Jeep WJ limited 2.7CRD from France :) 4" lift long arm etc... - JeepForum.com
post #1 of 10 Old 01-11-2016, 01:14 PM Thread Starter
10bagger
2003 WJ
hi everybody, I'm pleased to introduce to you my first jeep, and my first 4x4, a wj 2003 with 110000 km, it's a limited, with 2.7crd mercedes engine.
- rough country 4" lift long arm with front quick disco
- 2.5" pitman arm
- fender flares
- moab rims with 285/70r17 cooper stt
- 1.5' spacer at front and 2" spacer at rear
- porsche boxter 4 pot calipers with 328x30 mm rotors at front
- front brake hose
- adcco front and rear sway bar
- tom wood's double cardan front drive shaft
- JKS quick disco at rear
- additional teneco steering stabilizer
I have rebuild the np247 because the front output bearing was dead and I have rebuild the turbo because I'm a paranoid
now I plane to remap the ecu myself, and I also want to use a more modern turbo with 3" exhaust line to have better torque at low rpm. stock it has 163hp and 40mkg at 1800rpm, I think I can have 210hp and 50mkg at 1600 rpm with the proper mod
it may also need rock sliders and a winch
engish is not my mother language, I'm sorry
10bagger is offline
post #2 of 10 Old 01-11-2016, 02:29 PM
pwdrtoastman
jeep looks good....
Your English is better than most of ours and it is our first language.........
pwdrtoastman is offline
post #3 of 10 Old 01-11-2016, 06:14 PM
TexNVa
Originally Posted by pwdrtoastman View Post
jeep looks good....
^ That's a true statement right there!
What an awesome looking WJ and the fact that you have a diesel is even cooler.
If it makes you feel any better, I just started learning French, and my French is AWFUL. Been traveling to Niger, by way of France the last couple of years. Would love to be able to hold a conversation by the next time I go.
Good luck on your build!!
TexNVa is offline
post #4 of 10 Old 01-12-2016, 02:20 AM Thread Starter
10bagger
2003 WJ
many thanks, I think that french is much more difficult to learn than english, and there is much more situation for french peoples to talk english than for american peoples to talk french
many thanks for the jeep, the build is not finished
I would be please to go to niger with my jeep
I was needed a car that can be driven easaly on road and off road, that's why I have choosen the wj, and that's why there is adcco and quick disco everywhere
10bagger is offline
post #5 of 10 Old 01-12-2016, 04:27 AM Thread Starter
10bagger
2003 WJ
I have ordered air bag control modul with part number P56010488AG ( you can have other letters at the end like "D" or "F") to fix the air bag light, my stock P56036792AA is a crap and need to be replaced by P56010488AG for car with side curtains, I think without side curtains you need P56010485AG
10bagger is offline
post #6 of 10 Old 01-12-2016, 03:45 PM
TexNVa
That's a good point, but when in France do as the French right?!
I think most people get a good laugh when they hear how bad my french is
Buddy I would love to get my jeep to Niger, the wheeling in the dry season is SIIIIIIIICK
TexNVa is offline
post #7 of 10 Old 01-13-2016, 01:20 PM Thread Starter
10bagger
2003 WJ
when you come in France I would be pleased to see you, you will speak french and I will speak english and we will laught a lot lol
10bagger is offline
post #8 of 10 Old 01-13-2016, 08:20 PM
TexNVa
hahahahahahaha that would be awesome! Le Muy is beautiful, I'd definitely pass by Paris for Le Muy
TexNVa is offline
post #9 of 10 Old 03-05-2016, 11:58 AM Thread Starter
10bagger
2003 WJ
I need to do some mod on the windshield washer fluid tank to have more room for the 33" tire, and I have seen one hose disconnected, is it for the battery?
10bagger is offline
post #10 of 10 Old 05-15-2016, 11:30 AM Thread Starter
10bagger
2003 WJ
my jeep start to run realy well, the arms lenght given by rough contry in their installation instructions are completly wrong, the drvie shaft angle angle was wrong and the front caster was 9!!!
there is other problem with this kit, I was needed to mod the rear upper arm axle braket because with hight axle flex the ball joint was in contact with the braket, so it unlock the big nut of the ball joint and you have big knock noise at rear
other problem at rear one bolt of this braket was in contact with the upper arm with hight bump first I decide to use to grind the upper arm but it was not enought now I use a countersunk screws
10bagger is offline
