hysteria's 90 yj build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > hysteria's 90 yj build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 04-02-2011, 01:21 AM   #1
jclauson
disclaimer: this thread is mostly bs talk! Save yourself time and just skim for pictures!
Well after reading build threads avidly for the last year, I figured I should get mine started.
Almost a year ago (may 2010) I picked up my 1990 YJ hard top full doors for 3000. It came with 33x12.50 mud terrains with decent tread and a 4.2l 258 straight six with a weber carb.
It had minor issues when I got it. The alternator belt was worn to shreds almost which was causing the engine to barely run. The PO thought it was the battery so they replaced the battery with a new one. I am not mechanical at all but I was able to see that the belt was TOAST so I put a new one on and bam it runs great. The valve cover gasket was leaking but that was an easy fix also. The hard doors had issues opening but the linkage is pretty simple in those doors and I have been able to fix and refix those several times.
I dont have any pics of when I first got it, so I will jump into some more recent pics ( april 2011)
Here she sits nice and muddy
The heep didnt come with a winch, so that was my first mod.
(this is me winching out my buddies yj)
I also put a smittybilt rear bumper and mounted some cheapo rear lights so I could get some better backup lighting on the trails
I continued to do some minor mods, mostly fabbed myself
In cab camera mount
Dome Light
fabbed up a mount for my hi lift and shovel
I bought a full size spare on a newer jeep wheel on craiglist for 40 bones. my rear hatch doesnt open anyway, so why not mount it on that? i made a spacer bracket to mount my spare on the hatch
heres another front view pic and some pics of my buddies white yj
I took my sway bar off since and get alot more flex, so I trimmed up my flares to help with the rubbing.
So thats it for pictures now. My plans for the jeep are to keep it relatively low, it sits about 3" now with springs and shackles in the front which I am not happy with, but the PO did that.
Some friends and I get together on Sundays and work on our jeeps. My plans for this weekend are to put in my Lockright Locker that I picked up on craigslist for 120 for the d35.
I have multiple welders and have been welding for fun for about 5 years, so I plan making most of my stuff. Soon I will be getting a tubing bender and will be making tube fenders.
Anyway, thanks for looking and I welcome critisism. I will probably be building this jeep over the next few years as I am 21 and married not having a ton of extra money but enough to make slow and steady progress.
1990 YJ w/ lots of home made sh*t
check it out
http://www.jeepforum.com/forum/f22/hysterias-90-yj-build-1190617/
jclauson is offline   Reply With Quote Quick reply to this message
Unread 04-02-2011, 01:26 AM   #2
jclauson
finally I started a build thread! I will try to get some more daytime pics of how it sits now. Also, here is a video I made of some footage from my in cab camera
I made the intro WAY too long so fastforward like 1 minutes in and watch it in 480p
check it out
Unread 04-02-2011, 04:28 PM   #3
jclauson
The lockright is going in the D35 tomorrow so I will post some pics of the install
check it out
Unread 04-03-2011, 10:34 PM   #4
jclauson
So we went to put the lockright in the d35...
but my wheels have locking lugs and we couldnt find the key. soo..... we decided to weld up my spider gears in my D30. It went great and I will post pics tomorrow. The only problem was that after we were done we discovered that my vacuum disconnect is broken, so looks like a posi lock will be replacing that soon.
Cant decide if I want to install the lockright or help a fellow jeeper out and install it in his rig
check it out
Unread 04-03-2011, 11:01 PM   #5
jclauson
So I got the pictures off the camera early... heres a pic of my diff when we popped it open
I was happy to find out that I had 3.55 gears not the 3.07 I thought I had. That explains how I can go 75 on the highway with 33" tires... so gear change may not be in my near future.
