Jeep YJ 4BT Cummins build!! - Page 13 - JeepForum.com
post #181 of 219 Old 10-24-2012, 05:31 PM
Gaducker
1983 CJ8
Originally Posted by CumminsYj88 View Post
Aweesome! Have you had anything break or wear out with that set up.?cuz that's what I'm worried about with mine.I love the torque and speed but just havnt ever messed around with gearing and angles before.not sure what to expect.
I drive mine everyday and nothings broke. I have a scrambler so I have a longer driveshaft and I kept the tcase the same height and distance as it was stock. I am probably close to three thousand miles so far.
Gaducker is offline
post #182 of 219 Old 10-24-2012, 09:34 PM
wvujaw
I want to do this very badly. Question, you mentioned buying a " bread truck" earlier in the build. Can you give me a brief background on that, I'm a newb with little experience when it comes to rebuilds. The thing is defintely bada**! my buddy at work is all about putting a cummins in his now too.
wvujaw is offline
post #183 of 219 Old 10-25-2012, 06:49 AM
bigdhamYJ
You buy a bread truck so that you can have a donor that has the 4bt in it already, and possibly a transmission to use as well. It is good to keep around until your swap is complete because it may have little odd parts here and there that may be hard to find. It eliminates some of the foot work of having to track down all the parts, and they're usually aluminum bodies so when you're done with it you can scrap the body and make some of your money back from buying it and doing the swap!
"Who knew coolant keeps the motor cool?"
Check out my Heep "build"
http://www.jeepforum.com/forum/f22/bigdhamyjs-1993-yj-build-slow-1284516/
bigdhamYJ is offline
post #184 of 219 Old 10-25-2012, 06:50 PM
Gaducker
1983 CJ8
When I bought mine I got it running and drove it back and forth to work for a month so I could make sure the engine was going to be good and have no leaks.
Gaducker is offline
post #185 of 219 Old 11-01-2012, 05:22 PM Thread Starter
CumminsYj88
Took her mudding late Thursday night.had a blast!
CumminsYj88 is offline
post #186 of 219 Old 11-03-2012, 10:59 AM
trabag18
so what springs did you end up using? and which hole on the spring perch did you use for the center pin in the rear? by the way great build man im collecting all my parts todo pretty much the same thing!
trabag18 is offline
post #187 of 219 Old 11-03-2012, 08:22 PM
Wesownsarubicon
1976 CJ7
Dang what a perfect set up man! that thing is so sexy.
Wesownsarubicon is offline
post #188 of 219 Old 11-14-2012, 10:36 AM
Cabbage06
1987 YJ Wrangler
This is THE dream Jeep. I want to do this to mine so badly.
Cabbage06 is offline
post #189 of 219 Old 11-16-2012, 02:36 PM Thread Starter
CumminsYj88
Thanks everyone I love it may have an alternator problem its not keeping a charge.I need to get some doors its starting to get cold
post #190 of 219 Old 11-25-2012, 01:31 PM Thread Starter
CumminsYj88
post #191 of 219 Old 11-25-2012, 04:03 PM
maztj
Nice jeep
maztj is offline
post #192 of 219 Old 12-14-2012, 11:19 AM Thread Starter
CumminsYj88
Heres some more pictures!!
post #193 of 219 Old 12-14-2012, 05:22 PM Thread Starter
CumminsYj88
Semi driver now no big deal lol
post #194 of 219 Old 12-14-2012, 06:10 PM
teamgreen666
Will you put some turn signals back in your grill?
If not I thought it would look cool with some rigid D2 led lights mounted in the grill.
This one badazz YJ , good job.
teamgreen666 is offline
post #195 of 219 Old 12-27-2012, 07:58 PM
Salt222
Nice work, I'm in the process off a 4 bt swap in my 1995 yj rebuilt the motor working on the frame,will post pics,
Salt222 is offline
4bt , cummins , jeep , nv4500 , YJ
1998 Jeep TJ "Black Stallion" - 4Cyl Cummins Build Project! SAVAGE-RIDER Jeep Builds 18 09-20-2013 06:39 PM
Cummins in a jeep? grandguy109 Jeep Builds 5 05-12-2012 06:42 AM
Stockish Jeep pulling out Cummins Ram ajf1994 Jeep Picture Requests 3 11-21-2010 10:18 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 03:28 PM
