Jeffery 2.0 - some assembly required - Page 53 - JeepForum.com
post #781 of 1411 Old 12-12-2013, 02:49 PM Thread Starter
ksilovich
Originally Posted by try2holdmywheel View Post
Probably a wise choice. Any interest in building something like the GenRight LJ Safari tank? I have a hard time spending $1200 on some welded together aluminum sheet. I know that trivializes it a bit but, the price of gas tanks just seem way too steep.
http://www.genright.com/ProductInfo....7#.UqoSI9JDtJs
These that I am making are going to be around $500 a piece if I make 3 of them. That includes the genright weld on ring (which is custom), the filler, the roll over. All of which are weld on. The material has changed to 0.125 5052 h32 Aluminum.
The amount of design work to make a similar tank for one time would be about the same price. Just a sheet of AL is $310. I could make it, but you wont want to pay what I would charge you. Sorry. Just this simple tank design I have a few hours of modeling time. Id have at least 5-8hrs in ur tank which isnt cheap.
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #782 of 1411 Old 12-13-2013, 08:10 AM
monsonman
monsonman's Avatar
man this is one of the most inspiring builds i have ever seen. well done. i had to re-collect myself every time i remembered you started with this:
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #783 of 1411 Old 12-13-2013, 09:36 AM
roes
1947 CJ2A
Find a new supplier, unless you like paying 30-40% more.
roes is offline
post #784 of 1411 Old 12-13-2013, 09:41 AM Thread Starter
ksilovich
Thats just what the local ALRO quoted me for a single sheet. If you order in bulk the price drops and isnt so bad.
post #785 of 1411 Old 12-13-2013, 09:53 PM Thread Starter
ksilovich
Spent alittle time in solidworks cleaning up my fuel cell. I added the baffles and the filler.
In addition to that I set up some global variables so if I need to make another cell with some other dimensions (Length,Width,Height) or a different angle on the filler All I have to do is change a number in an notepad text file and hit Control+B and it will rebuild the fuel cell for me to the new values.
post #786 of 1411 Old 12-14-2013, 11:10 AM
Jeffro06
Jeffro06's Avatar
That's pretty cool....but you should have been here helping me swap my axle shafts.
Jeffro06 is offline
post #787 of 1411 Old 12-14-2013, 11:55 AM Thread Starter
ksilovich
You have to come down to me. I dont do house calls
post #788 of 1411 Old 12-14-2013, 01:16 PM
Jeffro06
Jeffro06's Avatar
I didn't get an invite....
I did it in my awesome 10x15 "shop".
Jeffro06 is offline
post #789 of 1411 Old 12-14-2013, 08:29 PM Thread Starter
ksilovich
Working away on the KOH Chassis today. Getting some of the little things done.
Odyssey/Diehard P34 Battery
Air Pumper
Upper Links
post #790 of 1411 Old 12-14-2013, 10:09 PM Thread Starter
ksilovich
Last ones for the night.
Copied the Ruff stuff light bar that my friend bought and added some lights to in. Now I can make my one light bar
post #791 of 1411 Old 12-15-2013, 08:40 PM Thread Starter
ksilovich
If anyone even cares, I did a few more items today. Sh*t sure takes awhile.
Fuel Safe fuel cell
Start of the Front Axle - fliped 14b
Rear Axle - flipped 14b
post #792 of 1411 Old 12-15-2013, 08:45 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
So your designing these for what? Browns KOH rig?
Can you transfer from solid works to your table?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #793 of 1411 Old 12-15-2013, 08:54 PM Thread Starter
ksilovich
That is correct. All of this for the Ultra4 car. It will be for his first. Then when I build mine. Plus Ill have a library of parts for when future stuff comes along.
As long as your model them correctly yes they will transfer. You draw them as a sheet metal part. Then you can flatten the part out. Then you can export that as a dxf which will load into the cam software. Nice thing about modeling sheet metal stuff in cad is that it can automatically add the bend allowance in.
post #794 of 1411 Old 12-16-2013, 05:44 PM
LeeMasterGT
Love the models! I just got trained in Solidworks myself. I'd love to be able to do what you do one day.
Build
LeeMasterGT is offline
post #795 of 1411 Old 12-16-2013, 06:11 PM Thread Starter
ksilovich
Its not that hard. I had to teach my self solid works. I took a few classes back in high school, but that was with Autocad Inverter.
14b , 40's , 4bt , aluminum , boat side , cnc , cummins , custom , d60 , diesel , indyorv , ori struts , plasma , tj
Clutch Assembly Pictures Requested - 1971 CJ5 028346 Jeep Picture Requests 0 06-18-2011 11:20 AM
Some Assembly Required: An 82 CJ7 Strings72 Jeep Builds 5 01-20-2011 05:11 PM
Any pics of Jeeps without spare tire & assembly phyrefighter Jeep Picture Requests 14 03-17-2008 11:29 AM
Factory Soft Top Header & Assembly Varnish Jeep Picture Requests 0 10-13-2006 11:04 AM
