IROCk build thread - JeepForum.com
 5Likes
post #1 of 136 Old 03-05-2013, 01:15 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
IROCk build thread
Ok so tired of starting new threads when I am doing some thing with my jeep time to consolodate. So I will from now on be posting in this so SUBSCRIBE
Here are some of the links of my adventures so far:
Replacing 305 with 350
http://www.jeepforum.com/forum/f12/r...-350-a-747494/
Gas tank swap
http://www.jeepforum.com/forum/f12/g...k-swap-854035/
Auto (700R4) to 5 speed (MG5) swap & TJ Brake booster upgrade
http://www.jeepforum.com/forum/f12/l...rsion-1430055/
Home brew power brake blead
http://www.jeepforum.com/forum/f12/p...l#post15008899
On to todays question. Im in the process for gathering parts on for an 8.8 swap. I ran across the teraflex upper adjustable rear shock mounts for $24.99 normally $126.99. Should I jump on it? Does anyone have it? Do you like it? Problems? I know I can build my own, but that seems pretty cheap.
EDIT: seems like these could cause issues with an anti wrap bar. I may have answered my own question
Double EDIT: Inserting to keep first page updated:
Local thread that I use to keep my build updated:
http://www.matanzasjeepclub.org/foru...php?f=7&t=2771
Rig: 1987 AMC Wrangler (Black)
Engine: IROC 5.7L Tuned Port Injection, Freshly rebuilt with less than 3K miles on it
Transmission: NV4500 MT8 5 speed (internal slave)
Transfercase: NP241C
Axles: D30 Locked/Ford 8.8 LSD 4.10 gears
Wheels: 17x9 Mayhem Tank
Tires: 315/70r17 Nitto Dune Grappers
Lift: SOA HD 0" springs, 1/2" booms
Mods: Updated 10-12-16
Suspension/Steering:
JB 4x4 (front) / Ruffstuff (rear) SOA spring perches
Procomp MX6 Remote reservoir front shocks
Energy Suspension poly sway bar bushings
JB4x4 Crossover steering
DOM Tierod w/ GM 1 ton offset TRE's
Crown HD 6 leaf springs
Ground & Pound ” Boomerang Shackles
Home built drag link (1/4" wall DOM)
Prothane 1" Body lift
Drive Train:
Advance Adapters SBC engine mount
Home built above frame transmission cross member with poly bushings
Energy Suspension poly motor mounts
Ruffstuff 8.8 differential cover
Cutthroat 4x4 NP241 clocking ring
JB Super Short SYE w/ 1310 CV yoke
Adams CV driveshaft (clearanced CV)
MSD Street fire Coil
Summit 8mm Wires
Performance cam
Corvette 2.5” Rams horn manifolds
Home built 2.5" mandrel bent y-pipe and Exhaust
Highflow Catalytic converter
Magnaflow Stainless muffler
Home built cold air intake
K&N filter
Outerwears Prefilter
Performance Camshaft
Oil pump pick up retainer
Home built Transfer case shift linkage
Performance stacked 8.8 LSD clutches
8.8 Lube locker
Ruffstuff DIY traction bar
Home Built CV front Drive shaft
D30 Lokka Locker
TJ axle shaft upgrade
Home built CAD block off plate
Recovery/Armor:
Family style roll bars
Skyjacker grab handles
Tow hooks
Warn 9.5XP w/ solenoid box relocation
Chassis Unlimited hawse fairlead
Am-steel synthetic rope
Pro-Link loaded thimble
In cab winch controls
Pro-comp front bumper w/ shackle mounts
Warrior stinger/grill hoop/winch mount
High lift jack w/ Isolator
D-Ring Shackles all 4 corners
Barnes 4x4 ” flat skid
Home built rear bumper/spare tire carrier w/ 2" receiver
30,000 lb. Tow rope
Smitty Built Snatch block
LED Flood lights
LED Spot lights
LED Eagle eye Rock lights
Interior:
Smitty Built security console
Alpine 9884 CD/Mp3 player
Polk DB461P dash speakers
Sound wedges w/6x9 Pioneer speakers
Overhead 4" wedges with tweeters
Rockville 10" powered subwoofer w/ 4AWG wiring
Dakota SGI-5 signal generator (speedo correction)
Half steel doors
Half soft doors
Black Quadra-Top
Chevy K1500 transfer case shifter housing
Carling engine fan kill switch
Carling Fog/Spot switch
Grant Steering wheel
Autometer gauge bezels
