Jeffro's ride ... - Page 7 - JeepForum.com
post #91 of 887 Old 01-14-2008, 05:37 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Originally Posted by Jeffro95
My SYE / CV install is all done. I had to wait an extra week to get some 8-degree shims, as the 4-degree shims allowed vibration.
Here is what it looks like now...
It didn't go without a hitch though. The new shims came with new centering pins. With those were some little washers...one for each pin.
First step of the day was to remove the transfer case drop. Then we, my daughter's boyfriend Josh, jacked up the rear end, supported the springs with jack stands, and started the swap.
The fisrt problem of the day came when the pins that RE sent with the shims was too big to fit the predrilled hole.... Thankfully a buddy of mines dad owns a suspension and allignment shop 2-minutes from my house. Even more thankfully....his dad was there at 10am on a Saturday. He drilled out the holes to their proper size!!
We returned to my garage and in went the shims. We were trying to figure out the whole pin, washer, thing. It didn't seem the the washers were needed, but we tried one. Guess what.....not needed. As Josh started to remove the pin the threads on it stripped, about half way down! I used a hacksaw to cut the pin, just above the the stripped nut. Josh was able to rethread the bolt onto the pin! We were back on track!
From there everything bolted up just fine. We took her out for a test drive and all is well, no more vibes!!!
Once that was all done I ordered 5 new 33x12.50 R15 TrXus MT's!! Hopefully they will be here, and mounted in time for the Badlands on the 28th!!
Awesome thread, it's been fun watching this rig get built up. It looks fantastic.
Aren't the shims supposed to raise the yoke up? (meaning front point up more toward TC)??
The pic looks like you've got them lowering the yoke.
Also looks like you have the military wrap on the frame side of the spring, not the shackle side. Do those springs have military wrap on both sides?
- Ernie
Richmond88yj is offline
post #92 of 887 Old 01-14-2008, 06:30 PM
93jeepREDSOX
the shims are on the right way, the thick end is pointing toward the front of the jeep, and i think the leafs are on right also.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #93 of 887 Old 01-14-2008, 06:58 PM
coolhand
coolhand's Avatar
Hey Jeffro95
How do you like those tires in the snow?
I live in SOCAL right now and will be moving to KY in a couple of months. I got the same ones and am thinking about replacing them with some 35's in a couple of months. But and don't want to get them if they totaly suck in the snow.
"The Empty Pocket Warriors." Member #2
"92 YJ, 3.5" BDS. Custom 1.5" lift shackles, 2" BL, Ford 8.8 W/Trac-loc & 33" TrXus MT's (for now).
"No one ever accused the Wrangler of being comfortable, quiet, or practical. No one ever called it boring, either. The Wrangler is a two-door toy, ... great fun to drive with the top down." -- AUTOMOBILE MAGAZINE, March 1995.
coolhand is offline
post #94 of 887 Old 01-14-2008, 07:57 PM
Richmond88yj
Eat, Sleep, Jeep
Thanks, was kinda hard to see on my laptop screen. Now that I'm home and can see, I feel like a tard for asking.
- Ernie
post #95 of 887 Old 01-15-2008, 07:11 AM Thread Starter
Jeffro06
Jeffro06's Avatar
Originally Posted by coolhand
Hey Jeffro95
I'm very happy with the performance of the TrXus tires. I've had them in deep snow, hard packed, even ice covered roads. They do great.
Jeffro06 is offline
post #96 of 887 Old 01-15-2008, 07:13 AM Thread Starter
Jeffro06
Jeffro06's Avatar
Yep, shims are on the right way....thick end to the front, as are the leafs....military wrap to the fixed position.
Jeffro06 is offline
post #97 of 887 Old 01-15-2008, 12:37 PM
coolhand
coolhand's Avatar
Thanks, that confirms it fo me. I'm going to get anouther set.
