Jeep YJ 4BT Cummins build!! - Page 7 - JeepForum.com
post #91 of 219 Old 08-30-2012, 08:52 PM Thread Starter
CumminsYj88
Transfer case input shaft came in today from advanced adapters,very good quality looks really nice.the reason I need this is because my stock input shaft doesn't have 29 splines,that I need for the nv4500.
Slip yoke eliminator,input shaft,oil,and silicone.ill tear into her this weekend,if I'm lucky ill have my driveline all bolted,juiced up,and maybe bolted in.but there's always problems.ill post what ever I do over the weekend,and any problems I might have.
CumminsYj88 is offline
post #92 of 219 Old 09-01-2012, 10:19 AM
dchilton
This thread makes me want to blow up my 4.0 just to have the excuse...
Hey! Wasn't me.
dchilton is offline
post #93 of 219 Old 09-02-2012, 05:33 PM Thread Starter
CumminsYj88
Haha I know what you mean man,my 2.5 was making me want to shoot my self..everyone asks me why I'm switching engines..obviously they've never owned a jeep.
post #94 of 219 Old 09-02-2012, 05:39 PM Thread Starter
CumminsYj88
Did a lot of work this weekend.put about 10 hours in.so ill start uploading the pictures..
First off I bought a smitybilt vault glove box,it fit right in didn't have to do any modifying,I can now lock my stuff up when I don't have my doors and top on plus it looks kinda cool.
post #95 of 219 Old 09-02-2012, 05:57 PM Thread Starter
CumminsYj88
ForumRunner_20120902_195622.jpg   ForumRunner_20120902_195655.jpg   ForumRunner_20120902_195717.jpg
post #96 of 219 Old 09-02-2012, 06:14 PM Thread Starter
CumminsYj88
Tore into my T-case,had to install sye and 29 spline input shaft,I was happy with the inside it looked really clean,and I checked for ware I couldn't find anything that was going to be a problem.
Had to press bearings out,for the super short shaft they said they weren't necessary and so that's what I did.it spun on the machine surface well so I'm not to worried about that
Here's the planetary gear,and input shaft.theres a little snap ring that you have to remove to get the input shaft out.I was confused and didn't see it at first
Had to cut the 4x4 shift fork,they recommend cutting it down to 9 3/8" so that the sye cover will fit..the stock length is 10 1/2 inches or something like that
After all that I started putting her back together.
post #97 of 219 Old 09-02-2012, 08:51 PM Thread Starter
CumminsYj88
Got fly wheel resurfaced at o'reillys,then tried to shake and shimmy my input shaft in with out a clutch tool.I kept trying and trying,after 30 mins of trying I was so pissed I drove to auto zone in mad rage.the guy at auto zone let me borrow one,and had to return it afterward.but any ways I pit locktight on all the bolts and greased everything
Whole drivetrain is now together and ready to be dropped in. Getting close!!
Click image for larger version
post #98 of 219 Old 09-04-2012, 09:06 AM Thread Starter
CumminsYj88
Called the dodge dealer,it 27$ a quart for transmission fluid,holy hell!!! I need like 4 1/2 quarts..I've searched up and down for fluid at autoparts stores.but no one has anything for the nv4500. evidently they are picky with what fluid you put in them because of the brass syncros.!
post #99 of 219 Old 09-04-2012, 06:33 PM
Luke95
What?
Every dodge ad Chevy manual of thoughs years had a 4500 weird.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #100 of 219 Old 09-04-2012, 11:03 PM
Ripper3494
Attachment 465031
Attachment 465032
Attachment 465036
Attachment 465037
Attachment 465038
Attachment 465038
Attachment 465040
Attachment 465035
your t case looks to be clocked down a ways, maybe its just the picture but it looks down quite a bit further than stock
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #101 of 219 Old 09-05-2012, 05:24 AM
dchilton
The trans fluid id phosphorus free thats why its so expensive. The only aftermarket alternative is amsoil trans fluid. Luckily my 6 speed only takes two quarts
Hey! Wasn't me.
dchilton is offline
post #102 of 219 Old 09-05-2012, 06:23 AM
cbpldc
Great thread! Keep up the good work.
cbpldc is offline
post #103 of 219 Old 09-05-2012, 08:32 AM Thread Starter
CumminsYj88
I'm glad you said something about that.I was wondering the same thing,if I clocked it up one notch I know for a fact it would be to high I tried it that way first and it was like pointing in a very unnatural way...I could be wrong but I think that's how the nv4500 holds their transfer case.I've seen other ppls pics and it looks about the same as mine,and the picture does make it look a lot lower then it is.I was lookin at the pics one night and thought the same thing as you I thought I screwed up.but walked into work that next morning and it looked fine,so the picture does kinda make it look lower then it is..worst case scenario,ill just have to drill new holes in the tail housing...I'm going to keep looking tho to see what other ppl think and have done,thanks for pointing that out.if you find anything out let me know.
post #104 of 219 Old 09-05-2012, 11:03 AM Thread Starter
CumminsYj88
Called advanced adapter,and the guy helping me out said that the nv4500 is clocked about 10 degrees lower then the ax5,that's just how they were made.he said it shouldn't cause any problems.and if anything to save room I could redrill new holes.so ill see what it looks like all bolted in.if I see a problem I might end up redrilling holes,if not ill just leave it like that.
post #105 of 219 Old 09-06-2012, 09:28 AM Thread Starter
CumminsYj88
Got trans fluid from the dealer,the guy cut me a deal and saved me 7 bucks a quart. It came out to be 80$. Not bad from what I've heard other people paying. It even says on the back.. only used for the 5 speed nv4500..,That only makes me at ease.don't have to worry about that any more.
4bt , cummins , jeep , nv4500 , YJ
1998 Jeep TJ "Black Stallion" - 4Cyl Cummins Build Project! SAVAGE-RIDER Jeep Builds 18 09-20-2013 06:39 PM
Cummins in a jeep? grandguy109 Jeep Builds 5 05-12-2012 06:42 AM
Stockish Jeep pulling out Cummins Ram ajf1994 Jeep Picture Requests 3 11-21-2010 10:18 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 03:28 PM
