Jeep YJ 4BT Cummins build!! - Page 11 - JeepForum.com
post #151 of 219 Old 10-10-2012, 06:00 PM Thread Starter
CumminsYj88
Up date time! So my engine started to sag a bit,turns out I tore my motor mount for installing it up side down,I was going to press the sleeve out and turn it around as soon as I got close to being done.but didn't get around to it.so I had to buy another motor mount from Jamie the cummins guy.came back to the shop pressed the old one out and the new one in,an turned it around.
Sagging drives side on lecturing and what it should look like on the right
Ripped!
Pressing it out
Putting new one in turned 90 degrees.
Much better!!
Then I started on my fuel lines and tanks here's a picture of my fuel pump that went bad and the reason I started this build.if this hadn't of failed I might not have started this project.any ways the green arrow was my original electric pick up tube,took the electric motor out and this will now be my return line for the cummins..the red arrow was the original return line,but now its my pick up tube for the cummins.thought this would be much easier to swap these two then to make an fab a pick up tube,and return line..my fuel gauge works so ill be reusing that.
Here's the tank before and after paint
Some idiot tried to weld a hitch to the thin gas tank skid plate lol so stupid O.o
CumminsYj88 is offline
post #152 of 219 Old 10-10-2012, 08:54 PM Thread Starter
CumminsYj88
Bought a drop pitman ARM but it was for the Dana 30 tie rod.not the Dana 44.turns out Dana 44s have bigger tie rod ends,so I bought a 7.15-1.5 per foot reamer from jegs.an had my grandfather who's a machinist help me out. Here's some pics of it.
Dana 44 tie rod joint,don't fit
7.15 1.5 Reamer
Set up
Finally fits !
post #153 of 219 Old 10-15-2012, 10:50 AM Thread Starter
CumminsYj88
Almost looks like no one has ever changed this brake fluid.so cleaned her up and flushed it..Workin on the jeep tonight hope to make some good progress ill update later.
post #154 of 219 Old 10-15-2012, 11:12 AM
TroubleNEO
No one probably ever has changed that fluid actually. I had an old 84 Suzuki motorcycle and the MC looked like that inside when I got into after buying it.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #155 of 219 Old 10-15-2012, 04:47 PM
owtcast
Admire your work ethic boy. You are probably makng a bunch of old men on here embarrassed. Lol
owtcast is offline
post #156 of 219 Old 10-15-2012, 05:48 PM Thread Starter
CumminsYj88
Hahaha best compliment yet! appreciate it ,I just would rather do it right the first time,expescially with a big project like this.don't want any problems down the road!
post #157 of 219 Old 10-15-2012, 11:40 PM Thread Starter
CumminsYj88
Set pinion angle,welded the spring perches in,ran my front and rear brake lines.and a little shock work today.didn't get the best pictures but here ya go here's some of the drive shaft stuff!
post #158 of 219 Old 10-16-2012, 08:39 AM
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
Great build man!
You are going to love that thing!! I cant wait to get mine back on the road.
Check out my build thread! It may give you some ideas.
My only reccomendation is an intercooler, especially if you plan to make some power out of it.
http://www.jeepforum.com/forum/f12/4...-pics-1275843/
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #159 of 219 Old 10-17-2012, 08:57 AM Thread Starter
CumminsYj88
Originally Posted by youngjeeper11
Great build man!
Yeah I can't wait to get it done,thanks for the link ill check it out.
post #160 of 219 Old 10-17-2012, 09:40 AM Thread Starter
CumminsYj88
Got steering hooked up,and throttle cable fabed up.yesterday nothing was going my way.it was one of thos days where a 15 min job took over and hour.but ill be working tonight too.hopefully I can get more done.hoping to be able to test drive it next week at the latest..I need to weld front perches,put shocks on,bleed brakes,put radiator in,make some power steering tubes,hook up boost gauge,and water temp.and then it should be done,long night at the shop tonight and I may be able to get all that done..
ForumRunner_20121017_103749.jpg   ForumRunner_20121017_103920.jpg   ForumRunner_20121017_103900.jpg
post #161 of 219 Old 10-18-2012, 09:42 AM
Gaducker
1983 CJ8
Dont put your return line there. I put mine there and I could not keep it from pissing air into the tank. I tried extending it also. I had to put it in the neck so it could roll down the filler tube and let the air get out of the fuel before it hits the fuel in the tank. There is alot of air in the fuel from the pump in the return line and it just amplifies the air in the tank the longer you run it.
I had my tank down three times before I decided to do it like that.
The air in the lines would make it hard to start after sitting all night.
I have a p pump so you may or may not have the same return pressure.
Also when its like you have it in the pic when you get low on fuel it is pissing the fuel and air mix right at the pick up and makes it ten times as bad mine would start running rough when I got below a 1/4 of a tank.
Is that pinion bearing gona get lube up to it running that much angle?
Gaducker is offline
post #162 of 219 Old 10-19-2012, 12:43 PM Thread Starter
CumminsYj88
Thanks alot.ill go back and change that when I get the chance..and I'm not sure I put a little more fluid then needed.hopping it might help a little,the picture makes it look like more of an angle then it is..even if it is a bit high,how big of a problem is that.and is there anything to fix it?
post #163 of 219 Old 10-19-2012, 05:43 PM Thread Starter
CumminsYj88
Worked a bunch this week got a lot done.unfortunately my phone camera is not taking pics like it should,they are really blurry.so didn't get to take any good pics of what I've done.ill up load some,just got to get around to getting the camera out and setting at the computer..ok so had some problems with clutch it was way to stiff and short,had a guy named stev'o come out and look at the jeep.he told me my master cyl ARM was at a weird angle,so I straightened that out,and it works a little better now,then got the rest of my wiring done,intake air filter fabd up.radiator brackets made and installed.radiator hoses connected,front spring perch welded,shift boot and floor plate made up..so I've basically only got,shifter,front drive shaft,bleed brakes,put rear shocks on,and throw the fenders on intill I get some tube fenders..other than that its ready to roll some coal.! Test driving it Monday or Tuesday.ill keep you updated.here's one pic that wasn't to blurry.
post #164 of 219 Old 10-19-2012, 08:53 PM
Gaducker
1983 CJ8
As long as you fill hole is at or above the bearing you should be ok. I had one with so much angle that I had to put a fill hole higher up on the diff cover to get it at the same height as the bearing,
Gaducker is offline
post #165 of 219 Old 10-22-2012, 08:31 PM Thread Starter
CumminsYj88
FINALLY!! the cummins lives and drives.it is a beast.1st is like wow,2nd is like a jet,and 3rd is just plan insane..so much power and torque..deff need new gears tho I have 3.07 gears with 37" tires..going to break something if I keep driving like that.but any ways.so much fun.had ppl across the parking lot just stare with a Wtf look lol..ill post a video 2maro!
4bt , cummins , jeep , nv4500 , YJ
1998 Jeep TJ "Black Stallion" - 4Cyl Cummins Build Project! SAVAGE-RIDER Jeep Builds 18 09-20-2013 07:39 PM
Cummins in a jeep? grandguy109 Jeep Builds 5 05-12-2012 07:42 AM
Stockish Jeep pulling out Cummins Ram ajf1994 Jeep Picture Requests 3 11-21-2010 11:18 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 04:28 PM