Maybe in the fall I'll see you at Attica.
coolhand is offline
post #98 of 887 Old 02-23-2008, 06:01 PM Thread Starter
Jeffro06
Jeffro06's Avatar
I've had my M.O.R.E. 5/8" boomerang shackles since 11/26/07...and today I finally put them on. The weather was nice...mid 30's, and sunny, this inspired me to get off my duff and get 'er done!
The back and............................................... front.
Driver side.
Passenger side.
Front.
It took me a couple of hours. I need a bigger garage. Doing this in a one car garage, with just enough room to get around the rig was kind of a pain. I even had to unhook the garage door opener to get the door opened high enough to get it and out.
I took it for a spin and could tell the difference, ride wise, instantly. Bumps that have sent spine jarring shock through me, every since I had the lift installed, were now almost non-exisitant. I flexed it a bit, and could tell the difference too...no pictures of that yet. I will need to get the steering wheel re-centered......again.
If you have the RE 4" lift, get the M.O.R.E. 5/8" boomerang shackles...you won't regret it. These suckers are way more beefy than the stock shackles too.
What to do next?
Jeffro06 is offline
post #99 of 887 Old 02-23-2008, 06:33 PM
BlackRhino
BlackRhino's Avatar
Your Jeep is looking great!
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #100 of 887 Old 02-23-2008, 06:44 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Thanks. I've changed quite a bit since I bought it. I'm thinking about beefing up the rear end. Super 35 is the easiest option..for me, but I haven't decided yet. I want a rear locker, so I'll have to do something, strenght wise, to accomplish that. Cost and ease of install, will be the deciding factors here.
Jeffro06 is offline
post #101 of 887 Old 02-24-2008, 12:33 AM
Samgler
Samgler's Avatar
Lookin good there!
________
l_l_,[____],
l---L-- []lllllll[]-
(o)_) (o)_)=o)_)
^^^^^^^^^^^ 1995 YJ Sahara, 4.0L 5spd
Rubicon Express 4.5 extreme duty lift, SYE, Tom Woods custom drive shaft. Mickey Thompson MTZ 33x12.5R15 on d windows.
Samgler is offline
post #102 of 887 Old 02-24-2008, 07:38 AM
--chris--
--chris--'s Avatar
Nice jeep Jeffro!
--chris-- is offline
post #103 of 887 Old 02-24-2008, 02:54 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Originally Posted by Samgler View Post
Lookin good there!
Originally Posted by cheap5.0 View Post
Nice jeep Jeffro!
Thanks guys. I'm trying to convince the wife it would look even better with a nice Warn winch up front.
Jeffro06 is offline
post #104 of 887 Old 02-28-2008, 08:42 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Well it's been almost a week with the boom's installed. The ride is smoother, the flex is better, but bump steer has appeared. It's not bad, but there wasn't any before. I don't have a dropped pitman arm, so I'm thinking it's time to get one. My steering wheel is taking a hard right, so I figure I may as well get the pitman arm, then adjust that.
My wife even says the Jeep rides better now.
Jeffro06 is offline
post #105 of 887 Old 02-28-2008, 09:32 PM
bmx_hb_guy
ayyy what kinda flares are u running ......are they stock?
93 wrangler 2.5l, 2in lift shackels, 31's, eagle alloy 186,and a flowmaster 44
98 zj 4.0 straight 6, 4in f<r lift, adj. trak bars, rustys sway bar quik discos, skyjacker shocks, rancho steering stabalizer, 32x11.50 daytons, straight piped, 2 12" pioneers,
I DO ALL MY OWN WORK!
AND YES IM 17 BUT THIS JEEP AINT DADDYS MONEY!
bmx_hb_guy is offline
Closed Thread
my 1st ride kale2s Jeep Builds 72 07-12-2010 09:21 AM
'79 CJ and my first ride..... Matt in TN Jeep Builds 6 10-24-2005 05:45 PM
My Ride Puppet Racing Jeep Builds 11 06-22-2005 05:22 PM
Little Joy Ride. Green_Machine Jeep Builds 13 04-18-2005 03:07 AM
My ride! D4FS4 Jeep Builds 2 09-11-2003 07:30 AM
