Jeepster1407's Project Take 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeepster1407's Project Take 2
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 03-04-2013, 09:30 AM   #1
jeepster1407
Well i figured I'd go ahead and start a build thread for my new toy. I traded my Built 95' TJ for a 2000 TJ. Well here it is in all her beauty. This is a Pic the PO sent me.
When I got it there was a 4" skyjacker suspension lift with a 1" body lift. I think the BL is Teraflex because all the 1" pucks are aluminum. It also has a new set of 5 285/75/16 Toyo open country M/T's and 5 Moto Metal 951b's with a fair amount of rock rash.
It had a set of JKS quick disconnects installed but they were all seezed up and one of the welds broke so I have replaced them with a set of Rough Country ones. They seem to be built well surprisingly. I'd Deffinately recommend them.
My favorite thing about it I guess is the 4.0 & rear 44. These are also pic the Previous owner sent me.
So far all I have build a front bumper, Rocker Guards, change the soft top to black, add a CB, converted all the interior lights to LED, added some Rigid Dually's, and fix a few broken parts. The shocks could use replacing and hopefully ill be getting a winch sometime in the future, in the mean time Ill be updating this as the mods come.
Sent from my iPhone using Tapatalk
_________
My Thread - http://www.jeepforum.com/forum/f22/p...arrel-3291513/
jeepster1407 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2013, 03:44 PM   #2
TXST8tj
Looking good! What are the short and long-term plans?
TXST8tj is offline   Reply With Quote Quick reply to this message
Unread 03-05-2013, 09:45 AM   #3
jeepster1407
Thanks, I have recently installed some rockers I made here at work. I'll work on getting pics of them.
This build will be nothing crazy since i have my firstchild on the way in August. That's the main reason I traded my YJ was for something a little more comfortable for the future little one. Short term goals (next 6 months) include Winch for the front, custom Tire carrier for the rear, H4 headlights, either a 12" light bar above the winch fairlead or a 20" bar on the hood, an aussie up front, & TJ tie rod.
Long term goals include building a HP30 with truss, 4.56 gears, HD control arm mounts, tube seals, chromos, and Solid diff cover. Then purchasing some selectable locker for the rear 44 (I had an ARB a while back and it was great so thats probably the route im going to take), reagearing to 4.56 and a Solid diff cover for the rear. Then I'll install a SYE and "flater" skid.
_________
Unread 03-05-2013, 10:10 AM   #4
jeepster1407
I'm looking at the Smittybilt XRC 8 Comp winch because I really want synthetic rope. I had a Warn M8000 befor and It was great but I hated the wire cable. What are some opinions on the XRC8? I heard the whinch hook needs to be replaced which smittybilt will do and the grease could use repacking with lighter grease to make freespool better. any other cons? Or does anyone have some other suggestions for a cheaper end winch that comes with rope instead of cable?
_________
Unread 03-05-2013, 12:47 PM   #5
TXST8tj
Congrats on the baby! Our second will be born in September.
Sounds like solid build plans for a capable Jeep!
I run a RC winch and a buddy runs the Qtec winch. Both have done their job, but both have limited use. I have installed several Smitty winches. I can't see how any of these 'budget' line winches are different from each other.
Don't settle for a Smitty winch just to get the synthetic line. Buying a better Warn winch now, and upgrading to synthetic line later would be the route I would take.
With Warn's "VR" line being so affordable, I would pass up all the budget winches.
Take a look at the VR8000...it's only $480. (the XRC8 is $450)
http://www.winchdepot.com/Winches-Wi...&t_pn=WAR86245
I'm not knockin' the XRC winch, just saying I would spend the extra $30 initially on the Warn, and then come back later for a synthetic line.
Unread 03-05-2013, 03:37 PM   #6
jeepster1407
Yea I may look into that also. Thanks for the tip!
_________
Unread 04-30-2013, 10:58 AM   #7
jeepster1407
Well I havent updated this in a while. A few more mods have been added.
Heres a pic of the rockers I made here at work.
I then purchased a winch from a guy on a local forum that was brand new in the box.
I painted the fairlead because that was just to much bling for me.
Then in order to mount the fairlead i had to either weld up a mount to my bumper or come up with a bolt on mount so i came up with this and a made it here at work.
Heres a pic of the winch mounted on the bumper with the bracket I made.
I added a 13.5" hanma-auto light bar that is wicked bright. Again i needed a place to put it so I fabbed up another mount at work to place it above the hawse fairlead.
Next I found some switches I liked over at OTRATTW and a stero that worked. The one that came in the jeep was broken.
Next I plan on adding a winch hoop / stinger to protect the light bar
_________
Unread 05-02-2013, 07:58 PM   #8
TXST8tj
I have the same light bar above/in front of my winch, and the cubes on the windshield.
Looking good!!!
Unread 05-17-2013, 02:02 PM   #9
jeepster1407
I added a Winch hoop above the Light Bar for a little extra protection.
I also made a step to assist my Pregnant wife get in a little easier.
_________
Unread 07-06-2013, 09:20 PM   #10
jeepster1407
I made some light mounts at work so I can run two sets on windshield lights.
Here's some crappy cell pics of them.
_________
Unread 07-24-2013, 06:55 PM   #11
jeepster1407
Had a new windshield installed today. The old one had a small chip in it but the seal around it leaked when it rained so the wife was tired of getting wet.
_________
Unread 02-02-2014, 09:48 AM   #12
Anschutz
Any updates to this? I'm sure with a little one things have slowed. Got here from TXST8tjs build.
Anschutz is offline   Reply With Quote Quick reply to this message
Unread 02-02-2014, 02:12 PM   #13
jeepster1407
Not to many updates. I got a hard top , diff protection, done some maintenance on it. I've got a good pile of parts to install but we're building a house, my brother in law is building a house, and my father in law is building a house ands a big shop and were all contracting it ourselves so time is limited to say the least.
_________
Unread 02-14-2014, 09:18 AM   #14
jeepster1407
Not many updates here... This past weekend we went To Morris Mountain and did some light wheelin'. On the way down my belt tensioner decided to explode as I was going around 285 in ATL so it was fun changing that on the side of the RD. Here's a few pics that someone else took. As usual I forgot to take any pics of myself...
_________
Unread 05-21-2014, 01:07 PM   #15
jeepster1407
I've been working on this switch panel on and off lately..... What do you think?
_________
