Holm-z's TJ build... work in progress - Page 10 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Holm-z's TJ build... work in progress
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 04-05-2013, 10:04 PM   #136
Holm-z
Holm-z's Avatar
Bought 6 cans of rustoleum to spray on my tub before I start monstaliner. Still haven't prepped the tub or anything yet, I'm working 12 days in a row so probably won't get to it until next week sometime.
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, Aux lights
my TJ build
I understand.
IAFF Local 4942
Holm-z is offline   Reply With Quote Quick reply to this message
Unread 04-06-2013, 04:51 PM   #137
G Beasley
Just finished your thread , I am so glad I live in the south and we dont have the rust to fight like you guys do . It was funny to see Rutland mentioned as I stayed there for a few months when I was working in South Royalton . Anyways , keep up the good work the switches turned out awesome .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 04-06-2013, 06:27 PM   #138
Holm-z
Holm-z's Avatar
Thanks man! Yeah rust is such a pita!! It's on just about every car truck trailer around up here.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 04-18-2013, 10:55 AM   #139
Rubicon0311
Have you done your Monstaliner yet??
[URL="http://www.jeepforum.com/forum/f22/rubicon0311-build-1470981/"][B]My 4.6 Stroker build[/B][/URL]
[URL="http://www.jeepforum.com/forum/f325/what-did-you-do-your-xj-mj-tj-zj-wj-wk-lj-jk-thread-1289204/"][B]Michigan BS Thread[/B][/URL]
Rubicon0311 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2013, 08:10 AM   #140
HighRoller02TJ
i still have the bestop windjammer and tonneau cover to give you. if i decide to go to go topless day NH i can give them to you then, im not sure if im going or not. how about you?
HighRoller02TJ is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 08:36 PM   #141
Holm-z
Holm-z's Avatar
Hey guys, sorry been busy with work as well as working on the race cars. I've sanded, washed then sanded the spots I missed the other day. Tonight was the first coat of rustoleum primer.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 04-23-2013, 08:46 PM   #142
Holm-z
Holm-z's Avatar
Nice dude, thanks. I'm planning on going with my jeep if I can get it inspected by then, if not I may or may not go, depending on what else I got going on. Hopefully once race season starts, the cars will be on the trailers and my other garage bay will be open, If you still want to do that body lift.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 04-23-2013, 08:48 PM   #143
Rubicon0311
Put the Monstaliner on THICK! I didn't do so when I did my tub, I wasn't sure if I would have enough. Boy was I wrong.
Unread 04-23-2013, 10:58 PM   #144
HighRoller02TJ
Nice. Ive been soaking the bolts everyday. Before i install the lift i want to take every body mount bolt out and back in so when the lift is installed there is no dealing with broken bolts. so far i have 1 rear broken bolt to remove and the front body mount came out clean. working on the sides this week
Unread 04-24-2013, 05:36 PM   #145
Holm-z
Holm-z's Avatar
Second coat of rustoleum on tonight. Looks really good, now I just got to order the monstaliner!
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 04-25-2013, 12:05 PM   #146
Holm-z
Holm-z's Avatar
Did you get the 1 gallon kit? I think that's all i will need for the interior tub.
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 04-25-2013, 12:38 PM   #147
goducks3620
you might want to pry out one of those metal drain plugs on each rear passenger well, that is what I did on mine before monstalining it. The JK oval plugs will fit in there and you'll want some drainage options back there.
goducks3620 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 12:46 PM   #148
Holm-z
Holm-z's Avatar
I can pry them off? I was just gonna drill a 1" round hole in it and use the same plugs as the front. Ill have to go out and see cause that may work better, thanks for the tip
3.75" RC
Superwinch 10000lb
my TJ build
I understand.
IAFF Local 4942
Unread 04-25-2013, 12:47 PM   #149
Rubicon0311
Yep, 1 gallon is plenty, I didn't put it on thick enough and had a bunch left over.
Unread 04-25-2013, 12:50 PM   #150
goducks3620
look underneath the jeep. each is held on with two metal tabs, once you pry them back, you can either pop it out from underneath or from top or both. The passenger one is above the heat shield so from top is easier there, once you open up the tabs from the side.
1998 , nh , sport , tj , wrangler
