Jeepin72's Build Thread - Page 39 - JeepForum.com
post #571 of 577 Old 06-05-2014, 09:31 AM
awinski
looks mucho stronger
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #572 of 577 Old 06-05-2014, 09:50 AM Thread Starter
Jeepin72
It is much beefier than before. I thought about welding some plate to the diff cover and bolting it to the bridge. But after welding up the plate and added gussets I didn't it was necessary. I was also worried that anything in that area of the diff cover would contact the TRE on the pitman arm since the axle is pushed as far forward as possible. The trackbar was moved forward and all...
Jeepin72 is offline
post #573 of 577 Old 06-06-2015, 06:32 PM Thread Starter
Jeepin72
The short side of the front 60 has walked excessively for some time. I didn't notice it when it was built the first time. I don't know if it started after the Yukon chromo inner shafts or not. I wonder if it had anything to do with previous breakage?
I've noticed binding when the front hubs are locked. I've sort of put off fixing them. but had some time today. I've read a lot about using or not using snap rings on the Ford 60's. It seems to be a mixed bag where some say they are not needed and others do. They can't hurt right? My 60 didn't have them on when I tore it down for the first time. I didn't put them on either when I built it. That all said, I've got a 96 BJ 60. The snap ring groove is there but it is moved from earlier locations.
From Quad 4x4:
Ford F-350 Dana 60 front axles had an outer axle shaft axle design change that relocated the snap ring groove to the inboard end of the splines. Dana lists the new axle shaft as 1988 mid model year change but Ford does not show this change until 1992. If you are looking for an outer axle shaft for a 1988 to 1991 F-350, you will have to verify the snap ring groove location. QU40371 is the correct outer axle shaft if your 1988/91 F-350 has the snap ring groove at the inboard end of the splines. If your snap ring groove is at the outboard end of the splines, see QU40486!
The shafts are Yukon chromo's, 35 spline inner and 30 spline out with Warn premium hubs.
Jeepin72 is offline
post #574 of 577 Old 06-06-2015, 06:51 PM Thread Starter
Jeepin72
The OEM shaft with snap ring groove at the inboard end of the splines. I don't recall removing any snap ring at tear down. That was years ago and so I could be wrong.
The left to right movement was the problem. The shaft seemed to want to be to the outward side instead of inward. I put the snap ring on in the inboard location and the Warn hubs would not go back on. So pushing the axle in didn't seem to be the answer. Pulling out was left. I moved it outboard and rotated it and there was no binding. So I installed the Warn internals and added the snap ring. I marked with a paint pen.
I added a hose clamp to help guide the cut. Using a cut off wheel I made my own snap ring groove.
Warn internals back in place.
Snap ring added. Drove it with hubs locked in and all was well.
Jeepin72 is offline
post #575 of 577 Old 06-13-2015, 09:27 PM
tdij
I didn't realize that was happening. I fully believe that contributed to the breakage... as I still believe there was absolutely no reason you should have broken under the circumstances you did.
Nice work on the DIY grove!
BOBCAT: TDI powered YJ
tdij is offline
post #576 of 577 Old 06-17-2015, 09:04 PM Thread Starter
Jeepin72
I don't recall when I first noticed the walk in the short side shaft. The long side doesn't do it. I think I first noticed the binding when turning on snow and I observed skid roll skid patterns. I wasn't sure if I was crazy or if the was a problem. Eventually I realized there was in fact a problem and that's when I discovered the walk in the shafts. Then I put the problem off for a bit...
When I built the axle the first time (OEM inners and Yukon outers) I recall debating the snap rings that came with the Warn hubs. They made no sense to me. The OD of the snap ring was smaller than the ID of the spindle. They didn't come with any washers to place between the spindle and the snap ring. Not to mention the internals for the hub wouldn't fit if the snap ring was in the inboard location either. So, I didn't use them. I don't recall any walk at the time, but I don't think I would have looked for it either.
Before I decided to make the cut I cycled the steering to full lock and turned the tires in both directions. I did it again after the cut and on its own weight. Drove forward and backward at full lock around my cul-de-sac. My neighbors love me! Then a road test. It worked...or at least nothing grenaded
Jeepin72 is offline
post #577 of 577 Old 08-20-2015, 11:28 AM Thread Starter
Jeepin72
JP Magazine Shoot
Went wheeling a few weekends ago with a writer for JP Magazine. She shot my rig! Who knows if it will make the magazine...but I've got pictures with the watermark to prove it.
Jeepin72 is offline
Build Thread Agent620 Jeep Builds 32 06-06-2013 10:29 AM
CJ5 build thread hybridmoments Jeep Builds 195 10-24-2012 11:31 PM
my build thread Glenn5 Jeep Builds 3 05-18-2010 08:10 PM
My Build Thread - '05 TJ 05rockymtn Jeep Builds 12 10-29-2009 01:26 PM
