Jeffery 2.0 - some assembly required - Page 11 - JeepForum.com
post #151 of 1411 Old 09-03-2012, 11:39 AM
10-3-TJ
Electrical engineer is what i need.. i am starting my wiring today and honestly it might as well be greek or Spanish
Awesome build. Love it
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #152 of 1411 Old 09-03-2012, 02:42 PM
djflyy
Originally Posted by ksilovich View Post
Mine are just 2" clearance marker lights. They are only 2 wire led. So what you do is add 2 diodes and a resister to make them a 3 wire turn signal. When I get to that point of wiring it all I take some photos and explain what i did. Its not hard to do at all. But then again I am an electrical engineer
Thanks. I'm a touring audio engineer so electricity is a common thing in my life (multiple 400 amp tie-ins per day), no explanation necessary! Thank you though. I'll look around more for lights, I just haven't found the right ones yet. For now I've got 3/4" LED markers in my TNTs as turn signals, which I will switch to the running lights and run the 2" markers as turn signals when the time comes.
djflyy is offline
post #153 of 1411 Old 09-03-2012, 03:50 PM Thread Starter
ksilovich
Its not that hard to wire these things up. These engines are simple .
Sounds good. Its really not hard to make the 2 wire to a 3 if you really want to make the 2" light a running light and turn light. I think I have some photos of it on my computer back at school. I check when I head back tomorrow.
Well today was the only day I worked on the jeep all week end. And of coarse I ran into problems. My radiator was 1/4" too low for my ram PS hose.
So i had to raise the whole radiator up and it was a *****. Once I finished that I made all the power steering hoses.
I also got my South Bend Clutch on friday. Dam this thing wasnt cheap
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #154 of 1411 Old 09-03-2012, 09:42 PM Thread Starter
ksilovich
worked on some more hoses.
Took me awhile to figure out where the second heater hose connects to. Come to find out if you remove one of the temp switch on the side there is a 1/2 npt fitting. So i got my self a 1/2npt to 5/8 barb and it work great.
Upper heater hose
Found me a lower radiator hose.
Then I bent up a tube for my front suck down winch. Just waiting for it to come in the mail
post #155 of 1411 Old 09-06-2012, 07:06 PM Thread Starter
ksilovich
Drew up some logic today after class. It will combined my rear turn and brake signal to one wire. It will also combined my front turn and running lights to one wire. In addition it will control my low/high fan. With the addition of lighting a red led when I switch the fan off. Then there is the Engine Fault LED, Low radiator level LED, low window wiper fluid LED, parking brake LED.
Inputs on the left, Outputs on the right
I could have used a micro controller to do most of this, but for right now I just want the fast and simple way. Later on I might clean up the relays with an IC. But for now this will do.
post #156 of 1411 Old 09-06-2012, 07:51 PM
kellerumps
kellerumps's Avatar
THANK YOU for the head-ache you just gave me......
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #157 of 1411 Old 09-06-2012, 08:11 PM Thread Starter
ksilovich
Your very welcome. What will happen when I post the complete wiring harness? Will your head explode? lol
post #158 of 1411 Old 09-06-2012, 08:19 PM
Jeffro06
Jeffro06's Avatar
You just like to show off.
Jeffro06 is offline
post #159 of 1411 Old 09-07-2012, 07:06 AM
woods9898
1995 XJ Cherokee
amazing freakin amazing
woods9898 is offline
post #160 of 1411 Old 09-07-2012, 07:25 AM
Imped
Imped's Avatar
Yep, that ****'s over my head by a mile. My brain wasn't built to understand electronics past the basics and I've accepted that.
OlllllllO
IndyORV
Imped is offline
post #161 of 1411 Old 09-07-2012, 01:07 PM Thread Starter
ksilovich
I do
Well you now know who to come to for that kinda s***
Today I came home to find a couple presents
post #162 of 1411 Old 09-07-2012, 04:41 PM Thread Starter
ksilovich
Hood pins - check
post #163 of 1411 Old 09-08-2012, 12:36 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
Who made your hydro assist hoses? Can you remember how long they are? Thanks.
Btw my hood is already set up for auto fab hood pins. :shh:
K.C.C.O.
Carpe Diem
Hendrix is offline
post #164 of 1411 Old 09-08-2012, 01:18 AM Thread Starter
ksilovich
I made all the hoses myself. I used Russell stainless steel 6an power steering lines and then Russell hose ends. I have no idea on the lengths cause all i did is put one end on then I ran the hose, dropped the axle and cut the line. I never pulled a tape measure out once doing it. LOL
Hose - http://www.summitracing.com/parts/RUS-632640
90* end - http://www.summitracing.com/parts/RUS-620421/
straight end - http://www.summitracing.com/parts/RUS-620401
6an to 1/4npt - http://www.summitracing.com/parts/SUM-220647B
I have some 3an hoses and fittings to do for all my brake lines.
As for the hood, tell me when I can pick it up. I have your dollar in my wallet with your name on it
post #165 of 1411 Old 09-08-2012, 01:19 AM Thread Starter
ksilovich
This is how they work.
14b , 40's , 4bt , aluminum , boat side , cnc , cummins , custom , d60 , diesel , indyorv , ori struts , plasma , tj
Clutch Assembly Pictures Requested - 1971 CJ5 028346 Jeep Picture Requests 0 06-18-2011 11:20 AM
Some Assembly Required: An 82 CJ7 Strings72 Jeep Builds 5 01-20-2011 05:11 PM
Any pics of Jeeps without spare tire & assembly phyrefighter Jeep Picture Requests 14 03-17-2008 11:29 AM
Factory Soft Top Header & Assembly Varnish Jeep Picture Requests 0 10-13-2006 11:04 AM
