JeepRocks86 TJ HP60, Shaved 14 Bolt, Coilovers, IROKs - Page 15 - JeepForum.com
post #211 of 592 Old 11-25-2011, 06:11 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Pictures
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #212 of 592 Old 11-25-2011, 06:17 PM Thread Starter
JeepRocks86
I bought this new and used it as a wheel for my spare. I probably should have washed it before I took a photo. No rock rash.
15x8 5x4.5
Louisville, KY
$35
For Sale:
post #213 of 592 Old 11-25-2011, 10:52 PM Thread Starter
JeepRocks86
36" TSLs for sale.
This evening I finished getting the rear axle out and the front axle is about half out. I started dozing off under the jeep on the creeper and decided to call it a night. I will get some photos once everything is out. Starting in January, I think I'm going to have to put a coffee maker in the garage so I can get this finished by March for a shake down run and definitely April for my Bachelor party to where ever we end up going.
I have 2 friends doing pretty extensive builds at the same time. One is putting air shocks on the Rear of his TJ. He already has 60s and air shocks in the front. The other is putting 60s under his with coilovers as well as stretching it.
For Sale:
post #214 of 592 Old 11-26-2011, 01:22 PM Thread Starter
JeepRocks86
stupid Local Craigs List Deals... Never mounted.
Bear Super Seats in Wide Could be for sale for the right price.
For Sale:
post #215 of 592 Old 11-27-2011, 12:28 AM Thread Starter
JeepRocks86
Did a little work today. I was going to do more, but my fiance decided that the living room needed to be painted and well, I had to start and finish the project.
Passenger side coil and shock mount is out. Also the dana 30 is all the way out from under the jeep. All control arms with exception to the rear uppers are out. With the current setup of my rear upper mounts, I have to raise or lower the transfercase to get the bolts out.
I cut the tubes out with a saw zaw. Used an angle grinder with a cut off wheel to basically score the lower portion of the mounts and then when I was almost all the way through, I used a mini sledge hammer to pound the mounts out.
Had trouble with the upper shock bolts
For Sale:
post #216 of 592 Old 11-27-2011, 01:31 AM
93civic_Sedan
PM me your bottom dollar on the axles if you don't mind sir. Starting to kick around the idea of picking some up...
93civic_Sedan is offline
post #217 of 592 Old 11-27-2011, 11:24 AM Thread Starter
JeepRocks86
I'm asking 2750 for the axles, PM me an offer.
Here's the 30 front. Haven't gotten to clean up the rear yet.
For Sale:
post #218 of 592 Old 11-29-2011, 11:35 PM Thread Starter
JeepRocks86
Tuffy Under Seat Conceal and Carry Box came in yesterday. I paid around 40 shipped for it because I had won some Gift Certificates to www.morris4x4center.com over the summer at the www.UCORA.org Crawl4Christ event.
I can't seem to find my 1/4" drive ratchets so I can't get the front drive shaft out so it just hangs there resting on the skid plate. It's toast anyway.
Removed the front tube fenders tonight.
For Sale:
post #219 of 592 Old 11-30-2011, 12:06 AM
rockcrawlernut
I am excited to see the finished product!
Once you understand the way broadly you see it in all things.
2004 WJ Special Edition 4.0L Project "
4" IRO Lift | IRO HD Track Bar | Doetsch Tech 8000 | JKS Quicker Disconnects | JKS Bar Pin Eliminators | Cooper Discoverer ST Maxx 265/75/16
rockcrawlernut is offline
post #220 of 592 Old 11-30-2011, 09:25 AM Thread Starter
JeepRocks86
You and me both. I'm trying to get as much finished before I start my job Jan 9. Before I move to Columbus, IN, I will be commuting 75 miles one way which means I will be leaving my house no later than 630am and getting home around 630pm. In the same time I will be working on the jeep to finish it by the end of march/ some time in april, as well as trying to sell my house, find a new house, move, oh and I'm getting married in May. We're driving the jeep away from the church so it has to be finished by then.
Who needs a Stretched Limo when you can have a Stretched TJ on 40s. one of the groomsman has a TJ on 40s with air shocks and one has a 68 camaro, so there may be some poser or flexing out...
I was joking with my fiance one day a few years before we were engaged about driving the jeep when I got married. Then after we were engaged a while, we were talking about transportation from the church to the reception place. She said, "we're still driving the jeep right?"... "it has to be CLEAN, and I mean CLEAN, CLEAN"
For Sale:
post #221 of 592 Old 11-30-2011, 04:35 PM
Sgt.Fuzz
Lol, no pressure there!
My build:
Sgt.Fuzz is offline
post #222 of 592 Old 11-30-2011, 05:58 PM Thread Starter
JeepRocks86
Front ARB, Gears, and Master Install kit came in today.
Grizzly for rear, rear master install, rear R&P, Arb Compressor, and 1350 Yoke should be here tomorrow.
Ruff Stuff Specialties dana 60 diff cover shipped today.
For Sale:
post #223 of 592 Old 11-30-2011, 08:45 PM
jose_p_adams
Are you going to be running 5.38 gears? If so, does the pinion snout for the 14 bolt have tooling marks? I had read about that on Pirate a long time ago and wasn't sure if they had remedied it.
jose_p_adams is offline
post #224 of 592 Old 11-30-2011, 09:16 PM Thread Starter
JeepRocks86
I'm going to be running 5.38s. Wasn't sure about the problem. what do you mean Tooling Marks?
Also ordered DOM tubing for steering, front Track bar, shock hoops, and rectangular tube for the rear frame. A buddy and I are splitting the DOM tube.
For Sale:
post #225 of 592 Old 12-01-2011, 06:23 AM
jose_p_adams
http://www.pirate4x4.com/forum/showt...=456149&page=3
The machine that cuts the teeth in the pinion, also cuts the pinion snout, just a little.
14b , custom , hardcore , hp60 , indyorv , pitbull , psc , rockers
Project Ton Ton - 1 Ton Cherokee HP60/14b andrewmacc Jeep Builds 300 10-08-2014 08:46 AM
cj's on coilovers 80CJ5SBC Jeep Picture Requests 3 12-13-2011 10:12 AM
Coilovers YJCRAZY1995 Jeep Picture Requests 4 12-06-2011 02:51 PM
WJ with shaved cladding JSRichar5985 Jeep Picture Requests 2 05-23-2011 12:35 AM
Lets see some coilovers! ljs89 Jeep Picture Requests 0 07-10-2009 07:59 AM
