The "I do everything with it" TJ Jeep - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > The "I do everything with it" TJ Jeep
**new!!** pandemic-usa led pod lights!! Siiiiick!!!07-15 JEEP JK Inner axle tube SleevesBead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 07-08-2014, 05:35 PM   #1
chunk9
Been planning on making this thread...
This is a RHD Jeep, that is my DD, AND is used on a mail route. It gets its share of abuse. I am also on a budget to build it, but would like to make what I do high quality stuff. So, it will likely be a VERY slow build. I also have to use it during the day for work on a mail route, so the work can't take the Jeep off the road for long periods of time. A Jeep with VERY tough constraints, if you will.
Also taking ideas on what to put on it!
chunk9 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2014, 05:38 PM   #2
chunk9
First things first, when spring came, I got a soft top for it. Also installed mudcakes for this pic!
Unread 07-08-2014, 05:41 PM   #3
chunk9
Next step, speakers. One of the front ones blew, so I went for those first. Went with 5.25" Pioneer 3-ways. Kinda brighter, but WAY better than having one blown.
Unread 07-09-2014, 12:12 AM   #4
EmeraldGreenXJ
Subscribed! Excited to see what you have planned for this!
EmeraldGreenXJ is offline   Reply With Quote Quick reply to this message
Unread 07-10-2014, 02:40 PM   #5
chunk9
Been planning the whole sound system; the rest of it will have to hold off for now. Gotta fix a transmission issue, then next mod will be a transmission cooler/thermostat. Jeez, I think I might need that ASAP...
Unread 09-14-2014, 11:30 AM   #6
chunk9
Had to add a metal plate to my hard top. Work requires a strobe light on the roof. I don't want to permanently mount the strobe, and the strobe has a good magnet
Unread 09-14-2014, 11:31 AM   #7
chunk9
Added grab handles
Unread 09-14-2014, 11:34 AM   #8
chunk9
Put 6.5" speakers in the sound bar. It was a bit of a pain, since I removed the "step" as well. Luckily, these speakers came with an adapter for a different vehicle that I could use to hold them in.
Unread 09-14-2014, 11:39 AM   #9
chunk9
Also, found out it needed a new transmission. Ugh, wasn't happy to spend that on it, but we had to.
Unread 09-16-2014, 11:25 AM   #10
EmeraldGreenXJ
What happened with the transmission that you needed to replace it?
HIS-2001 WJ 4.0L, 242, 2" Lift, 32s
HERS- 2004 WJ 4.0L AWD- Stock
Unread 09-17-2014, 02:18 PM   #11
chunk9
It was getting stuck into the infamous P1776 "limp mode" code frequently. The transmission fluid was also starting to smell burnt. Had it looked at, and they said it needed replaced, although I feel that's a bit of a cop-out.
Unread 09-17-2014, 06:32 PM   #12
EmeraldGreenXJ
Yeah, I recently sold my beloved XJ because I was told it needed a $300 Transmission repair, which I didnt have the money for, or time. If I had the time, I would have done it myself. Such as shame... Is it at least running like new?
Unread 09-17-2014, 09:04 PM   #13
Bobbie83CJ
1983 CJ7
Would love to see what you do with this jeep. If you lift is and put big tires on it we need to see a picture of it while it's delivering the mail. Now that's a mail carrier I would LOVE to see!
Bobbie83CJ is offline   Reply With Quote Quick reply to this message
Unread 09-17-2014, 09:09 PM   #14
chunk9
Starting to consider a 2"-ish lift for 32" tires...if I go too big, I won't be able to reach boxes!
Unread 09-17-2014, 10:10 PM   #15
Bobbie83CJ
1983 CJ7
Taking the doors off would fix that.
