bumper/Superwinch EPi 9.0 w/synthetic line
Rokmen Mercenary Sliders w/internal bracing
Skidrow engine skid
Skidrow radiator skid and Skidrow steering box skid
Cobra 75 WX ST 40 Channel CB
Rokmen 1" billet spacers up front, to level it out
Rokmen adjustable control arms (uppers and lowers)
Currie Johnny Joint adjustable front track bar
Currie Currectlync tie rod and drag link
Rampage soft top
Custom rear storage box w/Hi-Lift and fire extinguisher
MV-50 on board air compressor
Blue Monkey Motorsports SpeedoHealer
Silver Star headlights
Full set of Husky liners
Jeffro06 is offline
post #1572 of 4273 Old 03-11-2012, 07:11 AM
Sgt.Fuzz
Que?
My build:
Sgt.Fuzz is offline
post #1573 of 4273 Old 03-11-2012, 08:47 AM Thread Starter
Jeffro06
Jeffro06's Avatar
Originally Posted by Sgt.Fuzz View Post
Que?
I used the JF blog to keep track of maintenance I did, since it was easier to find than within my build. Turns out the blogs were shut down....they were spam magnets apparently. I just wish I had known they were being shut down before hand.
Jeffro06 is offline
post #1574 of 4273 Old 03-11-2012, 10:11 AM
Matt Graham
Matt Graham's Avatar
What's up Jeffro...remember me? The jeep looks great. I'm hoping to buy something exactly like what you have later this fall. Can't wait!
Instagram:
Twitter:
Youtube:
My Build Thread:
F-250 7.3 Tow Rig Build Thread:
Matt Graham is offline
post #1575 of 4273 Old 03-11-2012, 10:38 AM
Sgt.Fuzz
Hmm, I never knew such a critter existed.....or used to. Get the last of the CA's installed?
My build:
Sgt.Fuzz is offline
badlands , indyorv , jeeps gone wild , photography , rokmen
My Rubicon DaveFL Jeep Builds 7 02-02-2015 02:07 PM
Black Rubicon with flat black Rubicon decals MoparToYou Jeep Picture Requests 16 03-12-2012 06:53 AM
TJ (Rocky Mountain Edition) on Rubicon Wheels or Rubicon with Rocky Mtn. Interior MichaelK23 Jeep Picture Requests 19 01-03-2011 09:08 PM
My New Rubicon jeepmojo01 Jeep Builds 9 08-10-2009 07:44 AM
My New Rubicon Zacb262 Jeep Builds 5 06-02-2009 10:11 PM
