Jeffro06's Rubicon - Page 103 - JeepForum.com
post #1531 of 4273 Old 03-04-2012, 12:13 PM
Imped
Imped's Avatar
You need leverage. Breaker bar is good.
OlllllllO
IndyORV
Imped is offline
post #1532 of 4273 Old 03-04-2012, 12:15 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Tried one......not a real long one though.
Jeffro06 is offline
post #1533 of 4273 Old 03-04-2012, 03:37 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Ok, I've got three out of four lowers on. I can't get the DS rear lower off. The front bolt will break free but the rear bolt fought a good fight and won, for now. I need more leverage and just can't get it with the jeep on the ground. I'll talk to a few people tomorrow and see what I can work out.
The front two lowers aren't sitting straight, both are cocked to one side, the same side....normal? Not normal? I set the new CA's to the same length as the old ones, the bolts slid right in, no forcing at all.
It drives fine, better than it did actually, it feels more responsive. I flexed it and nothing broke, so that's a plus.
But for today I'm done.
Jeffro06 is offline
post #1534 of 4273 Old 03-04-2012, 03:38 PM
Imped
Imped's Avatar
If they're cocked to one side, the axle isn't centered.
OlllllllO
IndyORV
Imped is offline
post #1535 of 4273 Old 03-04-2012, 03:43 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Alrighty then, I guess I should wait until all 8 are on then center it.
Jeffro06 is offline
post #1536 of 4273 Old 03-04-2012, 03:46 PM
Imped
Imped's Avatar
I'd center it before dropping the uppers in. Regardless of the order of operations, ending up with a centered axle that's square to the frame is the key.
OlllllllO
IndyORV
Imped is offline
post #1537 of 4273 Old 03-04-2012, 04:39 PM Thread Starter
Jeffro06
Jeffro06's Avatar
I lied, I went back out and found it was off center by about a 1/4 of inch. I centered the axle, centered the steering wheel, and the CA's are no longer cocked.
Hopefully I'll be able to break that rear bolt free, soon, but not today, I'm beat.
Jeffro06 is offline
post #1538 of 4273 Old 03-05-2012, 06:16 AM Thread Starter
Jeffro06
Jeffro06's Avatar
My Currectlync steering will be here today.
I'm going to try and find someone who'll bust that stupid rear CA bolt free. The upper CA's are going to have to wait until at least next weekend.
Jeffro06 is offline
post #1539 of 4273 Old 03-05-2012, 07:09 AM
JJeeper09
Lucky. HF has some cheap electric impacts, the are around 35 bucks and mine works great! Check it out it will save some time for future adjustments.
JJeeper09 is offline
post #1540 of 4273 Old 03-05-2012, 08:55 AM Thread Starter
Jeffro06
Jeffro06's Avatar
My local jeep dealer is going to break the bolt free....pro bono. Should be able to get the control arm on tonight.
Jeffro06 is offline
post #1541 of 4273 Old 03-05-2012, 01:17 PM Thread Starter
Jeffro06
Jeffro06's Avatar
My Currie Currectlync was waiting for me, on my porch, when I went home for lunch...that thing is pure beef.
The last bolt on my lower CA's needed to be heated up, but it's loose now. I'll see if I can't get it swapped out tonight.
Looks like I might be going snowmobiling up north this weekend....weather permitting, so the jeep may have to go on hold.
Jeffro06 is offline
post #1542 of 4273 Old 03-05-2012, 04:59 PM
ksilovich
You better hope that this 60* warm front doesn't melt it all.
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #1543 of 4273 Old 03-05-2012, 05:01 PM Thread Starter
Jeffro06
Jeffro06's Avatar
It's way up north, almost Michigan. If it melts we might just switch to atv's..
Jeffro06 is offline
post #1544 of 4273 Old 03-05-2012, 05:05 PM Thread Starter
Jeffro06
Jeffro06's Avatar
I got that last lower CA on, thankfully.
Here's a peek:
Flexing it:
The Currie Currectlync:
Jeffro06 is offline
post #1545 of 4273 Old 03-06-2012, 07:26 AM
Sobie
Bolt-on Maniac
Sobie's Avatar
Nice. When you install the steering make sure you have a mallet. I didn't need a tie rod puller. I just hit the casting a few times while pulling down and they popped right out. Loosen the nut but leave the nut on with a few threads to "catch" it.
USAF
Sobie is offline
badlands , indyorv , jeeps gone wild , photography , rokmen
My Rubicon DaveFL Jeep Builds 7 02-02-2015 02:07 PM
Black Rubicon with flat black Rubicon decals MoparToYou Jeep Picture Requests 16 03-12-2012 06:53 AM
TJ (Rocky Mountain Edition) on Rubicon Wheels or Rubicon with Rocky Mtn. Interior MichaelK23 Jeep Picture Requests 19 01-03-2011 09:08 PM
My New Rubicon jeepmojo01 Jeep Builds 9 08-10-2009 07:44 AM
My New Rubicon Zacb262 Jeep Builds 5 06-02-2009 10:11 PM
