Installing zone 4.25 combo lift - JeepForum.com
post #1 of 2 Old 03-03-2014, 03:32 PM Thread Starter
junglej46
Hey guys I bought the zone combo lift for my 2006 tj wrangler and I am going to be installing it soon. Has anyone had any problems installing this lift that I can hopefully avoid? I heard the body lift bolts in the front are a pain and sometimes snap. Anyone else experience this? Any advice is appreciated. Thanks
junglej46 is offline
post #2 of 2 Old 03-03-2014, 03:57 PM
IceKnight
Seeing as how you are in the rust belt, I would suggest first soak every bolt you need to remove with PB Lube or something similar a few times before getting into things let it sit and work its way in. Don't hulk out the on the body bolts either if they seem stuck, I would suggest using a rubber mallet and with your ratchet, giving it a few wraps while keeping turning pressure, this might give it the shaking loose it needs to come loose without breaking. Check and recheck to make sure you have the needed parts and then putting things back together use some copper anti-seize to make removing next time a little easier.
IceKnight is offline