Autometer Ultra-lite gauges with LED lights (Tach, Speedo, Fuel, Vacuum, Volt, Temp, Oil press)
Contour V carling switches (Winch power, Winch In/Out, Engine Fan, Fog/Spot, Rock lights)
Rugged Ridge racing seats
Cobra CB
JeepAir A/C
A/C compressor relocation brackets
Sanden 7 piston A?C compressor
Miscellaneous:
Astro van hydroboost
Corvette Master Cylinder
Derale 10" Aluminum Power steering heat sink
Remote power steering heat sink
Power steering filter
TJ fender flairs
Steel braided front brake lines
20 gallon gas tank upgrade
Body mounted bottle opener
Home built Battery tray
DieHard Platinum AGM Group 65 Battery
140A CS144 Alternator
Champion 3 Core aluminum Radiator w/ Stainless overflow
Ford Contour Dual Fan w/ FAL variable speed controller
Home built wooden trunk deck lid
H4 headlight conversion
H4 headlight relay upgrade
Fire Stick CB antenna
Under hood tool box
300A battery bus bar
Under hood accessory fuse block
Mechanical Fuel pressure gauge
LED interior overhead lighting
SpiderWeb Shade
Cowl vent scoop
Future Mods:
1 tons
Links
Roll cage
YJ 350TPI NV4500 (D60 14BFF in process)
87TPIYJ is offline
post #2 of 136 Old 03-05-2013, 01:33 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's cheap and I run one but I haven't thought about it interfering with an antiwrap bar at all. There are three positions to adjust the shocks so I'm sure you could work around it.
Luck Favours The Prepared
Anticanman is offline
post #3 of 136 Old 03-05-2013, 01:38 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Is $126 normal price or is this one of those bs over price stuff to make it look like its on sale? Ive never really priced them out before. Anti- do you see any added benefits over using the stock mounts?
Anyone know where to get the best price on spicer 2-2-1379? I know I found them before for under $20, but Im having trouble now.
87TPIYJ is offline
post #4 of 136 Old 03-05-2013, 02:08 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
For the 8.8 swap its tough to get shocks that work unless they hang down like the stock Dana 35 and catch on everything. There just isn't enough room for the travel needed even with huge springs. I like mine but I'm also looking at a spring over in the rear soon so that will change the game up a little. And that is the best price on it. If you order it anywhere else its way too expensive. Don't forget the lower mounts too.
post #5 of 136 Old 03-05-2013, 09:18 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
OT but my jeep related. I scored some seat belts to today on fleabay. When I swapped roll-bars with a buddy back in Charlotte I forgot to swap the rear female belts that bolt to the floor. Didn't realize the sport style lap belt females were twice as long. Basically making the shoulder strap useless. Although I do have future plans for TJ roll-bar/soft top swap. YJ soft tops are just to much of a PITA to put up and down by yourself. Plus it will match the newly installed TJ fenders
87TPIYJ is offline
post #6 of 136 Old 03-07-2013, 07:35 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
So what welders are people using? In looking to buy a welder cause I wouldn't trust my harbor freight stick welder to soldier a wire! Anyways I'm starting to do research an educate myself better on them. I don't want to completely break the bank getting some crazy 400A welder. It will be used for odds and ends. More importantly it will be used for my 8.8 swap and SOA. Then bumpers and what ever else I can think of down the road. I was looking at a MIG, but I've heard different stories on how big. I've heard for my purposes I would need at least a 150A and I've also heard I should at least get a 220A and i would be better off with stick. What's you guys opinion? What do y'all use for your rig? Thanks!
