Jeep YJ 4BT Cummins build!! - Page 15 - JeepForum.com
post #211 of 219 Old 10-23-2013, 08:14 PM
lobi
small world hello from Nicholasville im always looking for someone to go wheeling with holler if you ever want some one else to go with
lobi is offline
post #212 of 219 Old 10-24-2013, 10:30 AM
ThomasYJ
This is so awesome!! Just sat here and read through all of it. Good job on doing a lot of the fab work yourself! Subscribed.
Funny thing is that I've watched your videos so many times looking for Cummins Jeeps on YouTube, before I even found this thread. As soon as I started reading I thought to myself, "I know this Jeep...."
I'm saving up for the swap right now, have my Jeep in storage. With the cost of everything I want to do I'm probably going to have to budget between 15-20 until all is said and done.
On a side note, I'm glad the 3:55 and 35s work out so well. I was leaning between those or 3.73.
I'll be keeping my eye out for more! opcorn:
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #213 of 219 Old 10-25-2013, 05:52 PM
ThomasYJ
Quick question:
What'd you do about the fuel filler, seeing as diesel nozzles are bigger. Just drill it out, or what?
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #214 of 219 Old 11-24-2013, 06:58 PM
Jeep-1995
Cummins YJ
ABSOLUTELY AMAZING!!!!! this is by far the SEXIEST YJ i have ever seen!!!
Dad and I are talking about doing this too. i want to do it basically the exact same but with a hood stack! what millage are you getting and what gearing are you going with?
We had the same idea about pulling a Cummins from a bread truck but we wernt sure about a transmission. i didnt know the 6BT 12 Valve tannies lined up so that helps a lot!! thanks for the great write up and hopefully next summer we will be able to tackle the project!
That is inspiring to see a teenager doing all this, i am 19 and in college and this is my dream build but i always thought older mechanics who owned a shop, were the only ones who got to successfully do this!!
great job once again!!!
90 YJ 4 cyl 5 speed on 35"s
5" lift
99 TJ 6 cyl 5 speed on 32"s
bone stock
Jeep-1995 is offline
post #215 of 219 Old 03-02-2015, 01:26 PM
vespo94
I have a 88 yj with a 4" lift and im planning on using a 4bt and nv4500. Probably gonna run 3.73 gears. What would be a good donor truck for axles and intercooler and all that good stuff? i was thinking ram 2500/3500?
vespo94 is offline
post #216 of 219 Old 03-02-2015, 11:03 PM
y2k-fxst
1964 CJ6
You might want to look into a 1" body lift also for hood clearance so the motor does not have to be down so low.
Seen some guys using the inter-cooler out of the doner bread truck, Audi TTS, or a Izuzu NPR.
For a radiator I am looking at http://www.speedwaymotors.com/Speedw...FUo6gQodYRsAKQ due to the fact that both the inlet and outlet is on the passenger side and I won't have to run the upper radiator hose across like most radiators.
Would stick with the smaller axles like Dana 44's due to the fact you lose so much ground clearance under the pumpkin when you get into 3/4 and 1 ton stuff unless your running 37"+ tires.
Probably not going to get a lot of responses on this thread as it has been dead almost 1.5 years but, at least you are reading!
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline
post #217 of 219 Old 03-03-2015, 05:30 PM
ThomasYJ
What size tires you planning on running? With 3.73 / 4.10 that's a fairly decent ratio for 37s. That's what I'll be putting on mine once I get the tons under my Heep. As for donors, if you dont mind a shorter driver side tube, late 80's early 90's F350 have a 60/ 10.25 combo which is pretty bulletproof. If you outboard your front springs you can keep the axle width as is, if that's what you're going for.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #218 of 219 Old 03-04-2015, 07:36 PM
JuniorsCJ7
1979 CJ7
Just finished reading your build. Awesome job, man. I am west of you in central KY (Leitchfield). Have you taken the Jeep to Black Mountain in Harlan yet? It is a four hour drive from my house, but worth every minute. Keep the pictures, videos, and write-ups coming!
JuniorsCJ7 is offline
post #219 of 219 Old 03-04-2015, 11:17 PM
theend2008
This thread has been dead for a long while. Although I hope he hops on and posts some follow up picks on how it is doing. This monster is truly a beautiful jeep and an inspiration to get my YJ were i want it. Great job on your YJ btw!
theend2008 is offline
4bt , cummins , jeep , nv4500 , YJ
1998 Jeep TJ "Black Stallion" - 4Cyl Cummins Build Project! SAVAGE-RIDER Jeep Builds 18 09-20-2013 06:39 PM
Cummins in a jeep? grandguy109 Jeep Builds 5 05-12-2012 06:42 AM
Stockish Jeep pulling out Cummins Ram ajf1994 Jeep Picture Requests 3 11-21-2010 10:18 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 03:28 PM
