#91 | |
Just violated my Parole
are you going to be doing anything to the front axle? if you're just going to leave it as is id box in the passenger upper control arm mount. it makes it a lot stronger!
#92 | |
Thanks.
![]() Quote:
#93 |
Steering box and track bar mounts:
#94 |
a few more
#95 |
All painted up and looking pretty in the rear, in the first 3 pics you can see the extra piece of "frame" we welded in between the t-case crossmember and the rear lower control arm mounts. That extra piece will prevent hang ups on large rocks since there is a nice flat surface there from the front control arms back to the rear ones now.
![]() ![]() ![]() ![]() ![]() ![]() here is the front all painted up nicely ![]() ![]() ![]() Front with long arms mounted ![]() ![]() |
#96 |
The rear spring perches moved back a few inches for the correct angles
![]() The upper coilover mounts. It is hard to tell but there are gussets on the corners and a gusset that joins the tabs together. ![]() ![]() The lower coilover mounts are nice and boxed in. ![]() The track bar mount was resized for the wider RE track bar and then beefed up. ![]() ![]() |
#97 |
Close...
#98 |
testing... testing...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Didn't have the rear shocks on, but it looks like limiting strap are probably in my future because the rig had more room to flex... |
#99 |
some more...
#100 |
These are some measurements to give you guys a better idea of how the jeep is sitting
28" - center of hub to bottom of fender flare 26" - ground to bottom outer edge of rock rails 20.25" - ground to rear control arm mounts 21.75" - ground to new beefed up frame rails 81" - ground to the top of the jeep |
#101 |
wow, that thing is a freakin monster. looks amazing. hurry up and get that thing done and post up some pics of the first run!
-Justin | Bruised LJ Build |
#102 |
That looks great man.
2002 Grand Cherokee Limited 2004 Chevrolet Tahoe Z71 USN Jeep Club #115
#103 |
That is seriously bad ***! I love it!
Daniel 1 Ton WJ Build In Progress The Daily: 2011 Chevy Cruze Eco - Bone stock and 37 MPG Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers and more to come... YouTube. - My Video Channel facebook. - Wheeling pictures and videos. The Jeep Wave. Bringing it back. For Sale Now: - Clayton 6" Springs - Bilstein 5100 Series Shocks (6" lift) For Sale Later (once I get my swap done): - Brand New WJ JKS Track Bar - Stock WJ Suspension Components - KOR 2.5" BB Lift - Many WJ Drivetrain Components (PM for details) |
#104 |
Those new MTR's are growing on me and wow that looks awesome
RC 4.5" with ADJ. Trac Bar 33" Pro Comp Xtreme M/T on Cragar Soft 8's FlowMaster HD Super 44 with Dual Turndowns 2 12" Alpine Type R's - 2600W Amp |
#105 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
