Jeffery 2.0 - some assembly required - Page 48 - JeepForum.com
post #706 of 1411 Old 10-31-2013, 12:03 PM
JJeeper09
Pics from the trip?
JJeeper09 is offline
post #707 of 1411 Old 10-31-2013, 12:07 PM
kellerumps
kellerumps's Avatar
I would do Heims no matter what Currie says.
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #708 of 1411 Old 10-31-2013, 01:47 PM Thread Starter
ksilovich
Originally Posted by JJeeper09 View Post
Pics from the trip?
If I get the time to upload some LOL
Why is that Doug. I want to here your reason, and not just because.
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #709 of 1411 Old 10-31-2013, 01:54 PM
Danno6102
Curious as to why you think the roll contributed to the play in the JJ. They get beat on pretty good in normal axle loads.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #710 of 1411 Old 10-31-2013, 01:59 PM Thread Starter
ksilovich
Originally Posted by gtxracer View Post
As for the winch, I picked up a M8000 on craigslist for $250 a year ago. Thing never stalls, won't die, and has pulled other Jeeps when their XXXXX brand winches die. I'm officially a Warn believer now.
As for the tie rod, 7075 should bend back but I would rather see some 1.5 .375 wall DOM or 1.5 .250 wall 4130/4340. Heretic Fab on Pirate sells a kit for $150 but you'll have to weld the inserts.
My current plan for my Eaton HO72/D60 front is 1.5x.375 wall tapped and threaded, possibly heat treat and cryo. Drag link and track bar will be 1.25 .250 wall. 3/4" or 7/8" heims for all steering, double shear everything. Just another two cents for you since you're running 40's and like to wheel it.
I might sell this winch they are sending me. Or throw it on the trailer and get a new one for my jeep.
The tie rod will bend back. NO reason to do steel. I fawked up a 1.5 x 0.25 DOM tie rod on my last jeep. Ill stick with AL. Plus AL solid AL is stronger end that DOM, plus you save ALOT of weight. Which I really need to do. I dont want to be any heavier. I dont need to buy no kits. A buddy owns a machine shop. All I have to do is go down to Indy for a weekend and make a new AL tierod 6" longer to remove the week chevy TRE.
The reason my 7075 tie rod bent, was because I was hauling *** in a wet rock garden and nailed the tierod right on a rock. Stopped me dead cold.
Steering will all be 7/8" heims like my track bar currently.
My new set up will be similar to what artec has on the market. The only difference is, I am designing and milling out the arms.
They were fine before that wheeling trip. Plus all the damage I had done was up front in the roll. It had enough force to tweak one of my lower link brackets. Plus that is when I bent my TRE.
post #711 of 1411 Old 10-31-2013, 02:00 PM
kellerumps
kellerumps's Avatar
My reason is pretty simple. Every hardcore rig I have ever looked at has them. When I redo my front, I'm going with Heims and I dont wheel 1/2 as hard as you do(Yet). I dont believe in re-inventing the wheel.
I think JJ's have a place but you are running 40's, with Huge Torque, and a heavy *** rig. Sorry...I think you are maxing them out.
For what you have and want, I would trust a Ruff-Stuff Heim over a JJ any day of week and twice on a weekend. Just my $.02.
Member of:
post #712 of 1411 Old 10-31-2013, 02:46 PM Thread Starter
ksilovich
Please explain to me why this guy has no problem with his jeep.
I built my rig because I saw his rig when I sold him my old jeep fenders. He is heavier then me. Cummins 4bt, 1 tons, 40's. O yea he built it back in 2008. He has wheeled Moab, CO, Rubicon, and other trails with out any issues.
There is a reason I didnt do Hiems to begin with and that is for road quality.
Heims and JJ on the road will react completely different. And seeing as I have 5k road miles on my rig, that is the reason I started out with JJ.
post #713 of 1411 Old 10-31-2013, 02:49 PM
kellerumps
kellerumps's Avatar
I totally understand the road quality aspect. I have no idea how hard this guy wheels his rig....I do have a pretty damn good idea on how hard you wheel yours.
Just gave you my $.02...its your rig....
Member of:
post #714 of 1411 Old 10-31-2013, 02:50 PM
Jeffro06
Jeffro06's Avatar
He ^ probably hasn't flipped his rig yet. lol.
Jeffro06 is offline
post #715 of 1411 Old 10-31-2013, 02:57 PM Thread Starter
ksilovich
He wheels decently hard on it. But I am just saying 5 years of wheeling is alot more then 10 days on my joints. That is the point I am trying to get across.
He has not. Just a side flop that I know of.
The front will have more force on the joints as in a suspension design. If you think about it simple terms. The front has to be forced up and over a rock, where as the rear kinda glides upwards. That is why I am leaning towards heims in the front and JJ in the Rear. Sacrifice a little here and there. Also All new Heims are just shy of 1k.
post #716 of 1411 Old 10-31-2013, 04:15 PM
Danno6102
Let me rephrase my question. What do you think happened inside the joint to cause the excessive play? Like excessive side loading that might have compressed the poly bushing?
post #717 of 1411 Old 10-31-2013, 05:16 PM Thread Starter
ksilovich
Yup. I kninda think that. If I had issues with the rear id say its just normal wear and tear.
post #718 of 1411 Old 10-31-2013, 08:44 PM
aw12345
Took your advice. There looking over some photos right now. Well see where this leads. If they do nothing about it. Heims it is.
On other news Superwinch is sending me my 3rd new winch.
1) motor was shot
2) Would spool out but not in plus it was a 9k not like my original 12.5
The 3rd one they didn't argue with me, there just sending it to me.
Checked things over from our Harlan, KY trip. It looks like high steer is in the near future. I bent the 1.5" 7075 tie rod. Right by the pumpkin, its bent in a good 1.5". Thinking of doing hi-steer with 1.75" AL this time.
I also have to do something about my power steering pump reservoir. The thing will leak oil on any incline, and I am constantly adding more out on the trail. I am thinking of welding a cap on the top with a port to pump up higher to a remote reservoir.
Then I put the drive cowl into a tree and dented that up with part of the hood. The boat side on the passenger side is dented in. And I fawked up the hinges, the passenger door barley closes now.
Other then that its pretty safe and sound.
Sounds like a pretty good wheelin trip
aw12345 is offline
post #719 of 1411 Old 10-31-2013, 08:51 PM
aw12345
Rebuilt the JJ's and see what happens, I got mostly the same setup with 40"s and have wheeled the piss out of it for 3 years, thing still drives nice on the street and JJ's are still tight, front and back
aw12345 is offline
post #720 of 1411 Old 10-31-2013, 10:52 PM
Imped
Imped's Avatar
Rebuild the JJ's man. Cheap, easy, and I bet you don't have to worry about it again....at least until you hardcore side-load them.
Anyone who's ever used them for a good stint of time knows that durability is a non-issue.
OlllllllO
IndyORV
Imped is offline
14b , 40's , 4bt , aluminum , boat side , cnc , cummins , custom , d60 , diesel , indyorv , ori struts , plasma , tj
Clutch Assembly Pictures Requested - 1971 CJ5 028346 Jeep Picture Requests 0 06-18-2011 11:20 AM
Some Assembly Required: An 82 CJ7 Strings72 Jeep Builds 5 01-20-2011 05:11 PM
Any pics of Jeeps without spare tire & assembly phyrefighter Jeep Picture Requests 14 03-17-2008 11:29 AM
Factory Soft Top Header & Assembly Varnish Jeep Picture Requests 0 10-13-2006 11:04 AM
