Jeepster1407's Project Take 2 - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeepster1407's Project Take 2
New! JK/U skid plate system.We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!
Unread 06-19-2014, 11:49 AM   #16
jeepster1407
Here's some update pictures of the switch panel i have been making... whats your guys thoughts on it?
[url=http://flic.kr/p/nZFEhu]
[url=http://flic.kr/p/o2CmAu]
jeepster1407 is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 01:25 PM   #17
jeepster1407
So I picked up an axle and some spare parts I found on craigslist this past Saturday. It's a low Pinion Dana 30 out of an LJ. Unfortunately the housing is bent, but it has 4.88 gears, A Spartan locker, Chromoly axle shafts, Currie correctlync steering, with a new tie rod for it, along with the original currie tie rod for a spare, ORO steering kit with tie rid and drag link, and finally two pair of factory axle shafts for spares. I think I'm going to add the Spartan and the chromoly shafts and the currie steering to mine. I will probably end up selling the 4.88 gears since I want to build a high pinion. I'm torn between running the Currie kit or this ORO kit. I think I'm going to run the Currie kit and see how I like it and go from there. I do like how the ORO kit has a solid tie rod from knuckle to knuckle, and the drag link goes from pitman arm to knuckle but this makes the track bar/drag link out of parallel so I could see the possibility of bump steer there but I doubt it would be very noticeable.
