Holm-z's TJ build... work in progress - Page 9 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Holm-z's TJ build... work in progress
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 03-19-2013, 01:52 PM   #121
Holm-z
Holm-z's Avatar
just ordered some U-Joints so I can get that taken care of. Got all my dash put back together!! looks pretty good! now just to see if everything works! few more things to tinker on before she gets rolling though! Pics to follow!
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, Aux lights
my TJ build
I understand.
IAFF Local 4942
Holm-z is offline   Reply With Quote Quick reply to this message
Unread 03-21-2013, 10:12 PM   #122
Holm-z
Holm-z's Avatar
Got some pics of the installed switches. Now waiting for my u-joints to show up. I bought some for my axles and my driveshaft that way I have some spares (only because I ordered the wrong ones to begin with!)
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-21-2013, 10:32 PM   #123
HighRoller02TJ
HighRoller02TJ is offline   Reply With Quote Quick reply to this message
Unread 03-21-2013, 10:43 PM   #124
Holm-z
Holm-z's Avatar
Im going to start stripping my seats out then prep work for the monstaliner. I figured if its still not moving at the moment, might as well get going on that otherwise it will be another year before I get to it.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-22-2013, 05:00 AM   #125
HighRoller02TJ
remember to remove the drain plugs. i bought my jeep with the rhino liner already done and the guy who sprayed it on did not remove any drain plugs.
Unread 03-22-2013, 05:04 PM   #126
Holm-z
Holm-z's Avatar
good call! ive read somewhere that people use ear plugs so im going to buy a few packs of those soon. I cleaned all the stuff out of my jeep and there is like 1" of dirt im going to have to sweep, vacuum, sweep, vacuum, sweep and then vacuum some more before I even start washing and prepping back there!!
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-23-2013, 02:46 AM   #127
Holm-z
Holm-z's Avatar
Sprayed PB Blaster on the seat bolts tonight, going to do it again tomorrow and really soak them. Ill try to remove the seats tomorrow night if i have time.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-23-2013, 04:56 AM   #128
HighRoller02TJ
WD40 has a new product that works great also. i started spraying under my jeep
Unread 03-24-2013, 02:50 AM   #129
Holm-z
Holm-z's Avatar
Got my seats and center console pulled!!
What a PITA with rusted bolts. Used 2 cans of PB Blaster and soaked the S*** out of them! Vacuumed and used a towel to get most of the dirt and debris up. Hopefully it will warm up some where I can roll it outside and hose the rest of it out.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-24-2013, 02:58 AM   #130
Holm-z
Holm-z's Avatar
a few more...
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-24-2013, 03:00 AM   #131
Holm-z
Holm-z's Avatar
Im having a real tough time with the rear seat bracket bolts... The front two broke off and the back two are just spinning. Looks like im going to have to drill the front two bolts out and get a sawzall and cut the other bolts and then drill them out as well.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-24-2013, 06:17 AM   #132
HighRoller02TJ
try this
Unread 03-24-2013, 02:26 PM   #133
Holm-z
Holm-z's Avatar
Yeah I picked up a can of this the other day... Used it all up on the racecar though lol. I bought 2 cans of PB Blaster and used both of them on my seats. The bolts just spin so I don't think any spray is going help. Im just going to cut the bolts off and drill them out. I don't use my rear seat much anyways so If I screw it up too bad I won't be that upset.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-25-2013, 08:48 PM   #134
Holm-z
Holm-z's Avatar
U-joints for driveshaft and axles came today
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-25-2013, 08:51 PM   #135
Holm-z
Holm-z's Avatar
Took the racecar over to Rutland, VT to the mall for a show this past weekend.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
1998 , nh , sport , tj , wrangler