Anyway we cleaned it up with brake cleaner and waited for it to dry then welded up the spider gears to the carrier and the teeth in the corners. I did multipass on each side and was able to get great penetration into the side of the carrier, so I know it will be strong.
check it out
Unread 04-03-2011, 11:10 PM   #6
jclauson
heres a little something i am working on now when I have free time after work.... making a roof rack for my hard top and ill be moving my lights up too it.
check it out
Unread 04-03-2011, 11:17 PM   #7
rogerhill
This sunday went great I think we did ok considering the time restrictions. haha. I installed a hand throttle on my 93 yj as soon as Hysteria left my house. I think it was finished like 10 minutes after he left my driveway. We need to get more people involved in the suday projects. More thoughts and hands makes everything easier. We try to have whatever tool we have used on the jeep on hand in the jeep.
rogerhill is offline   Reply With Quote Quick reply to this message
Unread 04-03-2011, 11:19 PM   #8
Mudmouse990
nice jeep and im happy to see someone making there own stuff im in the process of making a rear bumper, i like to make all the stuff for my jeep too keep the pics coming
[B]90 yj 2.5l or pure power,thrush turbo, gutted cat, RC 4in lift,1" boom shackles, 33" BFG A/T's, outlaw alum rims,Rhino lined interior,overhead lights,connex 3300 cb, Homemade disco's, no rear trackbar
future mods- diamond plate rocker gaurds, fold down bus steps,home made front and rear bumpers , tube fenders, paint my doors red,possibly a winch, 302 ford or a 350 chevy, ford 8.8, cv style shaft and much more [/B]
[COLOR="Red"][SIZE="5"]
Check out my build thread[/SIZE][/COLOR] [url]http://www.jeepforum.com/forum/f22/90yj-getting-there-1155268/[/url]
[COLOR="Yellow"]My Home made Quick Disconnects Write up [/COLOR][URL="http://www.jeepforum.com/forum/f12/home-made-quick-disconnects-write-up-pics-1182040/"]http://www.jeepforum.com/forum/f12/home-made-quick-disconnects-write-up-pics-1182040/[/URL]
Mudmouse990 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2011, 11:23 PM   #9
jclauson
Thanks for the input! I wanted to fab my own rear bumper, but I have limited Jeep time so it was more worth it to me to buy one. My smittybilt rear bumper was only like 140, and i was not worried about a spare tire carrier because I plan on doing a fold down once we fab up some corner gaurds. If you have the time I would recomend fabbing your own for sure!
check it out
Unread 04-03-2011, 11:24 PM   #10
jclauson
Hey when you get a chance can you mount a picture of your hand throttle? I didnt get to see it before I left. If you need help with img tags just call me
check it out
Unread 04-03-2011, 11:26 PM   #11
jclauson
Hey mudmouse, how do you like the 4" rough country lift? Does it clear your 33s or do you still have rubbing? I have been going back and forth between staying SUA or going SOA.
check it out
Unread 04-04-2011, 01:23 AM   #12
jclauson
I found some old pictures of my 98xj.. my first jeep that got me hooked. I still see it driving around town. I will have another xj someday to add to the jeep army
theres an XJ under that mud somewhere... dont mind me on the hood. i would like to emphasize that these are OLD PICTURES dont judge me
yesss those ruts that are dug out by 35s are too big for my stock tires
I am happy to say that the pretty lady sitting shotgun here 4 years ago in this picture has now been my wife for almost 2 years (yes, i am only 21 years old, and i just realized you can barely see her in past the reflection on the windshield)
OK sorry the thread got off topic but I was excited when I found these old pictures
check it out
Unread 04-04-2011, 11:19 AM   #13
Mudmouse990
well its not bad i had some rubbing while flexing and if i had two people in the back seat haha but if you look in my build i trimmed my fender flares a bit as long as they stay where they are ill be happy meaning they dont sag. I just orderd a set of 1inch boom shackles but if these springs ever crap out im thinking about soa or bds 4.5
Unread 04-04-2011, 02:02 PM   #14
jclauson
I'll watch your build for the boom shackles then but u don't sound completely satisfied with it lol
check it out
Unread 04-04-2011, 11:13 PM   #15
jclauson
Looking into doing a home brew posi lock instead of my vacuum disconnect in the d30, anyone have any tips?
check it out
