Holm-z's TJ build... work in progress - Page 16 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Holm-z's TJ build... work in progress
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 09-19-2013, 03:44 PM   #226
Holm-z
Holm-z's Avatar
Originally Posted by HighRoller02TJ
nice job with the Jeep, any updates on the truck?
Thanks man. Not much for progress on the truck, had to bring the girlfriends car to the shop last week for regular maintenance. I have an appt to drop it off at the local body shop for a quote on Monday. I'm thinking like $2500-$3000 in damage. Good thing for insurance!
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, Aux lights
my TJ build
I understand.
IAFF Local 4942
Holm-z is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 03:47 PM   #227
Holm-z
Holm-z's Avatar
Bought some gorilla lug nuts the other day. I stripped 3 of the old ones taking the tires off and on this year. Hopefully these babies will last a while. I don't know if I will put the lock nuts on my drive tires or my spare. I'm not too concerned about thieves stealing the tires out from under the jeep.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 10-05-2013, 12:09 PM   #228
Holm-z
Holm-z's Avatar
Finally got my new wheel bearings on last night!! Drivers side was definitely on its last leg.. Now the front end is done!!!
Now the next thing I have to do is replace both front fog lightbulbs in my KC day lighters. Ordere the bulbs today 15 bucks a piece and will be in on Monday.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 10-10-2013, 12:27 PM   #229
Holm-z
Holm-z's Avatar
The bulbs ended up being 11.99 a piece, so that made me happy . But when I took the jeep out for a test spin, the freakin mirror fell out of the casing and smashed in the roadway! So I went and bought a small 5" round mirror that fits into the aftermarket bracket. Drove it to work in Keene last night and I'm impressed!!! She drives ok!! Still having some transmission problems but hopefully that will be solve when I do the mml and new fluid in the tranny.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 10-18-2013, 05:57 PM   #230
Holm-z
Holm-z's Avatar
Got it inspected today, Yaahooooo!!!! Now I don't have to worry about the state troopers when I pass them!!
Still have to do the mml, in another week or so I should get a chance to install it. Also got my truck back from the repair shop... Looks like new! Hopefully it stays that way for a while.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 12-07-2013, 04:37 PM   #231
Holm-z
Holm-z's Avatar
Well, not much progress on the Jeep... Still having a clutch/transmission issue. When the clutch is pressed all the way in its fine, but when I let off in Neutral, the transmission is trying to grab and pull forward. Still havent done the the MML, so im hoping it just needs adjusting. If that doesnt fix it, ill have to start a winter project and im not looking forward to that!
I did take it out and drive it around the other day. Thankfully everything else we did over the summer is holding up and feeling ok.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 03-10-2014, 09:54 PM   #232
Holm-z
Holm-z's Avatar
Took it out and drove it for about an hour yesterday... Still having some shifting issues but she fired right up with no hesitation and felt good driving otherwise. We have one more snowstorm moving in this week so im not done snowmobiling for the year that means my jeep will have to wait a few more weeks before I start focusing my attention on her.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 04-26-2014, 05:20 PM   #233
Holm-z
Holm-z's Avatar
Pulled the jeep out again the other day and bought some up/down stream o2 sensors. Started PB blasting them and then tried to replace the upper sensor...
NOPE!! They are pretty much welded on there. Stripped the nut on it and even used a propane torch for some heat... Still nothing...
Next step is to get it up on a lift and use a oxy acetelyne torch to heat it up.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 05-23-2014, 05:17 PM   #234
Holm-z
Holm-z's Avatar
Well I finally got around to getting the upstream O2 sensor out... End up having to use an oxy-acyeteline torch to get it hot enough to break free. Once we got that on, started her up and no sputtering!!! Finally!
Cleared the code and onto the next project of the day, MML. That wasn't too bad to do, didn't have to use the torches on those! It took a little muscle to move the engine to the exact bolt alignment holes at first but other than that it was a breeze.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 05-23-2014, 05:46 PM   #235
Holm-z
Holm-z's Avatar
Few more driveway pics. My buddy backed his TJ next to mine for comparison. He's deciding on a lift to hopefully do this summer.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 05-24-2014, 05:59 PM   #236
HighRoller02TJ
looks good
HighRoller02TJ is offline   Reply With Quote Quick reply to this message
Unread 05-27-2014, 04:03 PM   #237
Holm-z
Holm-z's Avatar
Originally Posted by HighRoller02TJ View Post
looks good
Thanks man
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 05-27-2014, 04:15 PM   #238
Holm-z
Holm-z's Avatar
Went out for a little spin in woods the other day
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 05-27-2014, 04:41 PM   #239
Holm-z
Holm-z's Avatar
This also showed up today...
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 05-27-2014, 05:05 PM   #240
Holm-z
Holm-z's Avatar
Now for the install!!!!!
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
1998 , nh , sport , tj , wrangler
