JeepRocks86 TJ HP60, Shaved 14 Bolt, Coilovers, Pit Bull Rockers
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Some Call me RockDog
EDIT:
![]() The TJ has been stretched for about a year. It work wonderfully. On 4/14/11 I picked up a set of Dana 60s. King Pin SnowFigher front from a 79 250. Rear is also out of a 79. Post 107 Starts the 60s build. I am currently stretching the wheelbase of my TJ. My TJ has progressed a lot over the years since I purchased it. From Stock Daily Driver to modified daily driver to more modified daily driver to even more modified Trail Rig. I want to keep the jeep streetable, but have one that performs on the trail as well. The day I bought it. Strait panels and no scratches. ![]() First dirt. ![]() First Stuck ![]() 4" Skyjacker and 33 Baja Claws ![]() 36s stock gears and axles ![]() 4.88s, Chromo front shafts, lockers ![]() I have more older photos that I will post at a later date. Custom belly up skid RCI 15 Gallon Fuel cell with KORE ring MORE front bumper to be straitened out and sold Rear modified bumper from ebay that I bought a number of years ago Currently the jeep has 35s for the street and 36s for the trail Dana 30 front, Yukon Chromo shafts, Lockright, 4.88s dana 44 rear, Alloy USA shafts, Detroit, 4.88s 4.5 RE springs Shocks TBD Clayton Long arm front Custom rear Stretch in progress ~hopefully 5-7" with out a comp cut. (ballistic joints) PSC steering box sitting on the garage floor Future Plans (no particular order)... Dana 60s 40s or 42s re do the cage new front bumper sink the fuel tank into the floor with a custom box overhead for protection different suspension mounts 3 link front etc... Recent favorite trail photos. Harlan March 2009. I bought a House in late 2008 so my Jeep trips have been drastically reduced. Harlan Lions Den ![]() ![]() Looking down into Lions den ![]() Can opener trail ![]() Current build: Rear frame modification. New rear control arms new crossmember above the axle cut the fenders Hopefully I will get about 7" of stretch at most. photobucket album for the stretch Silver TJ Stretch pictures by JeepRocks86 - Photobucket planned cut ![]() How the bumper was ![]() Cut corners (I will probably cut more out of the rear) ![]() ![]() Rear crossmember (Factory vs my plan) ![]() ![]() Frame clean up ![]() ![]() The reason for the new crossmember ![]()
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 Last edited by JeepRocks86; 10-28-2011 at 05:33 PM.. Reason: Changed Title |
#2 |
Initial Frame cut for the coil mounts.
![]() Coil mount welds ![]() Coil mount mock up ![]() Frame welded up ![]() ![]() 3/16" reinforcement plate that goes on the inside of the frame on both sides. ![]() one of the frame plates welded in ![]() as it sits right now. ![]() I haven't touched the jeep in two or three weeks. My new body mounts did come in this past week. I am planning on removing the 1" bodylift. It has been cold and I have been swamped with school work. After this semester I will have 2 400 level classes and one 500 level Engineering course for my Bachelors. My plan is to continue to get my MEng (masters of engineering) and possibly an MBA since UL has a joint program with the MEng/MBA.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#3 |
Looks good.
#4 |
Just violated my Parole
ive been waiting to see this
#5 |
Thanks, Maybe this weekend I will be able to do some more work. I figured it wasn't really build thread worthy since there are no one tons and 40s etc.
#6 |
This is JF, not Pirate Tyler lol
93 YJ - SOLD |
#7 |
subscibed..cool thread,,hurry up and get to work already
JACK OF ALL TRADES,,,MASTER OF NONE fla cracker head born and bred build- http://www.jeepforum.com/forum/f22/punishers-ezgo-build-thread-1065655/ |
#8 |
i would redo those welds if i was you
Selling your tire carrier?! send me a PM i want it |
#9 |
insert stuff here .... i think the welds look melted in good..when it gets some mud and dirt on it youll never see it from my house ![]() get r done
#10 |
Looks good. Looking forward to following this to the end.
#11 |
My plan was to grind them down smooth and weld over them again for a better looking weld. The weld penetration looks good, but I agree they look like crap.
#12 |
I looked at the jeep again today.
#13 |
TITS
Awesome, I'll be watching this like a hawk.
#14 |
#15 |
TITS
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
