jeep build cj3 - JeepForum.com
post #1 of 4 Old 06-19-2017, 12:13 PM Thread Starter
khanhhoa
jeep build cj3
I am looking to put a 4 cylinder turbo diesel, either a cummins or an Isuzu in a jeep cj3a, I am trying to find out if there is a bellhousing that will fit the engine and bolt to a standard T-90 three speed transmission on the market.
khanhhoa is offline
post #2 of 4 Old 06-19-2017, 12:51 PM
CGrugger
CGrugger's Avatar
I am not all to familiar with the older jeeps, but I know danielbuck put a little diesel in his 46 willies and enjoys it.
Sent from my SM-G935V using Tapatalk
2005 TJ X: 2" RE spacer lift, 32"x11.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #3 of 4 Old 06-19-2017, 01:09 PM
jrallen
The problem you'll have with the T90 is it's very short overall length; either the shifter will be in the firewall, or the motor will be. I don't think you'll find any off the shelf bell housing for it either, or at least Novak doesn't have any info on it. Have you considered an SM465? Still a little on the short side so you'll likely have to make a long shifter with a bend in it to get it out of the dash, but at least you'll be able to find a bell housing.
jrallen is online now
post #4 of 4 Old 06-20-2017, 10:03 PM
holliewood61
1981 CJ7
I would do a mercedes om617 and an ax15 trans if i were looking to do a diesel swap. The om617 is much smoother and quieter than a cummins 4bt and with an overdrive trans you could look to get 30+ mpg with tons of torque.
holliewood61 is offline
