Quantcast Jeep SAS Project - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeep SAS Project
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 08-12-2009, 06:17 PM   #61
justanotherjpr
Will you be running without a track bar in the rear?
justanotherjpr is offline   Reply With Quote
Old 08-12-2009, 06:21 PM   #62
mikes_muse
Originally Posted by ohvkj View Post
lol...hey mike how much were the 264 ome's?
The 864 rear springs were $75 use from JJ. I still need to get you that measurement. What did you want me to measure? Hub center to bottom fender?
Yeah, just the 4 link rear. Radius arm front with track bar.
mikes_muse is offline   Reply With Quote
Old 08-12-2009, 06:27 PM   #63
mikes_muse
weird and old double post...
Old 08-13-2009, 01:53 PM   #64
ohvkj
um center wheel to top of the flair where the body bends... my flairs are cut so that would be the best
02 TJ locked and low on 33" tires
98 XJ DD
Old Jeep(Sold)03 SAS Liberty KJ,
[b]Wish my jeep was like a Che-a Pet, Add water and watch it grow[/b]
ohvkj is offline   Reply With Quote
Old 08-13-2009, 02:48 PM   #65
Air Sierra
Right now with no spare tire and newly installed springs it's 32.5"
YES My old jeep is RUNNING A 2.4L TURBO MOTOR If you want to know http://www.reno4x4.com/forum/turbocharged-2-4-me-t5362.html?t=5362
Air Sierra is offline   Reply With Quote
Old 08-13-2009, 04:57 PM   #66
mikes_muse
Thanks Chris.
Old 08-14-2009, 09:06 AM   #67
ohvkj
yeah were the same... now to find a place to get those springs
98 XJ DD
Old 08-14-2009, 01:58 PM   #68
mikes_muse
DPG offroad sells OME stuff, maybe he can get them.
Old 08-14-2009, 06:47 PM   #69
mikes_muse
Depending on how these ride, I may go to the OME 863s. Same size spring, but a lighter duty spring rate. Not sure the exact pound difference though.
Old 08-19-2009, 09:09 PM   #70
mikes_muse
Nothing really new to report, but I did get my new winch last night. It is stinkin nice. Not sure if I will wait until the jeep is done to install it. I might see if it is cool with Chris if I head to his shop and install it while he and his guy work on the rest of the jeep...
Old 08-19-2009, 10:36 PM   #71
ohvkj
cool... i will be having lots of weight later so i'll go w/ the 864's
98 XJ DD
Old 08-27-2009, 12:26 AM   #72
mikes_muse
The brackets you see in this pic will be welded to the unibody frame of the jeep. The crossmember will bolt in directly over this plate. You may notice that the front long arm mounts are actually backwards, as they face the same direction as the rear bracket mounts, rather than cut the crossmember to get them to fit facing the traditional way, Chris and I decided to flip them and weld them in that way. They won't be skidded like the rear will but I decided I'd rather lose that option than cut into the crossmember and have a massive piece of steel I'd have to remove in order to work on the t-case. This way the plate and long arm mounts are more solid too than if they bolted up like they would have. Should be done this week/weekend.
Old 08-27-2009, 12:45 PM   #73
mikes_muse
The 250 and 350 coils are too soft, that little experiment is over and I am going with the 450 and 550 springs. The unibody up front in the fender wells, needs to be trimmed. The wheel spacers are not on in these shots by the way. The support between the rear mount brackets and the cross member still needs to be made, the rear gears, the track bar bracket, the steering box and the custom skid all need to be done still.
Old 08-27-2009, 12:47 PM   #74
Apex
Recon death squad
Apex's Avatar
This thing brings the hotness...amazing project good sir
SOLDSilver 02 TJ Apex Edition. "Pandora"
3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff
IndyORV
Apex is offline   Reply With Quote
Old 08-27-2009, 12:53 PM   #75
spyder6
Just violated my Parole
spyder6's Avatar
i like how far the front axle is pushed forward. looks great!
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Glock Forum
