Jeffro's ride ... - Page 5 - JeepForum.com
post #61 of 887 Old 10-19-2007, 06:16 AM Thread Starter
Jeffro06
Jeffro06's Avatar
Originally Posted by I<3Jeeps
I've been wanting to get rid of my back seat bench and put seats in like yours that you have in your back seat. How'd you do it and where'd you buy em?
It took a lot of searching, and custom fabrication, to get the new bucket seats installed in the back. What you have to do is have twin girls, go to Wal-Mart, head to the baby section. Once there look for the bright pink seats....yes pink....they will look just like this...
Now put them in the back seat, side by side, take the seat belts and lace them trough the upper eyelets, squeeze your hand down between the two seats, and secure the buckles.
Oh, one more thing....take them out when the twins aren't with you, or you'll look like a dork!
Jeffro06 is offline
post #62 of 887 Old 10-20-2007, 03:55 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Originally Posted by Jeffro95
My SYE / CV install is all done. I had to wait an extra week to get some 8-degree shims, as the 4-degree shims allowed vibration.
Here is what it looks like now...
It didn't go without a hitch though. The new shims came with new centering pins. With those were some little washers...one for each pin.
First step of the day was to remove the transfer case drop. Then we, my daughter's boyfriend Josh, jacked up the rear end, supported the springs with jack stands, and started the swap.
The fisrt problem of the day came when the pins that RE sent with the shims was too big to fit the predrilled hole.... Thankfully a buddy of mines dad owns a suspension and allignment shop 2-minutes from my house. Even more thankfully....his dad was there at 10am on a Saturday. He drilled out the holes to their proper size!!
We returned to my garage and in went the shims. We were trying to figure out the whole pin, washer, thing. It didn't seem the the washers were needed, but we tried one. Guess what.....not needed. As Josh started to remove the pin the threads on it stripped, about half way down! I used a hacksaw to cut the pin, just above the the stripped nut. Josh was able to rethread the bolt onto the pin! We were back on track!
From there everything bolted up just fine. We took her out for a test drive and all is well, no more vibes!!!
Once that was all done I ordered 5 new 33x12.50 R15 TrXus MT's!! Hopefully they will be here, and mounted in time for the Badlands on the 28th!!
Jeffro06 is offline
post #63 of 887 Old 10-20-2007, 06:24 PM
eche981
dig the pink
do they make a okoly seat cover for that model?
_______
l l_[____],
IóL---{[]ll[]}-
(0)_)(0)_)-(o)_) 88 hardtop 258 (Strong motor) 3 in lift, 1 in body , 32X12.50, webber, nutter, HEI upgarde and needs paint.
eche981 is offline
post #64 of 887 Old 10-23-2007, 04:12 PM Thread Starter
Jeffro06
Jeffro06's Avatar
I'm not sure, I'll have to check....maybe I can find some 5-point harnesses for them too...in pink of course!
Jeffro06 is offline
post #65 of 887 Old 10-23-2007, 04:33 PM
ChrisYJ - Italy
Jeffro, be very careful , that driveshaft is too long for your setup , it looks completely stuffed in at ride height, if compressed it will press on your tcase, eventually destroyn'it and- or bending the new ds.
Triple measure everything before driving it really, to me it looks just wrong like that! Maybe it's just the pic, but..!!!!!
Greetings from Italy!!!!
ChrisYJ - Italy is offline
post #66 of 887 Old 10-23-2007, 04:58 PM Thread Starter
Jeffro06
Jeffro06's Avatar
That wouldn't be good. I'm not sure if it's the angle of the picture or not. Anyone have pictures of theirs they could share? I'd hate to kill the entire rig! There is a bit more space than it appears there, so the angle has something to do with it I guess...but still. So photos?
Jeffro06 is offline
post #67 of 887 Old 10-25-2007, 07:38 PM
Stout95YJ
i have the same lift as you, could i just lengthen my driveshaft and use some 8* shims?
Stout95YJ is offline
post #68 of 887 Old 10-25-2007, 09:03 PM Thread Starter
Jeffro06
Jeffro06's Avatar
That I can't answer....just don't now for sure. Putting in the 8* shims and trying it would only run you about $35, and some time, and would be one way to know for sure.
Jeffro06 is offline
post #69 of 887 Old 10-26-2007, 10:48 AM
richmond1273
i agree with chris yj, there doesn't look to be any room for the driveshaft to compress when the axle articulates. even if some of it is the angle, i would think you would be able to see some splines. otherwise nice looking jeep!
1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears
3" Rough Country suspension 33x12.50 Mastercraft MT
2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears
richmond1273 is offline
post #70 of 887 Old 10-26-2007, 04:58 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Two shops, and a compression test....all seems to be fine. Sure it looks close, but I'd probably have to race the Baja 1000 for it to do go bad. I still might take an inch off, just for some added piece of mind.
Jeffro06 is offline
post #71 of 887 Old 10-26-2007, 05:05 PM Thread Starter
Jeffro06
Jeffro06's Avatar
New tread!
Well my TrXus 33x12.5 R15's arrived today. I had them mounted today too.
Here's how she looks now.....
I still have to go out and hit some highway speeds to see how well they balanced, as I've read they are a bit hard to tame. It takes a little more time for the rig to come to a stop now. Noticed that when an idiot slammed on his brakes, right in front of me, just two minutes after I left the shop.
I like the way she looks, much better now.
Jeffro06 is offline
post #72 of 887 Old 10-26-2007, 10:15 PM
93jeepREDSOX
I have the same tires and i think that they are awsome. They are pretty quiet and they have a great bite off road. Good tire in my opinion.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #73 of 887 Old 11-01-2007, 06:00 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Well after making the 8-hour round trip drive, to the Badlands in Attica Indiana, and spending 5-hours playing on the rocks, in the mud, creek, and on the trails, I'm pretty happy with my tire choice.
They ride well on the road, at 70mph, and made the day of off-roading better than it was with the Mickey Thompson's I had. I've read that the TrXus radials are hard to balance, mine are fine.
To sum it up...they look good, ride good, grip well, clean out well, handled in the rain @ highway speeds well, didn't slip in the rain during acceleration....now all I need is some snow!
Jeffro06 is offline
post #74 of 887 Old 11-01-2007, 07:14 PM
black2door
black2door's Avatar
1994 XJ Cherokee
That looks awesome. Really nice jeep
black2door is offline
post #75 of 887 Old 11-03-2007, 06:04 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Thanks, I've been tweaking it since I bought it...trying to make it MINE.
Jeffro06 is offline
Closed Thread
my 1st ride kale2s Jeep Builds 72 07-12-2010 08:21 AM
'79 CJ and my first ride..... Matt in TN Jeep Builds 6 10-24-2005 04:45 PM
My Ride Puppet Racing Jeep Builds 11 06-22-2005 04:22 PM
Little Joy Ride. Green_Machine Jeep Builds 13 04-18-2005 02:07 AM
My ride! D4FS4 Jeep Builds 2 09-11-2003 06:30 AM
