Impact Orange LJ - Page 65 - JeepForum.com
post #961 of 1924 Old 07-22-2013, 12:44 PM
MWV247
Check this out until then. http://www.jeepforum.com/forum/f9/tj...et-qs-1279778/
MWV247 is offline
post #962 of 1924 Old 07-22-2013, 02:12 PM
Holaday
This is what mine will look like. Mocking it up it looks like my DL will interfere with my Antirock. I will get you full bump pics by Wednesday
Holaday is offline
post #963 of 1924 Old 07-22-2013, 02:45 PM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Thanks and now I can see where the sway bar links could interfere with the high steer knuckle/drag link mount.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #964 of 1924 Old 07-22-2013, 06:01 PM
Holaday
Depending how you setup ur steering ur draglink could hit the stock swaybar mount. Just grab Blaine's raised swaybar mounts and u should be fine.
Where can i find this?
Holaday is offline
post #965 of 1924 Old 07-22-2013, 06:05 PM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
http://shop.blackmagicbrakes.com/Rai...Mounts_c40.htm
16 Taco
dayriesw is offline
post #966 of 1924 Old 07-23-2013, 08:22 AM
Holaday
Thank you
Holaday is offline
post #967 of 1924 Old 07-25-2013, 08:32 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
http://www.fjcruiserforums.com/forum...d-upgrade.html
Gonna try and do this so I don't keep blowing solenoids due to what the article calls warn's 1940s designs.
16 Taco
dayriesw is offline
post #968 of 1924 Old 07-25-2013, 08:41 AM
AngryTJ
Decide anything on the steering?
AngryTJ is offline
post #969 of 1924 Old 07-25-2013, 08:42 AM
Imped
Imped's Avatar
Don't sacrifice your sway bar for a different steering setup........
But FYI, you don't have to. There is always a way to make everything fit. Look at how Hendrix did his on the truck and also take a look at Blaine's WJ swaps. There's always a way.
OlllllllO
IndyORV
Imped is offline
post #970 of 1924 Old 07-25-2013, 09:36 AM
USMCHarleyJeepG
nice build
USMCHarleyJeepG is offline
post #971 of 1924 Old 07-25-2013, 10:10 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I haven't decided anything. I will be at the jy this weekend.
I will have the torsion bar on the axle housing itself before the AR comes off the jeep. I love that little sucker too much to let it go. I mentioned doing something similar to Hendrix's on the previous page of the build. I also watched UA 07 last night where two people were running the exact same setup (single shear, sleeved bolt mounted to the top of the axle housing). All of the setups like this (that I have seen) have used coilover on the front ends tho, so I am not sure exactly how it will work to get the trackbar past the coils on my rig.
I have not studied to many of Blaine's swaps. If you have a link, I would love to take a look. I will google it too.
Originally Posted by USMCHarleyJeepG View Post
nice build
Thanks.
16 Taco
dayriesw is offline
post #972 of 1924 Old 07-25-2013, 10:26 AM
McChillen
Jeep looks good, hope you figure out the steering!
McChillen is offline
post #973 of 1924 Old 07-25-2013, 01:02 PM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Me too.
16 Taco
dayriesw is offline
post #974 of 1924 Old 07-26-2013, 09:26 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Well, maybe this TB will work and I will not have to change my steering and all that other junk involved with it.
http://www.currieenterprises.com/ces...t.aspx?id=3488
It is specific to the dana 30 with 2" of lift made for clearance. Only problem is, it will require drilling. So if this doesn't work, I will be in the custom category for sure.
16 Taco
dayriesw is offline
post #975 of 1924 Old 07-26-2013, 06:32 PM
LA-Sahara
What trackbar are you running currently? Just got to drill the taper out the frame mount. If you have to go back, I think they make inserts.
LA-Sahara is offline
Closed Thread
Impact Orange Jeep Rjsimms Jeep Picture Requests 50 03-31-2013 06:29 PM
Impact Orange, AC Orange, or Intense Blue. 4x4Mudmonster Jeep Picture Requests 4 08-04-2009 09:19 PM
My New Toy: Impact Orange TJ RHD Chalice Jeep Builds 15 07-21-2006 09:16 PM
Impact Orange Scoobert Jeep Picture Requests 4 10-24-2005 02:41 PM
