Jeep I6 dualexhaust question - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Jeep I6 dualexhaust question
RIGID LED Light Blowout Sale - All Sizes, All Series, all ECGS Black Friday Sale!!6th Annual, Beat Your Wife to the Credit Card Sale!
Unread 11-16-2014, 12:41 AM   #1
JeepxjLife
Was looking online at the pacesetter exhaust manifold for the 4.0 it splits the pipe 3 cylinders per pipe then Y pipe into single again if I could make true duals off the manifold would I be losing too much back pressure does the 4.0 need the back pressure ? Or should I go with most flow possible ?
JeepxjLife is offline   Reply With Quote Quick reply to this message
Unread 11-16-2014, 12:48 AM   #2
baktie_91YJ
You need a 99+ computer to do this, as it has two O2 upstream sensors. A 4.0 with only one upstream O2 will not be able to do this. To answer the backpressure question, you can still use mufflers/catalytic converters to have the same amount of backpressure, but this mod would be very useful for street/high flow use
baktie_91YJ is offline   Reply With Quote Quick reply to this message
Unread 11-16-2014, 12:59 AM   #3
JeepxjLife
It's on a 94 xj the pacesetter exhaust manifold has the first upstream o2 on the rear part at the top of the manifold only on the one side and the down stream one right at the y pipe back into the single would a nice x pipe with the o2 in the middle of it work in place of the y pipe ?
