JeepRocks86 TJ HP60, Shaved 14 Bolt, Coilovers, IROKs - Page 14 - JeepForum.com
post #196 of 592 Old 11-02-2011, 07:16 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Originally Posted by spyder6 View Post
since when does Max sell pickles?
Since a long time ago.
They are made by Juicy Butts BBQ
www.BBQgeneralstore.com
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #197 of 592 Old 11-10-2011, 09:53 PM Thread Starter
JeepRocks86
Haven't done anything to the jeep, been busy with work and school but I have done quite a bit of work to the trailer. Still need to replace the deck and install the front brakes. Wiring is finished with exception of some wire loom and one ground wire. Tomorrow I plan on finishing up the wiring and then cut the boards down to install them. After that, If I have time, The front axle may get brakes.
For Sale:
post #198 of 592 Old 11-11-2011, 10:06 PM Thread Starter
JeepRocks86
I believe I should win the "best Neighbor award". Just got finished at 1045pm putting the boards on my trailer. That entailed a circular saw cutting the 20' boards down to 18' and then pounding them into place... Still need to load the jeep.
I will be moving next year. Everyone I talked to said they would be sad to see me gone. I told them that they wouldn't have to deal with all the cars (5 people live in my house, I rent out 3 rooms to pay the bills plus my fiance). They said that good neighbors are hard to come by. I guess me being friendly to them overcomes the 5 cars outside, flat bed trailer, occasional additional vehicles, and occasional garage noises.
For Sale:
post #199 of 592 Old 11-14-2011, 12:18 AM Thread Starter
JeepRocks86
Took it out for the last time this year and the last time before I tear it down at my Club's Toys for Tots run.
Had a great time. i broke a brake line on the driver front side. Also having some trouble with my PSC box or probably the pump. It's really stiff to steer and has been since I put it on. I'm hoping that it's air in the lines.
List of things that are going up for sale.
TJ30 4.88s lockright Yukon shafts knuckle over JCR offroad steering HD 1/4" lower mounts (rustys?)
TJ44 rear 4.88s Detroit Alloy USA shafts Clayton Truss heavy duty lower mounts
36" TSLs slightly grooved on Steel Wheels. 2 are mounted on weld on bead locks and the other 2 aren't. never got around to welding them up, but I have the bolts and rings to be welded on
35" Pro Comp AT tires on 15x8 aluminum wheels They probably have less than 15000 miles on them
Big Daddy Offroad HD tie Rod
35" Old style MTR <350 miles of street use on a 15x8 steel wheel
RE 4.5 Springs Front and Rear
3 11" BBCS shocks
2 13" BBCS shocks
Rear TJ bumper with D ring point and Receiver Hitch
Possibly for sale
Front tube fenders Poison Spider
Front Bumper
May have some other stuff when I come across it.
361_13_11_11_1_15_50_2.jpeg   361_13_11_11_1_15_48_1.jpeg   361_13_11_11_1_15_53_3.jpeg
For Sale:
post #200 of 592 Old 11-14-2011, 08:40 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
i guess i just never noticed any jars sitting around when i was perusing his wares.
My builds:
and
or follow us on
spyder6 is offline
post #201 of 592 Old 11-14-2011, 09:51 AM Thread Starter
JeepRocks86
They are delicious.
For Sale:
post #202 of 592 Old 11-20-2011, 01:59 PM Thread Starter
JeepRocks86
16" and 14" remote reservoir shocks were ordered the other day. I didn't get the springs yet because I'm not fully sure what rates I want to run quite yet.
For Sale:
post #203 of 592 Old 11-21-2011, 06:35 PM
aw12345
Find a way to measure the weight at each wheel once you got the axles under there, will give a very good idea what spring rates are needed
aw12345 is offline
post #204 of 592 Old 11-21-2011, 08:03 PM Thread Starter
JeepRocks86
Thanks, I'm still searching for a 4 wheel scale.
For Sale:
post #205 of 592 Old 11-23-2011, 07:28 PM Thread Starter
JeepRocks86
Drove it to the Car wash to give it a bath before I put it before the build up. The underside was pretty dirty from a few weeks ago's Toys 4 Tots run.
It was pulling to the right pretty badly on the way to and from the car wash. I didn't realize until I was about 2 blocks from home why it was pulling so badly. That's when I realized/ remembered I had broken driver side front hard brake line on the last wheeling trip. It wasn't leaking since my buddy did a really good job pinching it.
I'm pretty proud of the top sticker... Finally finishing school in December with my Masters in Mechanical Engineering and I start at Cummins in January. I'm really Excited.
I just hope I can finish this stage of the jeep's buildup before my wedding in May. Also trying to sell my house here in Louisville and find a new one in Columbus, Indiana.
Also looking for suggestions for Daily Driver Vehicles for my 75 mile drive to work and 75 miles back home until I move. Thought about buying a new one, but it's not worth it to me. I'm thinking once I move up there I may have to cross over to the "Dark Side" and find a Bright Silver 4 Door Wrangler as a DD for when living close to work. The jeeps would have to match of course.
For Sale:
post #206 of 592 Old 11-24-2011, 12:10 AM Thread Starter
JeepRocks86
Rear 13" shocks are out
Rear drive shaft is out, but not before dropping it on my stomach
all 4 tires are off
did some thinking and planning
For Sale:
post #207 of 592 Old 11-24-2011, 08:19 AM
spyder6
spyder6's Avatar
2010
i love my new 4 door. less than 200 miles on it and I'm averaging 18mpg. not stellar, but it should improve as the motor loosens up. then it will take a nose dive as soon as the 5.38's get put in the diffs
My builds:
and
or follow us on
spyder6 is offline
post #208 of 592 Old 11-24-2011, 11:41 AM Thread Starter
JeepRocks86
One day. Until I move I will be driving 150 miles a day so a JK isn't too practical. Originally I thought of getting a Sahara, but When in Rome, Why not get a rubicon. That and I will get below invoice pricing on all chrysler products.
Today I pulled the Rear diff skid off. Nth Degree/AEV
It's now for sale separately. $150 shipped via USPS I will get actual photos later but here's one for now off AEV's site.
For Sale:
post #209 of 592 Old 11-24-2011, 05:26 PM
WranglerBurg
Nice build and AEKDB bro
WranglerBurg is offline
post #210 of 592 Old 11-24-2011, 08:08 PM Thread Starter
JeepRocks86
Thanks
AEKDB
For Sale:
14b , custom , hardcore , hp60 , indyorv , pitbull , psc , rockers
Project Ton Ton - 1 Ton Cherokee HP60/14b andrewmacc Jeep Builds 300 10-08-2014 08:46 AM
cj's on coilovers 80CJ5SBC Jeep Picture Requests 3 12-13-2011 10:12 AM
Coilovers YJCRAZY1995 Jeep Picture Requests 4 12-06-2011 02:51 PM
WJ with shaved cladding JSRichar5985 Jeep Picture Requests 2 05-23-2011 12:35 AM
Lets see some coilovers! ljs89 Jeep Picture Requests 0 07-10-2009 07:59 AM
