Impact Orange LJ - Page 52 - JeepForum.com
post #766 of 1924 Old 05-21-2013, 07:31 PM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Well, my angle measurement on top of the ball joint was not at 8*... Mine was at 10* & 12* but they were super dirty. So I measured the angle of the disk brake which was a few degrees out of wrack.
So I kept removing parts. At the knuckle, it was off 1 degree on drivers side.
And exactly at 0/90* on the passanger side.
I pulled everything out of the housing but couldn't go any further when I got the the tre/knuckle connection. I have the 3 sizes of pickle forks that I rented and used the smallest size with no results. I need to get a bigger hammer I think.
The unit bearings are loose. So I think I found the problem. I assume the last bit on the passanger side is front the ball joints.
I'll probably paint the knuckles when they are off and touch up the last little bit of the axle with por 15 once they are off. More to come soon on this and I have a package coming in on Friday that I have been looking for since I had a CJ.... I will have to retrofit it to use it on the LJ. Here is the hint:
There are two
They are discontinued
I just sold a set of very similar item
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #767 of 1924 Old 05-21-2013, 08:24 PM
G Beasley
I suspect the lowers are going to have some play once you get them loose. You can leave the knuckle attached to the TRE if you want , just do one side at a time and let the side you are working on sit on the ground . If not try tapping the knuckle beside the tre as you use the pickle fork . This will usually pop the tre out .
There are two
Riddles make my head hurt after a day like today but my guess is chrome curb feelers . One last thing , the OTC angled adapter is my new favorite tool . It took me 25 minutes to tear down the complete passenger side and about 15 minutes per ball joint to press them back in versus the debacle I had on the drivers side .
G Beasley is offline
post #768 of 1924 Old 05-21-2013, 08:26 PM
G Beasley
Originally Posted by LA-Sahara View Post
Yup, changed the ball joints using the advance tool with the numerous adapters. Not exactly sure which is the dodge adapter (supposedly angled on the bottom of the C's?) but there were angled adapters that worked.
I had the HF set and looked at the Advance set and neither of them had the angled adapter that I ordered in . I agree a press and the kit are something you wont use often , but that funky little angled adapter was worth its weight in gold to me when the ball joints popped out and pressed right back in .
post #769 of 1924 Old 05-21-2013, 08:49 PM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I want to remove the knuckles and get them sand blasted to paint. I will try again to remove the tre but if I can't, I will do what you said above GB.
Not chrome curb feelers.... I wish (besides mine would be flat black). Another hint, they are black but will be redone to match my current black.
16 Taco
dayriesw is offline
post #770 of 1924 Old 05-22-2013, 02:12 AM
H3lzsn1p3r
put the nut on the tre backwards till the threads are flush with the bottom of the nut and pound it out the tre is still useable if done right
Hehehe...SoccerLockers. That's what I'm calling Obvious Moms in Rubicons from now on.
91 yj renegade
98 ram 1500
H3lzsn1p3r is offline
post #771 of 1924 Old 05-22-2013, 09:07 AM
monsonman
monsonman's Avatar
not sure what your mystery package could be. twin stick? no thats not it.
When the hell are you gonna paint the damn hood
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #772 of 1924 Old 05-22-2013, 10:02 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I did try this with no luck but it was a small hammer.
Less technical. More hints to come.
And not until after the first ride just incase I roll it
Seriously, there is a little show here in late september that I might enter it in, so by then I guess.
16 Taco
dayriesw is offline
post #773 of 1924 Old 05-22-2013, 10:58 AM
H3lzsn1p3r
BFH is a must
91 yj renegade
98 ram 1500
post #774 of 1924 Old 05-22-2013, 12:32 PM
LA-Sahara
You could try one of these. http://shop.advanceautoparts.com/web...man+arm+puller
I used it on my driver side knuckle, but couldn't on my passenger (if I remember correctly). Just used a hammer on the other one.
LA-Sahara is offline
post #775 of 1924 Old 05-22-2013, 09:57 PM
G Beasley
http://www.amazon.com/Lisle-41500-Fo.../dp/B0002SRG4S
This adapter set and a cheap air chisel will pop a tre out with no cussing involved .
post #776 of 1924 Old 05-23-2013, 09:25 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
BFH is a must
Didn't have it with me then.... Working at the non-home shop has its drawbacks, but I have it with me today.
I might have to go with this if the air hammer I borrowed yesterday don't work out.... or work at all, it looks old.
That is what I rented. Works with a big hammer or air hammer. Looking forward to it tonight.
16 Taco
dayriesw is offline
post #777 of 1924 Old 05-23-2013, 09:27 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Another hint. These are required by law in this state but I rarely use them or have them with me..... Pretty big hint.
16 Taco
dayriesw is offline
post #778 of 1924 Old 05-23-2013, 09:32 AM
monsonman
monsonman's Avatar
i know
'98 TJ- build:
post #779 of 1924 Old 05-23-2013, 09:32 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
i know
Like I said.... Big hint.
16 Taco
dayriesw is offline
post #780 of 1924 Old 05-23-2013, 10:08 AM
LA-Sahara
i know
x2. I think...
Closed Thread
Impact Orange Jeep Rjsimms Jeep Picture Requests 50 03-31-2013 07:29 PM
Impact Orange, AC Orange, or Intense Blue. 4x4Mudmonster Jeep Picture Requests 4 08-04-2009 10:19 PM
My New Toy: Impact Orange TJ RHD Chalice Jeep Builds 15 07-21-2006 10:16 PM
Impact Orange Scoobert Jeep Picture Requests 4 10-24-2005 03:41 PM
