Jeepin72's Build Thread - Page 30 - JeepForum.com
post #436 of 577 Old 04-17-2013, 03:41 PM
IEcrawlerTJ01
What procedure did you use to bleed the brakes?
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #437 of 577 Old 04-17-2013, 06:03 PM Thread Starter
Jeepin72
I had my wife pump the brakes three times and then push and hold while opened and closed the bleeder while she held the pedal.
Jeepin72 is offline
post #438 of 577 Old 04-17-2013, 07:07 PM Thread Starter
Jeepin72
So before dinner I was able to pull the MC to double check the push rod. I am dialed in at one half inch from the face of the booster. There was a nice big woosh from the booster so I know that seems to be working.
I pulled the front tires and had my wife press the pedal while I turned the rotors (12.5 " Fords) and the calipers engaged and stopped them. So both calipers are actually moving. Last nights observation was incorrect.
So is this a clamping force issue? Smaller bore MC?
Jeepin72 is offline
post #439 of 577 Old 04-17-2013, 08:42 PM
SnuffThis505
Subscribed and lookin forward to meeting ya next weekend!
SnuffThis505 is offline
post #440 of 577 Old 04-17-2013, 08:47 PM Thread Starter
Jeepin72
I jacked up the rear end and was able to turn the tires without the bake depressed and could not when the brake was depressed. At least those components seem to be working.
So it leads me to believe this is a clamping force issue. The pedal is firm as heck when the engine is off, but when it is on, the pedal goes to the floor.
Go back to the TJ MC with hydroboost? I also need to read up on gutting the proportioning valve, but IIRC the valve is the same in both set ups in a Jeep and that shouldn't make a difference right?
Jeepin72 is offline
post #441 of 577 Old 04-17-2013, 08:49 PM Thread Starter
Jeepin72
Right on man! You have a clean looking rig.
Jeepin72 is offline
post #442 of 577 Old 04-18-2013, 05:55 PM Thread Starter
Jeepin72
So I put the TJ MC back in today, what an improvement. I can lock it up at 30 mph. I can come to a decent stop at 55.
I am going to look into hydroboost as well.
Jeepin72 is offline
post #443 of 577 Old 04-18-2013, 06:22 PM
tdij
Good to hear you have acceptable braking again! Moab would be fun with a mushy pedal.
BOBCAT: TDI powered YJ
tdij is offline
post #444 of 577 Old 04-18-2013, 06:51 PM Thread Starter
Jeepin72
Acceptable is a relative term! They are better than with the Ram 2500 MC. They are not as good as they were. That is to be expected.
The way they were with the Ram MC...I wasn't going to go to Moab. There was no way I would take it on the interstate or a attempt a climb on Hells Revenge.
Now I think I could at least stop from 65 MPH. I will find out for sure this weekend!
But the first order of business in Moab will be to duck out on Fins and Things and see if I can hold it still on some of the little fins that dump out to sand. That way if I can't hold it, no big deal...it was only a 10 foot ledge. Not a terrifying death roll like the famed video from the old Lions Back.
Jeepin72 is offline
post #445 of 577 Old 04-18-2013, 08:08 PM Thread Starter
Jeepin72
Can you run a hydroboost with a ram assist?
Jeepin72 is offline
post #446 of 577 Old 04-18-2013, 08:14 PM
jason m
Nothing but the facts
jason m's Avatar
Yes, I have set up full hydro buggys with Hydro boost running on a single Chevy P-pump.
Glad to here you got some peddle back, like I said I had a the OEM YJ master for years and swapped to a TJ cause the YJ went out on me one day and this was goiving to me.
Works great, but in your case eather disc the rear or hydro boost it and it should offer the calmping force your needing.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is online now
post #447 of 577 Old 04-18-2013, 08:28 PM Thread Starter
Jeepin72
And what if I disk the rear and do a hydroboost?
Jeepin72 is offline
post #448 of 577 Old 04-18-2013, 08:33 PM
jason m
jason m's Avatar
Extra super secret brake power now, you just opened the portal to the brake gods.
Jason.
post #449 of 577 Old 04-18-2013, 08:36 PM Thread Starter
Jeepin72
Sweeeet
Jeepin72 is offline
post #450 of 577 Old 04-18-2013, 11:18 PM
tdij
Out of curiosity... what was the setup process done on the 2500 master? Don't masters need bench bled? I'm not specifically familiar... but for some reason I think a brand new master needs a lot of attention to get it set up initially????
tdij is offline
Build Thread Agent620 Jeep Builds 32 06-06-2013 11:29 AM
CJ5 build thread hybridmoments Jeep Builds 195 10-25-2012 12:31 AM
WeatherWarrior's "you better not call it a build" build thread. WeatherWarrior Jeep Builds 10 12-12-2011 06:31 PM
my build thread Glenn5 Jeep Builds 3 05-18-2010 09:10 PM
My Build Thread - '05 TJ 05rockymtn Jeep Builds 12 10-29-2009 02:26 PM