87TPIYJ is offline
post #7 of 136 Old 03-09-2013, 10:33 AM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Welders anyone???
I ordered a front female buckle out of the 92-95 from ebay. It has a bend in the plastic casing. Has anyone fixed this before? I am not sure if it is a thermoplastic. I have some ideas either heatgun or if I can manage to get the seatbelt out then maybe try putting the plastic in boiling water to try to soften it so I can reset it straight. Has anyone tried this???
87TPIYJ is offline
post #8 of 136 Old 03-09-2013, 11:55 AM
skyj
I personally like my MIG. It's a Lincoln 180 runs on 220v. It works great for welding anything small or big. Lots of guys use a 110v but you got to be careful with what you get, as you have found out with your harbor freight one. I started out learning on our ranch with a stick, then taught myself with a MIG. They are super easy to use and welds look much better than my stick welds. I like the Lincoln since its a very affordable welder but can still weld on par with a Miller or Hobart.
build thread:
skyj is offline
post #9 of 136 Old 03-09-2013, 12:36 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I was looking at the Lincoln 180 dual (mig). It can use 220v or 110V. I liked that because of flexibility of power. I just wonder if its as good as the true 220v. The only thing that sucks is its $900. I have seen the lincoln 140 around $400. Its a 110V welder. Would that be sufficient? Or do you think a 180A would be the minimum I need?
Side note I used a hair dryer to heat up the seatbelt casing and it worked like a charm to reform it
87TPIYJ is offline
post #10 of 136 Old 03-09-2013, 01:23 PM
soonermatt
If you have an outlet and enough money you should do a Miller/Lincoln/Hobart 180 MIG. If you need to go cheaper, I strongly recommend the Hobart 135 MIG. It can lay strong welds with good penetration to that 8.8 axle. You just have to go full power, low speed, .35 wire and I use CO2 for my hotter stuff. It has a much lower cycle life due to running hot but gets it done.
And before anyone questions my welds, yes I've done plenty of bad welds so I know the difference. I started out with pretty and weak welds. Then I started laying really ugly and strong welds. Now they are unintentionally looking better as I focus on heat, pushing/pulling, puddle, proper wire, line speed, prep, etc. It turns out the machine has been very capable...I was the problem,
soonermatt is offline
post #11 of 136 Old 03-09-2013, 05:14 PM
USMCBuckWild
This.
I put the shock tabs near the top of the tube on my 8.8. Seem to work just fine
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #12 of 136 Old 03-17-2013, 02:44 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Today was a great day. I finally went through my first tank of gas since swapping the transmission, fixing the vacuum leaks, and fixing a all the check engine lights. For the first time since u have owned my jeep (2004) I got over 200 miles to the tank. I ended up with 12.9 mpg. That is a far cry from the, 6 mpg I was getting before and I definitely wasn't light on the skinny pedal. I know the 4.10's are to tall for the v8 I'm sure I would get better mpg with 3.73's, but for me awesome day
87TPIYJ is offline
post #13 of 136 Old 04-24-2013, 09:12 AM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Well she's been running good so no new build update. However if anyone is within a days drive of Daytona FL then I definatly suggest they go to Jeep Beach this weekend! http://www.jeepbeach.com/index.html check it out! Its going to be awesome!
87TPIYJ is offline
post #14 of 136 Old 04-28-2013, 07:34 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Just a few shots from this weekend. It was awesome!
getting pulled off the course. I broke the d/s at the beginning of the course.
line to get on the beach
x2
never in my life seen so many jeeps (behind)
(infront)
all in all it was an awesome weekend! Hope to see some of you guys down there next year representing the YJ's
87TPIYJ is offline
post #15 of 136 Old 04-28-2013, 10:23 PM
Que89YJ
Great pics. I know that beach!
Que89YJ is online now
