Jeepen jimmy's xj build - Page 3 - JeepForum.com
post #31 of 59 Old 10-24-2013, 04:30 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
hey nobody likes your thread hahaha jeep forum is about as dead as myspace
Jamison
ajamison is offline
post #32 of 59 Old 10-24-2013, 05:44 PM
Luke95
Truth.
I <3 rockrash
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is online now
post #33 of 59 Old 10-26-2013, 06:42 AM Thread Starter
Jeepenjimmy440
I scared everyone away from my build due to my bad spelling hahaha!!!!!
Blue Ribbon Fab
Custom Cages, Bumpers, Lift installs and everything in between. P.M. me with your interest!!!!!!!
Jeepenjimmy440 is offline
post #34 of 59 Old 10-26-2013, 07:14 AM
krawler510
Was going from the 8.25 to an 8.8 worth the effort? I'm guessing it came with 4.10s?
Were you at Rausch the 19th? I saw at least 2 red XJs there.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #35 of 59 Old 10-27-2013, 06:21 PM Thread Starter
Jeepenjimmy440
Its the best upgrade i did to my Jeep!!!! defiantly way more stronger then the 8.25, there are 800 hp mustangs drag racing with these rears and launching them very hard. My 8.8 came with 4.10 gears and a limited slip differential.
Blue Ribbon Fab
post #36 of 59 Old 10-27-2013, 07:58 PM
lokithecoyote
Where did you acquire your near axle? Did you have to cut it down to fit in on?
The time you enjoy wasting is not wasted time.
lokithecoyote is offline
post #37 of 59 Old 10-27-2013, 09:21 PM
ZSXJ430
2015 KL Cherokee
That looks awesome man. Mine will not be so pretty when it is done...if it ever gets done.
'15 Trailhawk - Eco Green, V6, Nav, Tow, Cold Weather. Wrangler All-Terrain ProGrades 245/70R17.
ZSXJ430 is offline
post #38 of 59 Old 10-28-2013, 03:49 PM Thread Starter
Jeepenjimmy440
I acquired the rear axle from my best buddy asjamison. (the one with the killer mj) I believe he found it on craigslist, also the axle does not require the tubes to be shortened. Thanks for the compliment, mine is slowly getting beat up though from thrashing it around.
Blue Ribbon Fab
post #39 of 59 Old 10-28-2013, 03:56 PM Thread Starter
Jeepenjimmy440
This happened a few weeks ago when asjamison called me a p#ssy and well thank god i had my bumper on or my Jeep would of been on it side!!!!
Blue Ribbon Fab
post #40 of 59 Old 10-28-2013, 09:03 PM
ZSXJ430
2015 KL Cherokee
Yes, you did get lucky.
ZSXJ430 is offline
post #41 of 59 Old 10-28-2013, 09:39 PM
Aaronbeaver
Sweet XJ. I just recently bought a 2dr XJ. What size tires are you running and how critical where the subframe connectors?
Aaronbeaver is offline
post #42 of 59 Old 10-29-2013, 04:46 PM Thread Starter
Jeepenjimmy440
Give it time most likely Ill flip it eventually!!!!! If i do flip it before i make a cage I will cut the roof off and build a hole exo-cage hahahhahaha!!!!!! As for the subframe connectors they where a peace of cake. I had to do some trim work to get them to fit sung to the unibody rails. I used 2 tubes of panel bond from 3m (its as strong as welding) then i welding all the plug welds and grinned it smooth, also i used a heavy body seam sealer around the tie ins and under coated it. Il snap a few pics tonight and show you all.
Blue Ribbon Fab
post #43 of 59 Old 10-29-2013, 08:44 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
spell check! grammer check! ONE TONS!!!!
Jamison
ajamison is offline
post #44 of 59 Old 10-29-2013, 09:33 PM
boatsandhose
Did you have to get a new proportioning valve or master cylinder when you swapped in the 8.8? I'm in the process of building my 8.8 w/discs and I've heard mixed reviews about this.
Also, my rotors are straight and uniform thickness, but they are surface rusted like yours. Should I get them turned or will the rust wear off at the first run of the brakes?
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #45 of 59 Old 10-30-2013, 03:05 PM
ajamison
ajamison's Avatar
1991 MJ Comanche
i helped him with the build, we didnt do anything special with the brakes, just hook up the lines and bleed them. i've swapped 8.8s into 4 or 5 different jeeps and none of them required any type of prop valve or MC upgrade
Jamison
ajamison is offline
