Jeep YJ 4BT Cummins build!! - Page 6 - JeepForum.com
post #76 of 219 Old 08-08-2012, 04:43 PM Thread Starter
CumminsYj88
GOOD NEWS: the 1st gen intercooler fits like it was made for it.its a tight squeeze from side to side but it fits.the rod support for the grill was a perfect mounting spot.the factory bolts just lined up with it so all I had to do was drop it in.
CumminsYj88 is offline
post #77 of 219 Old 08-08-2012, 04:51 PM Thread Starter
CumminsYj88
BAD NEWS: the starter is right in front of my mount.I knew it wouldn't be easy to fit motor mounts but this can't get any more in my way then it is so I've been thinking of stuff.ill post pictures 2maro of what I fab'd up with some cardboard and see what you guys think.
post #78 of 219 Old 08-08-2012, 04:54 PM Thread Starter
CumminsYj88
BAD NEWS: here's a side to side to give you a better idea of what I'm working with..top left with the starter one,top right with out starter and mount,and the bottom 2 show the mount I got,(yes I knew it wasn't going to fit,just showing where it should be,ill post a picture of what I'm going to make 2maro)
post #79 of 219 Old 08-08-2012, 05:02 PM
Ripper3494
awesome looking build, i thought about doing a diesel when i was building mine but i just loved the sound a healthy v8 too much, my next one will most likely be a cummins build though
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #80 of 219 Old 08-10-2012, 10:41 AM Thread Starter
CumminsYj88
Nice dude,i love the idea of a v8 in a jeep.did you make a build thread?
post #81 of 219 Old 08-10-2012, 10:44 AM Thread Starter
CumminsYj88
Had trouble finding a 90 degree fitting for my powersteering oil feed.but jerry found me one in no time and its perfect!
post #82 of 219 Old 08-15-2012, 10:03 AM Thread Starter
CumminsYj88
Cut the side out of an old forklift.to get metal for my mounts.
post #83 of 219 Old 08-15-2012, 10:13 AM Thread Starter
CumminsYj88
Here's what I ended up making after changing my mind more then once...it seems like its going to be very strong I just need to finish up some welding on it.
post #84 of 219 Old 08-15-2012, 09:27 PM
skursh
I like this build thread a lot. I'm defiantly going to be checking this thread out in the future.
Nice build an good luck
If I could of saw this thread before, I would of told you to rotate the axle so that the pinion is pointing up a little taking some stress off of the driveshaft.
I've been trying to convince my dad to allow me to put the 4bt in my cj, but he won't let me because he doesnt want me to take over the garage. Lol
Its a little late but I was reading they said get a set of v8 motor mounts and move the up 1 inch and the fit. I bet the frame will break/bend before those 6bt mounts do.
A jeep v8 rad will also works great, and mounts to factor grill mounts.
You should put the cj front clip on, it will look a lot better than those square headlights. IMHO
Are you getting tube fenders and flares or just leaving it stock.
skursh is offline
post #85 of 219 Old 08-16-2012, 03:40 PM Thread Starter
CumminsYj88
Thanks for the input man..my axle perch's aren't welded yet so I can still set my pinion angle.I'm going to drop my drive train in and get it all lined up,then make mounts for the motor and trans.after that ill set my pinion angle higher,I ordered a super short sye and tom woods drive shaft.And yeah its a little late to change out motor mounts,I agree,I like the fact of knowing the 6bt mounts will out last anything else. And yes I had thought about the cj front end,I think the cj grill looks better,but I ain't to picky as long as I have a jeep that's able to go off road,and be my dd I'm happy with.I might switch it out in the future.and fender flares,I'm pretty sure I'm going to do away with the stock ones..I want to try and fab up my own fenders,but i might fail.so if all else does fail ill give in and buy some from smity bilt or something.
post #86 of 219 Old 08-16-2012, 04:00 PM
10-3-TJ
Great build man. I will also be watching this closely. Like the work on the motor mounts. Nice work. I am currently putting a 4bt in my TJ.
"We have enough youth, how about a fountain of smart"
"Look no further than yourself, for all of the good and all of the evil that exist in this world, resides in the heart of man and his propensity to use it".
10-3-TJ is offline
post #87 of 219 Old 08-16-2012, 05:26 PM Thread Starter
CumminsYj88
Thanks,are you making a build thread?
post #88 of 219 Old 08-16-2012, 05:31 PM Thread Starter
CumminsYj88
Bought a super short sye from JB conversions..it was 100$ more for the super short,but with the lift I have on my jeep my drive shaft and yokes will appreciate the extra 3 inches..Ill be buying a c/v drive shaft from tom woods soon..well maybe not too soon,I got 2 tickets this week,from a couple of pigs with nothin better to do.smh
post #89 of 219 Old 08-17-2012, 12:54 AM
Ripper3494
yep, though it hasnt been updated in awhile lol http://www.jeepforum.com/forum/f22/9...-spud-1218315/
build thread:
RC vs BDS
post #90 of 219 Old 08-21-2012, 08:57 PM Thread Starter
CumminsYj88
94-97 cummins clutch master cyl won't for in stock location.it would if the brake booster wasn't in the way,but it never works that way,so ill cut a new hole lower.and put a new pin hole in my clutch pedal.
4bt , cummins , jeep , nv4500 , YJ
1998 Jeep TJ "Black Stallion" - 4Cyl Cummins Build Project! SAVAGE-RIDER Jeep Builds 18 09-20-2013 06:39 PM
Cummins in a jeep? grandguy109 Jeep Builds 5 05-12-2012 06:42 AM
Stockish Jeep pulling out Cummins Ram ajf1994 Jeep Picture Requests 3 11-21-2010 10:18 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 03:28 PM
