Quantcast Hot JK build! Lets do it... - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Hot JK build! Lets do it...
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Closed Thread
Old 06-18-2009, 06:35 PM   #46
SDH
1995 XJ Cherokee
another crawl
Red 95 XJ 3" and on 31" BFG AT's
My JEEP http://www.jeepforum.com/forum/f22/sdhs-xj-build-953069/
Red JEEP #501
SDH is offline
Old 06-18-2009, 08:36 PM   #47
steve L.
well the frame looks to be in decent shape...once you get rid of all the crap that is left inside it should be a really cool build to do! Good Luck man
97' ZJ Laredo, I6, NP242
A Little Taste of Jersey Wheelin Of A 1997 & 1998 Jeep Grand Cherokee's For Your Enjoyment.
http://www.youtube.com/watch?v=sxa3-LJhz-Y
steve L. is offline
Old 06-18-2009, 09:20 PM   #48
jeeptrash
Cant wait to see it get under way!! Crawled
jeeptrash is offline
Old 06-18-2009, 10:39 PM   #49
ausi02
I know if a concrete building catches fire it must be demolished as its structural integrity is comprimised. I also know that heat makes steel hard and brittle. Do you think the fire could have even come close to making that much heat to mess with the frame?
Otherwise looks to be a sick build. There was an LJ build similar to this and it turned out BA! so you gottta set the bar even higher for burn builds
1998 Cherokee 2 Door 4.0 AX-15
4.5 Rustys +BB , 4.56 gears Ironscorpion/custom bumper, 35x12.5 Goodyear MTRs on Cragars,Dana 44 w/ Crown Vic Discs-H4+goJeep Harness, TNT Stiffners, ZJ steering, SYE waiting on driveshaft
ausi02 is offline
Old 06-19-2009, 12:39 AM   #50
BiTMAP
very neat starting point
paint flames on it when your done, just for the irony.
BiTMAP is offline
Old 06-19-2009, 12:58 AM   #51
JeepStreet
1991 XJ Cherokee
Should be fine, fire mainly burned from the carpet upwards, the roll bar may be jacked but underneath the carpet the Jeep still has its paint. There was only one tire that burned off the rim, this point of the vehicle may have reached 1000 degrees F just under the point at which aluminum melts and is quite enuff to temper steel to its first brittle stage. The wheel at that point was not melted but does look to be a little warped.
JeepStreet is offline
Old 06-19-2009, 01:00 AM   #52
JeepStreet
1991 XJ Cherokee
I did flames to a festiva and it gave it 50 more horsepower.
Old 06-19-2009, 01:12 AM   #53
HITMONEY
RubiKong's Trainer
HITMONEY's Avatar
Lemme guess... it is a automatic... No?
A few reports of Unlimited Automatics burning up... so far the speculation is an overheated tranny which over flows the fluid onto the exhaust.
Anyway, I've seen some pretty involved JK builds but this is the most intense undertaking I've seen on a JK yet.. by far.
Good luck with it!!
If I can be of any assistance at all lemme know.
Crawled.
I Wheel a Wave Killer!
08 Unlimited RubiKong
Pics And Info Of My Junk HERE.
YouTube Channel HERE
FaceBook HERE
HITMONEY is offline
Old 06-19-2009, 02:42 AM   #54
Donza
haha 'go fast flames'?
Donza is offline
Old 06-19-2009, 12:32 PM   #55
thefarside123
crawled- can't even imagine
thefarside123 is offline
Old 06-19-2009, 12:45 PM   #56
WranglerZac
you should paint it that burnt orange color !
and crawled
Black Jeep Society #589
Michigan Jeepers #84
V5 Group #1
1994-YJ
2002-WJ
WranglerZac is offline
Old 06-19-2009, 07:34 PM   #57
Pvt_Joker
wow good luck
just make sure it's awesome when it's done this has so much potential.
Pvt_Joker is offline
Old 06-19-2009, 09:01 PM   #58
spyder6
Just violated my Parole
spyder6's Avatar
Originally Posted by ********** View Post
I think I am gonna run the original fire-stained wheels on this thing as someone had suggested.
ahem...
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline
Old 06-20-2009, 01:15 AM   #59
yoda13
Force Wheeler
yoda13's Avatar
I crawled it too, this should be good...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Rancho RS5000 shocks, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, John 3:16
If you want to help the sport of off-roading, and protect your right to do so, please visit the Envirobeat
forum...
yoda13 is offline
Old 06-21-2009, 12:45 AM   #60
JeepIJoe
wow this is going to be an amazing build, good luck bro
JeepIJoe is offline
Closed Thread
Glock Forum
