Jeffro's ride ... - Page 6 - JeepForum.com
post #76 of 887 Old 11-08-2007, 05:52 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Nothing new today....but I'm considering MORE boomerang shackles...front and rear.
Jeffro06 is offline
post #77 of 887 Old 11-20-2007, 10:07 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Just a little update.
My 5/8" Boomerangs are on the way. I've had no problems with the sye/cv. Love the TrXus tires. They worked good on the trail, road nice on the highway, and are balanced. The only negative so far is they are a bit hard for the first few miles on cold mornings. They soon warm up and the ride smooths out...as much as it can in a Jeep. The MORE boomerangs will probably be the last addition until spring.... I want sooooooo much more.
Better check my lottery ticket.
Jeffro06 is offline
post #78 of 887 Old 11-26-2007, 10:42 AM Thread Starter
Jeffro06
Jeffro06's Avatar
My M.O.R.E. boomerangs arrived today!! They sure are beefy. I'll post some pic's when the change over is complete.
Jeffro06 is offline
post #79 of 887 Old 12-18-2007, 07:24 PM
Stout95YJ
bump, got them shackles on?
Stout95YJ is offline
post #80 of 887 Old 12-18-2007, 08:41 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I just bought some MORE boomerang shackles for the front. I've been going through in my head how I'm going to install them without removing the springs. how did you install them, if you did already?
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #81 of 887 Old 12-18-2007, 10:06 PM
Ryanpowell167
When i did my booms, i just jacked up the front frame so it took all the pressure off the axle. Then i unbolted them and just had the springs stickin out. Then i bolted up the new ones and lowered the springs down into them....
Black 1992 wrangler, 40" creepy crawlers, d60/14b 350tbi/700r4/np205, spring over on 4" springs.
2011 Ford F-150 Raptor, whipple supercharged...
Ryanpowell167 is offline
post #82 of 887 Old 12-19-2007, 04:30 PM
Mr.B
Mr.B's Avatar
Thanks for the reply. But let me ask. Did you jack up the frame so the tires were off the ground? And then wouldn't you also have to jack up the axle a little to take weight off the springs?
Ham license:
Everyone is Welcome
Mr.B is online now
post #83 of 887 Old 12-19-2007, 05:34 PM Thread Starter
Jeffro06
Jeffro06's Avatar
NOPE! I've been busy with work and all...trying to get caught up before the end of this week, at which time I start a vacation. I'll be off until after the new year, and I hope to get them on then.
I will post some photos afterwards.
It kills me to see them sitting in the box everytime I walk through the dining room....which by the way the wife keeps tellling me to get them out of.
Jeffro06 is offline
post #84 of 887 Old 12-19-2007, 08:32 PM
danielp
jeffro love the jeep im hoping to have my jeep setup like you have it now within the next 2-3mos. question. what size tires were you running before you got the 33 trxus? if anything ima be running a 4" lift on 31"s untill i save some more for the 33s
/l, [____],
l---L []lllllll[]-
()_) ()_)--o-)_)
95yj 4 happy squirrels going strong
31" BFG AT/KO
stock susp.
danielp is offline
post #85 of 887 Old 12-19-2007, 08:34 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Thank you. I had 32x11.5's prior to the 33's.
Jeffro06 is offline
post #86 of 887 Old 12-20-2007, 10:51 AM
jsahara24
looks good man, I was wondering where you bought those 8* shims? Thanks, Jason
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #87 of 887 Old 12-20-2007, 01:29 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Right here in the vendor section, from Fullsizexj.
Jeffro06 is offline
post #88 of 887 Old 01-14-2008, 12:30 PM
93jeepREDSOX
You said that you put in the 8 degree shims for you rear right, how did you go about doing them, I have ordered them and wanted to get some ideas on how to go about doing it.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #89 of 887 Old 01-14-2008, 03:43 PM Thread Starter
Jeffro06
Jeffro06's Avatar
It's pretty straight forward. You need a floor jack and some jack stands. And of course the right wrenches... Once you loosen up the u-bolts holding the springs on the axle, you slip out the old shims and slip in the new.
Well it wasn't quite that easy...turns out the hole in the new shims wasn't as big as the centering pin. A quick trip to a buddies shop, to use his drill press, solved that problem. I just needed to take the old shim with so we knew what size the hole should be.
After replacing the shims it was as simple as tightening everything back up. I'm not a grease monkey by any means, and this was very easy. Not much to it at all.
Now I have GOT to find time to put on my M.O.R.E. Boomerang shackles!!! I've had them for like forever!!
Jeffro06 is offline
post #90 of 887 Old 01-14-2008, 03:55 PM
93jeepREDSOX
Did you take the u-bolts completly off or just losen them up enough to get the shim out.
The build thread
Closed Thread
my 1st ride kale2s Jeep Builds 72 07-12-2010 08:21 AM
'79 CJ and my first ride..... Matt in TN Jeep Builds 6 10-24-2005 04:45 PM
My Ride Puppet Racing Jeep Builds 11 06-22-2005 04:22 PM
Little Joy Ride. Green_Machine Jeep Builds 13 04-18-2005 02:07 AM
My ride! D4FS4 Jeep Builds 2 09-11-2003 06:30 AM
