JeepRocks86 TJ HP60, Shaved 14 Bolt, Coilovers, IROKs - Page 2 - JeepForum.com
post #16 of 592 Old 02-21-2010, 06:29 AM
Guzbus
Bump for a great build
Guzbus is offline
post #17 of 592 Old 02-21-2010, 09:44 AM
BeepTheJeep
Nice pics! I envy you!
BeepTheJeep is offline
post #18 of 592 Old 02-21-2010, 05:33 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Thanks everyone. I hope to get back in the garage this week. I was going to work yesterday, but my girlfriend's Jetta decided it wanted to overheat so I got to work on that, and I need to finish it tomorrow evening after classes.
Out of curiosity, why would you envy me?
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #19 of 592 Old 02-21-2010, 05:36 PM Thread Starter
JeepRocks86
went to the Carl Casper auto show this weekend... Saw this and laughed... A LOT.
I almost went up to the guy and asked him WTF was he thinking but I didn't.
Passenger side drop 60 front, and I forget the rear axle, may have been 60 70 or 14 bolt.
49" IROKS.
It is my new inspiration for my jeep.
For Sale:
post #20 of 592 Old 02-21-2010, 10:06 PM
TYphoonXJ
Subscribed!
96 XJ. RC 4.5" Long Arm with 31" Firestone Destination MT's.
TYphoonXJ is offline
post #21 of 592 Old 02-23-2010, 10:21 AM Thread Starter
JeepRocks86
Dear VDub,
Your water pump sucks on my girlfriends 1.8T Jetta. Why did you need to put a plastic impeller on the water pump that comes apart at 65000 miles. I spent a lot of hours trying other things and my ideas didn't fix it.
Thanks,
Tyler
That being said, I have no other immediate project vehicles, so I plan on spending a few hours out in the garage tonight.
For Sale:
post #22 of 592 Old 02-25-2010, 12:09 AM Thread Starter
JeepRocks86
After not touching the jeep for almost 3 weeks, I worked on it a bit this evening.
I did some grinding and welding on the rear.
I also did some planning on my rear crossmember. I don't think my original though for my crossmember will work.
I think I will put a large tab off of the frame with a gusset or two on each side. Those tabs will be tied into the crossmember which will have 2 gussets on each side as well. I am taking the body lift off so there isn't quite as much room under there to make everything fit like originally planned.
Also, the BL came out and I'm going to replace the rubber pieces with poly ones as well as soak the metal inserts/cups to remove the rust and then sand them down for a little bit of paint.
For Sale:
post #23 of 592 Old 02-25-2010, 11:37 AM Thread Starter
JeepRocks86
Designed a new rear crossmember again.
It should have plenty of gussets. I didn't feel like sketching both sides so here's just one side.
For Sale:
post #24 of 592 Old 03-07-2010, 10:15 PM
bddisi
49" IROKS.
They say, A picture is worth a thousand words. This one is only worth the 3 letters, you have already laid down, WTF.
On another note, it seems that there is always someone breaking balls about how someones welds look. Mine by no means look that great, but I know when there is proper penetration and when there is not. I also know that welding underneath like that is tricky. I think your stuff will be fine. A ton of people build the crap out of their jeep using all of the factory brackets. Sometimes they fail, mostly by bending, sometimes by ripping off. But start cutting those off and check out the factory welds, thats scary.
Good work...........
Scorpion-Offroad-Concepts
bddisi is offline
post #25 of 592 Old 03-08-2010, 09:12 AM
dreizehn
Agreed on the factory welds... I spent some time with a new frame on my rig cleaning everything for coating and couldn't believe the quality of welds under there.
Good luck with your build.
dreizehn is offline
post #26 of 592 Old 03-08-2010, 02:24 PM
TYphoonXJ
Yeah seriously! I looked at the inside welds to my control arm brackets....looks like someone sneezed on my unibody. Its actually scary
post #27 of 592 Old 03-08-2010, 05:15 PM Thread Starter
JeepRocks86
I haven't touched the jeep in a while. I had good momentum going and then Things started happening that didn't allow me to work on the jeep.
I will get this stage finished, it will just take a lot longer than I figured.
For Sale:
post #28 of 592 Old 03-08-2010, 05:27 PM
IzzyGreenTJ
Keep on jeepin!
Keep on Jeepin :D
IzzyGreenTJ is offline
post #29 of 592 Old 03-23-2010, 10:30 PM Thread Starter
JeepRocks86
I cut the tube for the crossmember. It will need a little more grinding and the loose paint removed before I weld it into place.
I also stripped most of the rust off of the metal body mount pieces, by soaking them in some rust remover. I'm going to paint them before I put them back under the jeep.
For Sale:
post #30 of 592 Old 03-24-2010, 10:13 PM Thread Starter
JeepRocks86
I picked up shorter bolts for my body lift removal. I hope this weekend to get a whole lot knocked out.
I just found these photos taken about this time last year at Harlan, KY.
Just before sunset.
For Sale:
14b , custom , hardcore , hp60 , indyorv , pitbull , psc , rockers
Project Ton Ton - 1 Ton Cherokee HP60/14b andrewmacc Jeep Builds 300 10-08-2014 08:46 AM
cj's on coilovers 80CJ5SBC Jeep Picture Requests 3 12-13-2011 10:12 AM
Coilovers YJCRAZY1995 Jeep Picture Requests 4 12-06-2011 02:51 PM
WJ with shaved cladding JSRichar5985 Jeep Picture Requests 2 05-23-2011 12:35 AM
Lets see some coilovers! ljs89 Jeep Picture Requests 0 07-10-2009 07:59 AM
