Jeffery 2.0 - some assembly required - Page 17 - JeepForum.com
post #241 of 1411 Old 11-06-2012, 04:39 PM Thread Starter
ksilovich
I have been working with Jim over at OTRATTW on some custom switch covers.
He did the artwork for free since I bought over $300 in switches lol
I have 20 total switches and 12 of which needed custom engraving and symbols. Cant wait till I get them
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #242 of 1411 Old 11-07-2012, 08:01 AM
babyhulk
Same switches i run in my jeep and i love them.
babyhulk is offline
post #243 of 1411 Old 11-10-2012, 12:36 AM Thread Starter
ksilovich
came home from school and made a double shear tab break. Instead of paying $4 a tab, i could make them for the cost of a couple hrs making this.
Sample piece. Bent it like butter
post #244 of 1411 Old 11-10-2012, 02:42 AM
straightsixjeep
Thats awesome good job.
straightsixjeep is offline
post #245 of 1411 Old 11-10-2012, 09:37 PM Thread Starter
ksilovich
made all 10 of the seat belt tabs.
I knew empty wd-40 can were useful. Welded it to my knotcher so I can keep the allen keys and wrench handy now.
Finished the top of the cage. Plus put the driver side b spreaders in.
Need to finish the seat mounts and the x behind the seats. That will come tomorrow.
post #246 of 1411 Old 11-10-2012, 10:44 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Looks great, how about a side view of the double shear press brake?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #247 of 1411 Old 11-10-2012, 10:48 PM Thread Starter
ksilovich
Thanks Man. I'll take a photo in the morning. I had to modify it little. All it is, is 2 angle iron pieces with a half inch gap. Originally the angle iron was 3x3. Today I cut it down to 2x3. Made it easier to remove the tap.
post #248 of 1411 Old 11-10-2012, 10:52 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Wow nice work man!
gst95dsm is offline
post #249 of 1411 Old 11-11-2012, 02:38 PM
kellerumps
kellerumps's Avatar
I know I'm not very smart......but I dont get how that works?
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #250 of 1411 Old 11-12-2012, 12:58 PM Thread Starter
ksilovich
Doug. It works by pressing a piece of 1/8 plate in the center of the gap. This then pushes the steel down causing it to fold up. As it goes down you will get a nice u shape. The gap is set at 1/2" and the dies is 1/4".
On another note. I worked on the cage under the seats. This was a pain to get correct. Cause on the seat sliders I am using and how tall I am. I want the seats as low as possible so I have head room, seeing as I'm 6' 2".
Really the only tubes I have left is the x behind the seat.
post #251 of 1411 Old 11-18-2012, 10:16 PM Thread Starter
ksilovich
Worked on the cage yet again. Only thing I have left is to mount the seats and weld the whole thing.
This weekend I got the x behind the seats in, then I got the gusset from the second b to the first b in. Then I did the rear of the cage so the fuel cell and tool box will be supported by the cage and not the tub. Then I put a tube going through the dash on the passenger side so I can make a removable handle.
Left enough room so I can make a bottle holder between the tool box and fuel cell. My plan is to have two radiator bottles, two gear oil, one 5 qt bottle of oil, and then some power steering and brake fluid. Only plan on carrying those items on long wheeling trips like Moab and Rubicon.
post #252 of 1411 Old 11-19-2012, 12:09 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
Dude, that's one fine looking cage.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #253 of 1411 Old 11-19-2012, 07:29 AM Thread Starter
ksilovich
Thanks man
post #254 of 1411 Old 11-21-2012, 11:03 PM Thread Starter
ksilovich
Finally broke down and bought my 1.25" die.
So I bent up some grab handles and made the grab bar for the passenger.
Then I spent some time thinking how I wanted to do my rear rack.
So then I bent this up and tig-ed the two ends together.
Going to get a buddy of mine to cut the bottom and sides out for me on his plasma table (since my dad wont let me buy one to put in the garage )
post #255 of 1411 Old 11-24-2012, 12:02 AM Thread Starter
ksilovich
Today I took my old sub box that I made for my old 2000 GMC 3500 dump truck and modified it a little. Turns out its almost a perfect fit.
Took the center out and cut it down.
I plan to throw a coat of fiberglass resin over it to make it water proof.
Then I moved on to the seat mounts.
I used a hole saw and cut out some circles, then welded a nut on the back of them, and then tig welded them on to some tube.
Power of Blue
Driver side with the seat slider
Passenger side
From the top of my head to the top of the cage is about 3.5~4" of head room.
14b , 40's , 4bt , aluminum , boat side , cnc , cummins , custom , d60 , diesel , indyorv , ori struts , plasma , tj
Clutch Assembly Pictures Requested - 1971 CJ5 028346 Jeep Picture Requests 0 06-18-2011 12:20 PM
Some Assembly Required: An 82 CJ7 Strings72 Jeep Builds 5 01-20-2011 06:11 PM
Any pics of Jeeps without spare tire & assembly phyrefighter Jeep Picture Requests 14 03-17-2008 12:29 PM
Factory Soft Top Header & Assembly Varnish Jeep Picture Requests 0 10-13-2006 12:04 PM
