Jeffery 2.0 - some assembly required - Page 56 - JeepForum.com
post #826 of 1411 Old 02-06-2014, 10:09 PM
Jeffro06
Jeffro06's Avatar
Originally Posted by ksilovich View Post
We got a winner. Im starting to draw up a tube chassis. Will be going with jk fiberglass front clip. Plan is to swap everything over so no need to buy anything other then tube .
So how long are you going to be without a Jeep, I mean buggy, this time?
You are a glutton for punishment.
I take it that shop lease thing didn't workout either.
Jeffro06 is offline
post #827 of 1411 Old 02-06-2014, 10:51 PM Thread Starter
ksilovich
Not long I hope. Should be a simple swap over. Maybe a month at the longest. Ill have everything built while still rocking my current jeep.
I got a lead on another one I think.
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #828 of 1411 Old 02-07-2014, 05:35 PM
jforse
Jeffery 2.1 is in the works
Uh oh.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #829 of 1411 Old 02-08-2014, 10:19 PM
Imped
Imped's Avatar
Kevin is playing terrible pool and rocking out to Britney Spears Toxic.
OlllllllO
IndyORV
Imped is offline
post #830 of 1411 Old 02-09-2014, 09:28 AM
Jeffro06
Jeffro06's Avatar
Sounds normal.
Jeffro06 is offline
post #831 of 1411 Old 02-09-2014, 07:00 PM
Jeffro06
Jeffro06's Avatar
So, did you get any work done this weekend, or did you spend all your time singing and dancing to Britney Spears?
Jeffro06 is offline
post #832 of 1411 Old 02-11-2014, 04:04 PM Thread Starter
ksilovich
I was only dancing to try and get Mike to break out the moves.
Yeah we got most of the chassis finished. And should have it done by this Sunday. Going to see if I can bring my plasma table down and start cutting the following weekend.
post #833 of 1411 Old 02-11-2014, 04:40 PM
moomoomage
The things I see people do are amazing I'm only 17 but I can see myself learning and being a jeep guy for life!
moomoomage is offline
post #834 of 1411 Old 02-11-2014, 05:24 PM Thread Starter
ksilovich
Im only 22, and started this jeep when I was 20. Once you start you will never stop.
post #835 of 1411 Old 02-12-2014, 05:36 AM
Danno6102
You guys suck! I guess that shows how valuable experience is. We didn't even get Doug's done. We learned a **** ton though!
Before we started he said you told him to double how long you think it would take. We were cursing your name every time we hit a road block.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #836 of 1411 Old 02-12-2014, 10:48 AM
kellerumps
kellerumps's Avatar
Yup....You put the Voo-Doo Hex on us Kevin. However, I did learn a lot which was my next major objective.
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #837 of 1411 Old 02-12-2014, 11:40 AM Thread Starter
ksilovich
Two things I have learned. If you think it will cost x it will really cost you 2x. And if it should take x amount of time it will be 3x the first time and then 2x for every time after that.
post #838 of 1411 Old 02-12-2014, 12:50 PM
Danno6102
It seems like a solid theory. I started my cage last night & the amount of stupid **** that went on made me want to burn the garage down. From not being able to make the last bend on my A to C pillar tube because I thought it'd be a good idea to try & start bending from the opposite end, to gouging the snot out of the plastic around my steering column moving my dash around.
In the end after about an hour of measuring & moving & grinding & cutting, I got the A to C bars set perfect. Hopefully some good uneventful progress tonight.
Can't wait to see some pics of the U4!
post #839 of 1411 Old 02-12-2014, 01:26 PM Thread Starter
ksilovich
Tip and trick. Add an extra few inches to the a to c middle. Then cut and sleve it at the b piller. That way you can twist the tube and get it to fit easier. And dont let people tell you that you just weakend that joint. Cause thats false. Your adding more material on the inside and you have a weld there. Your actually strong if done right.
post #840 of 1411 Old 02-12-2014, 05:09 PM
JJeeper09
That's how poly a to b pillars are
JJeeper09 is offline
14b , 40's , 4bt , aluminum , boat side , cnc , cummins , custom , d60 , diesel , indyorv , ori struts , plasma , tj
Clutch Assembly Pictures Requested - 1971 CJ5 028346 Jeep Picture Requests 0 06-18-2011 12:20 PM
Some Assembly Required: An 82 CJ7 Strings72 Jeep Builds 5 01-20-2011 06:11 PM
Any pics of Jeeps without spare tire & assembly phyrefighter Jeep Picture Requests 14 03-17-2008 12:29 PM
Factory Soft Top Header & Assembly Varnish Jeep Picture Requests 0 10-13-2006 12:04 PM
